Exploding Tire Kills 8yr old boy
/ Exploding Tire Kills 8yr old boy #31
I often see wobbling Dayton wheels due to some tire jocky not knowing how to properly mount them. (No big secret, simply snug up the lug nuts a little at a time while rotating the wheel)
/ Exploding Tire Kills 8yr old boy #33
Up in Fort Mac, when the heavy hauler tires blow it removes the fenders and blows the windows out of any pickups nearby.
/ Exploding Tire Kills 8yr old boy #34
Having been in the tire businees for many years (now retired), we worked with splits all the time. My standing orders were always the same: Use the cage and locking tire chuck or pick up your final paycheck. I didn't want to make that phone call to a loved one saying their man was blown to pieces because he failed to follow orders. That said, I had a young man who didn't follow orders and when I spotted what he was doing (kneeling on the tire,no cage, AND unaware that the ring had begun to separate). I drop kicked him halfway across the shop while similtaneously ripping the air chuck off the valve stem--all at a dead run. It still makes me cringe even today. That was his last day working for me.
/ Exploding Tire Kills 8yr old boy #35
25 years ago on a hot afternoon I heard an explosion, windows shook and things fell from the window sill. I went to investigate and the front tire from a car I had for sale had exploded. It was a small car with probably a 13 or 14 inch tire.
Scott
It can happen...back in the early '90's I had a Ford F150. The tires, while not brand new, were in good shape and filled to proper pressure. One extra hot day in August one of the front tires blew up while sitting in my front yard. Luckily no one was near it at the time. The blast destroyed the inner fender and overflow tank. I was just thankful my kids were nowhere near it when it happened.
/ Exploding Tire Kills 8yr old boy #36
My brother has an old hay trailer with 7.50-20 wheels, very old truck wheels. I assume the axles came off a truck from the 50's because nobody uses this dimension anymore, let alone on single wheel, three piece rims.
Anyways, i changed a tube some years, but i was warned by a neighbor who used these in the days they were common. I followed his warning and strapped a tie-down ratchet around the tire and rim, so if the locking ring would jump out of its groove while inflating, its speed would surely be limited.
Anyways, my brother took this trailer home on a flat tire, when the hay he stacked on it is up, he'll change the wheels and axles for some 10-15 agricultural tires with 6 lug axles, which are readily available on many scrap machinery, and wont kill a man when they blow during assembly.
/ Exploding Tire Kills 8yr old boy #37
The strap may have made you feel better but it wouldn't have helped if it came apart. Those cages were made that heavy for a reason. Seen some massive damage over the years from rings flying through walls, cielings etc..
/ Exploding Tire Kills 8yr old boy #38
It helps as much as water jars around pillars of highway overpasses. They arent strong at all, but they do absorb a lot of energy while breaking.
/ Exploding Tire Kills 8yr old boy #39
One strap wouldn't work...it would just act as a hinge if it didn't break and the locking ring would still swat you. Besides...if the assembly blew apart when at full pressure, just the air blast is enough to kill, let alone any physical contact with the tire or rim parts.
/ Exploding Tire Kills 8yr old boy #40
Was talking about seating the locking ring at 1 to 2 bar pressure.. thats the most tricky part.
(INOP) MASSEY FERGUSON 1552 TRACTOR (A59823)
(INOP) MASSEY...
2017 ADDCO ROAD SIGN DH1000-ALS (A60736)
2017 ADDCO ROAD...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
