Backhoe Bucket Tooth Wear
/ Backhoe Bucket Tooth Wear #41
jinman said:
I think I get your inference. I should quit whining like a mamby pamby and be happy I have it so easy, huh?:laughing: I suspect there's a bit of truth in that.:D
When did R Lee join the thread?
:laughing:
/ Backhoe Bucket Tooth Wear #43
jinman said:
I looked at one of those when looking for teeth, and it prompted me to talk about not having installation instructions for teeth in the operator or service manuals. I know how that tool works for both insertion and removal, but I swear I do not think that split pin shown in use on the tool will work on my backhoe teeth. The darn pin would not extend out on each side of the stub and the tooth would just fall off. If I have room, I can deal with nuts and bolts alot better than a high-tech split pin.:confused2:
The split pins will protrude around 3/16" of the shank. They hold a tooth in place real well in impact situations, whereas a bolt will break. If the shank is worn, and the tooth is loose, bolts will work better, especially in the digging conditions you have. Of bolts work, use them.
Well, my teeth aren't loose on the shanks, so maybe the split pin will work. They look big to put into the 7/16" hole, but maybe that's just because of the filler material in the split. The next time I change teeth, I may try a pin on one of the outside teeth to see how it works. If it had pins when I first got it, I'm sure I'd have more faith in it. But never seeing it with pins makes me a little skeptical as you can tell.:)
/ Backhoe Bucket Tooth Wear #45
Romac came through with prices for my Bradco bucket. Twin Tiger tooth $11.32 and $1.71 for roll pins. It will cost be $65.00 to buy another Mahindra/Bradco shank and weld it on to narrow the gap between teeth and to have 5. I looked at the bucket again this morning in relation to the thumb and think now I will not add a tooth and just go with 4 Dual Tiger teeth.
hugs, Brandi
hugs, Brandi
Brandi, did you ever receive your teeth? How do they fit and what do you think? Enquiring minds want to know....:D
/ Backhoe Bucket Tooth Wear #48
Jim,
Between the ice and me still recovering from foot surgery, I haven't ordered them yet.:( I'll post when I get them on order.:thumbsup:
hugs, Brandi
Jim,
hugs, Brandi
Brandi, I hope your healing is going well. To hear somebody from Willis talk about ice is really, really strange. This storm really kicked our collective butts here in Texas.:confused2:
/ Backhoe Bucket Tooth Wear #50
Storms like that really aren't that uncommon as far as the Earth's concerned. I remember hearing about it happening when I was a kid. They're just not common enough to build for them. Now if you start getting them in August... I'd be getting worried.:laughing:
/ Backhoe Bucket Tooth Wear #51
Jim,
Thanks. Houston had more ice and rain fall then we did.
hugs, Brandi
/ Backhoe Bucket Tooth Wear #52
To install the split pins; I clamp the split pin as tight as possible with large vise grips to compress the rubber. Align the pin with the hole, and tap on the vise grips to install pin. Some pins have a front and back, some don't. The specialized pin removal tool works well for removing the retainers, or use a punch.
I found out that if you hit the tooth hard enough, metal can flake off and bury itself in your palm like shrapnel. I pulled the sharp flake out and eventually the blood stopped flowing. 18 months later the second chunk worked it's way to the surface, and I dug it out with a utility knife. Finally, the soreness went away.
Morals of the story; A. Wear safety glasses
B. Use a hard wood block between the hammer and the
tooth
SixHoeBob, thanks for the instructions and advice.:thumbsup: My pins do have a front and rear with "rear" embossed on one side. I also noticed that the holes through the stub are larger on the right side, so I think they are made that way to have the pins inserted there and then driven into place. I will try the pins the next time I change teeth.
/ Backhoe Bucket Tooth Wear #54
Speaking of changing teeth... How are the new ones holding up to that material you're digging?
Cyril, I only dig in nice weather. That's the benefit of being retired.:D Lately we have been sub-freezing and my flooded basement has kept me busy. Because of that, I've only been digging twice with the new teeth and they are superb. I've busted up lots of big chunks of caliche and then pulverized them by dropping the teeth on them.
As a side note, I looked at my excavation yesterday and there was a pool of water about 8' in diameter where it doesn't drain off. The water was so clear, I thought I was just looking at wet mud before realizing there was a foot of water on top of it. I hope that indicates that this is going to be a beautiful clear blue pond. Being 90% in caliche, I think it has that possibility.
/ Backhoe Bucket Tooth Wear #56
I guess you have been a little distracted. My bad, I wasn't thinking.:ashamed:
Let us know how they hold up when you get some time on them.:laughing:
/ Backhoe Bucket Tooth Wear #57
Boy I wish I could wear teeth down. All I ever do is break them. I just buy them at the local Case dealer, it's cheaper for me than on-line once you figure in shipping.
I've used the backhoe some this week to dig and move about 100 yards of caliche. It is working very well. It's such a pleasure to do my checks, fuel up, and grease up then head out to do some work. This LB75B is really spoiling me. I've done some very rough calculations and I think I'm using about 1 gallon of fuel for every 8 yards of material dug up, moved, and spread. At $3.30 per gallon, that means I'm moving material at a fuel cost of $0.41 per yard. I'm guessing that with the other maintenance items, I'm looking at an operational cost around $0.50 per yard. I don't know how that compares to what other people might see. If I was digging and hauling in a trailer, I don't think my overall costs would be any less. My wife told me that the loader bucket was so heaped up when I was hauling loads to the fill area that it looked like there was more dirt outside the bucket than inside. I'm sure those heaped buckets are over 2 yards.:thumbsup:
/ Backhoe Bucket Tooth Wear #59
Jim,
I finally got around to ordering my fork teeth yesterday and was told they are back ordered. So now I wait longer.
hugs, Brandi
/ Backhoe Bucket Tooth Wear #60
A ripper is a good idea to use in tight ground. Over here we get a ripper off a dozer and weld a box on the top with the ears off that so that it looks like the area of the bucket where you attach it to the dipper. If you have a quick attach then weld the pins into the ears then all you have to do is dump the bucket, pick up the ripper, do your ripping then change over etc. In tight or rocky ground they are the go.
Hardfacing bucket teeth is no more than false economy cause the cost of rods,time etc and also it stuffs the metal under the weld. You can end up getting real busy, don't have time to reface the teeth then they wear at twice the rate.
2018 PJ Trailers 14ft T/A End Dump Trailer (A61568)
2018 PJ Trailers...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
UNUSED SDLANCH SDLGC100 ELECTRIC GOLF CART (A62130)
UNUSED SDLANCH...
Mama Goat Decorative Statue (A61569)
Mama Goat...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
2025 Swict 78in. Bucket Skid Steer Attachment (A61567)
2025 Swict 78in...
