BX25 Loader Control Valve Grease Zerk
/ BX25 Loader Control Valve Grease Zerk #1
CompactTractorFan
Super Member
Pennsylvania
Kubota BX25
In the operators manual it mentions greasing the "loader control valve". Is that the valve that the joystick is attached to? If so we can't find the zerk...
/ BX25 Loader Control Valve Grease Zerk #2
no zerk for the loader control valve. at the base of the loader control spray some lube under the boot. there's another zerk for the foot pedal under the mat.
steve
bx25
steve
bx25
Thanks, I knew about the one under the mat...
UPDATE: I now have some white lithium spray grease I'm going to spray on the FEL control valve. I'm wondering if I could do the same with the BH control valve? They seemed to have started squeaking...
:anyone:
/ BX25 Loader Control Valve Grease Zerk #8
I use the white lithium grease on my BH controls with great results.
/ BX25 Loader Control Valve Grease Zerk #9
is there a grease fitting under the mat on the bx 24?
yes there is- its for HST pedal shaft .
It won't hurt it.... :thumbsup:
/ BX25 Loader Control Valve Grease Zerk #11
any idea on the location on the bx24 ? its easy to find on the bx23 ...is it up underneath? I just spray lubed with lithium grease, the loader control underneath the rubber boot and the control seems really loose now
/ BX25 Loader Control Valve Grease Zerk #12
Its a tiny half circle cut in the mat just to left of the hst pedal if I recall correctly. you will need a small flat blade to flip it up to access the zerk.
/ BX25 Loader Control Valve Grease Zerk #13
There is no loader zerk on the BX24..Only on for the foot pedal. The other levers on the BX24 are all, well, silicone works just nice.
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
Long 350 Tractor (A62613)
Long 350 Tractor...
Rock Hammer for Excavator (A65579)
Rock Hammer for...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
New/Unused Wolverine 72in Quick Attach Rock Bucket (A65583)
New/Unused...
2011 GALYEAN 130BBL (A65643)
2011 GALYEAN...
