Comparison B2920 vs B3200 vs JD2520
/ B2920 vs B3200 vs JD2520 #1
architect
Western PA
Kubota B1750, traded, L3010 sold, B2920, Mahindra eMax 25
started pricing the JD 2520 because of the quick change bucket (FEL) and other quick attach implements, tractor with R4, 62" MMM, 200CX loader is $18,500 (before any taxes).
Then of course I had to look at Kubota (have owned two), so I priced B2920, FEL, 60" MMM and was at $18,500, then looked at the B3200 because of loader and quick attach bucket like JD 2520, tractor, FEL, 60" MMM was $19,250.
Plan on using it for mowing mostly, and driveway clearing (450' +), but first will be using it to excavate for an addition to my house, I used a Kubota B1750 years ago to level off the same area for a above ground pool, now need to go down another 4 ft., so 23 HP to 32HP with B3200 should work fine.
I will be adding other options later like a tiller, box blade and front blade, but t the initial purchase done as priced above.
I understand the B3200 doesn't have the deluxe options of the B3030, but not worried.
Does anyone know if old B1750 or Grand L3010 had position control or quater inch valving?
because I know the Kubota's would be quarter inch and JD position control, and I owned the B1750 and L3010 before.
What are your thoughts?
/ B2920 vs B3200 vs JD2520 #2
I don't know anything about JD. Is the JD the same HP as the Kubotas? Kubota has B2320 and a B2620 if the JD is 25HP which would probably be the closer comparison and a few thousand dollars cheaper on the Kubotas.
You may also want to call/contact Barlows for a comparison of an actual bottom line delivered price to your home of any/all of the comparable Kubotas.
Barlow Equipment - Home of the Kubota Tractor Package Builder
Barlows is the source of my Kubota prices, JD is 26HP, B2920 is same price due to $1000 available from John Deere, will always go with more HP.
John Deere is larger than B2920, so looked at B3200, surprised by price vs B3030.
With B3030 and B2630 being replaced, looked at B3200 because was $1000 to $2400 cheaper than deluxe B's.
John Deere two speed rear became a sticking point, Both Kubota's have 3 speed.
I guess I just stumbled on the B3200 price and it looks too good to pass up for the HP and the size, I sold my L3010 because it was physically too big and unstable on slopes.
/ B2920 vs B3200 vs JD2520 #4
I've had a 2920 for about 2.5 years now. I like the 3 speeds and most of the time it is in the mid range. It is pretty seldom I need to go to low. It has the suspended mower deck and is a drive over so it is pretty easy to R&R. The 3200 uses the deck that rides on the ground as does the 3030. I use it to clear a similar length driveway with a FEL and rear blade. I would prefer a front blade, but hard to justify the expense for the amount of snow we typically get in a winter. The engine is very smooth on the 2920 as it is a 3 cyl. Before you pick a 3200 you would want to test one and make sure you get it to near PTO RPM's and decide if the vibration of the 4 cyl is an issue for you or not.
Clearly the 3200 is a bigger framed tractor with stronger hydraulics, so the better excavator, but frankly I think that would be a good job to hire out or rent something more suited to the task. If you do decide to attack it, you will probably want to go ahead and get the box blade as it would help break up the soil and add a counter balance to the loaded FEL. I was using mine to remove some dirt in the pond on our other property when the pond was down and spent a lot of time and made a lot of trips and still didn't get that much done. If I was really serious about it as if we built on that property, I would bring someone in to do it.
As for the 1/4" valve, it does not bother me when using the box blade or rear blade and in fact I think it works pretty well for them. You can bring it up or down in small increments or slow and smooth or quickly. The only problem for me in using it is with the brush hog. It will not hold it at the same height, requiring you to readjust it every so often. I now use chains on mine to keep it at the height I set it.
/ B2920 vs B3200 vs JD2520 #5
I really like the B2920, but the lack of position control on any tractor is a deal breaker for me. I dislike the one on my BX2660, but position control is not available on that model. In using position control and quarter inching on sometimes a daily basis, I can do much better work with position control.
As mentioned, for some it is an issue and not for others.
My knowledge of the B3200 is limited, but I guess it does not have a drive over Mower deck?
Does anyone know if the older Kubota's B1750 and L3010 were quarter inch valve or position control (back when I owned them they seemed the same, and would guess from explanations on this site they were quarter inch - so that would be fine, had no problem with it)
/ B2920 vs B3200 vs JD2520 #7
As far as I know only the B2x20 series has a drive over deck in the Kubota product lines. The mowing height is set on the B2x20 by raising the deck, adjusting a knob to whatever height you want and then lowering the deck and it is suspended at that height. The wheels are anti-scalping wheels and are not normally riding on the ground. The deck on the B3200 & Bxx30 tractors are set for their mowing height by adjusting the wheels which ride on the ground more like an RFM.
In the Kubota B series only the Bxx30's offer the position control currently. I don't know about previous models. Perhaps someone with experience will help you out on that.
/ B2920 vs B3200 vs JD2520 #8
Really, I'd call it more appropriate to compare the JD 2520 to the Kubota 2620. Those are the two similar tractors. So...... does the JD offer anything worth the $1000 difference? Perhaps having position control would be that important? Or having the brake pedals on the left?
I think that if finish mowing were the priority, I'd be looking toward the 2520 or the 2620 / 2920. If dirt work were the priority, I'd be looking at the B3200. A 3200 will handle implements a foot wider than the other tractors, but it's extra wheelbase and slightly heavier weight would be a negative when finish mowing.
/ B2920 vs B3200 vs JD2520 #10
I'm new to tractors. Can someone elaborate what position control is?
/ B2920 vs B3200 vs JD2520 #11
Great explanation of position control.
To clairify, the JD2520 (and 2320, 2720) have a larger chassis, wheelbase like the B2630, B3030, B3200, the B2920 are maybe 6" smaller with smaller wheels. My personal preference would be the B2630, B3030 only because I love the treadle pedal for the HST, both my previous tractors had it, liked it better than separate pedals. But maybe I should go the extra $1000 to get it since Kubota is changing all tractors to separate pedals, can't see an extra $2500 for the B3030.
Maybe I should check with Barlows for a B2630.
/ B2920 vs B3200 vs JD2520 #13
On a road trip last summer I stopped at a Kubota dealership in MO to get an accessory that they carried. While there, I sat on some tractors and the one I really liked was a B3030. My dealer did not stock them because he said he had not found most buyers willing to pay the extra vs the more basic models and I suspect that was an accurate statement. At the time I bought I knew so little and was already so confused between the models that I also probably would have not paid the extra. But the position control, the telescopic stabilizers instead of turnbuckles and the telescopic lower arm links are really better. Also just the feel of a little wider stance and that you seem to sit more down in the tractor makes it seem like it would feel more stable. I would still prefer the suspended mower deck on the 2x20 series, but otherwise, I think a B2630 or B3030 would be a great choice. If I was personally buying one, I would probably opt for the 60" MMM instead of the 72". At one point some of the members were saying they were getting a rebate on the 2630, but I don't know if that is still going on or not.
Believe it or not these discussions may be talking me into the JD2520, 26.5 HP, FEL with removable bucket, position control, drive over mower deck, larger chassis than B2920 for stability for $18,500 about $1500 less than B2630, maybe I should post in JD forum, sorry Kubota.
/ B2920 vs B3200 vs JD2520 #15
My personal preference would be the B2630 regardless of cost, but I believe all TBN members strive to provide the best information available to us to help other members make the right decision for them, in this case it may very well be a John Deere.
I think it is a wise move for all new tractor shoppers to cast a wide net and look at all of the top manufacturers. Good luck.
Thanks for all the information, I read the posts to learn, I listed the prices I talked with dealers because for a tractor buyer there doesn't appear to be a 'Edmunds' to help out. I wish all who purchase would post their prices.
Also found an old picture of my B1750, it had Bar Turf tires on it, never knew what they were back then, buy do remember the great traction in snow and they never left a mark on the grass. My L3010 had R4's, hated them.
Now the latest thought, buy the B2920 with bar turfs, and because it has the three range transmission, JD has two and JD owners wish for three in a lot of posts. The B2920 appears to be the only size tractor with bar turfs, rare tire, otherwise would have picked the B3200.
/ B2920 vs B3200 vs JD2520 #17
Arch...is that price of $18,500 for the 2520 and the listed attachments the msrp price or the price you negioated?
price was selling price that included $1000 John Deere cash, no taxes, included local delivery.
Just an update, looking at Kubota B2920, FEL, 60" MMM, and backhoe, but wife is hesitant about expense of backhoe. Any comments from people who have one?
/ B2920 vs B3200 vs JD2520 #20
Have the B3200 TLB and I can honestly tell you it is quite the tractor, lots of power.
DevilDog
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2022 Chevrolet...
2025 60in Hydraulic Forks and Frame Skid Steer Attachment (A66734)
2025 60in...
2018 Chevrolet Suburban 4x4 SUV (A66738)
2018 Chevrolet...
2011 BRENNER TANK 200BBL CRUDE TANKER (A67714)
2011 BRENNER TANK...
2023 Ford Explorer SUV (A66738)
2023 Ford Explorer...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
