Soldering vertical copper pipe
/ Soldering vertical copper pipe #1
bcarwell
Gold Member
Austin, Texas
Kabota 7500DT
I have a vertical 3/4" copper pipe I just cut a section out of which froze and cracked. Now I'm replacing it with a new piece of pipe and two standard slip joints- one on either end. My question is how do you sweat solder when the joints are vertical ? I know how to solder and I know about capillary action sucking in the solder even vertically, and that you make the part hottest in the direction you want the solder to flow. But: once you've soldered in one side of the slip joint when soldering the other side won't it heat up the side you just soldered to cause the solder to flow out ? What order should I solder the joints in or does it matter ? Should I first solder on the slip joints onto the piece of replacement pipe at my workbench so I only have two joints left to solder when I put the replacement pipe in place ? Still seems like in doing so I'd be heating other side of the slip joint that I had soldered at my bench. And how long should the spliced-in piece of pipe be or does it matter ? Just a few inches long to replace all the bulged pipe where the crack was ?
Thanks for any tips (or reassurances if it will work just fine)...
Bob
/ Soldering vertical copper pipe #2
Not an expert but think I found out a few years ago that there are fittings for bulged pipe :confused: I know I have soldered vertical pipe with no problem. Easy as horizontal :D
/ Soldering vertical copper pipe #3
I would solder them all in place starting at bottom and working up. Make sure pipe and fittings are dry of water, clean, sanded and fluxed properly. You did not state what type of solder or flux you were using. I prefer a few inches between the couplings to keep one from overheating the next.
/ Soldering vertical copper pipe #4
I had to do this last winter. I did the bottom joint first, heating the middle of the coupling and then applying solder to both sides real quick. Next the top joint in the same way. Remember heat rises so doing the bottom will send a little heat up to the next joint. My joints were about a foot apart. You can also use a wet rag on the first joint once it's done to keep any additional heat off it while you do the second one.
/ Soldering vertical copper pipe #5
I am a HVAC/R - plumber and there are really no issues vertical or horizontal that practice doesn't take care of. I generally go bottom up. I heat side closest to me and start solder on backside and let it draw around joint and then onto next joint. Couplings are really no issue, key is to not overheat. When solder starts to flow you can take heat away for a moment. It does take practice, but in my 25+ years of exp. most people have problems because they overheat the joint.
/ Soldering vertical copper pipe #6
Or they do not properly heat the fitting to draw the solder in
/ Soldering vertical copper pipe #7
Some over heat because they do not get joint cleaned and fluxed right also.
/ Soldering vertical copper pipe #8
Never do your joints too close together....space them out over time. :confused2:
Sorry.....I just couldn't resist that one....;)
Many thanks guys for the quick, informative, confidence building replies, just in time for the weekend ! It's guest house for mother-in-law, so can't wait to get her back in it
/ Soldering vertical copper pipe #11
:laughing::laughing::laughing::laughing::laughing::laughing:
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
Kubota L3901HST
Kubota L3901HST
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
PORTA POTTY (A68842)
CASE  721F WHEEL LOADER (INOPERABLE) (A67714)
CASE 721F WHEEL...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
