Leaking seal on 5740
/ Leaking seal on 5740 #1
nebraskasparks
Gold Member
Northern Illiniois
2010 Kubota L5740 HST and JD X734
Anyone have a problem on the rear seals on the 5740 weeping enough to get your attention? No leaks per say but enough residue to catch my eye. -17 this morning...springs right around the corner:laughing:
/ Leaking seal on 5740 #2
.......... the rear seals on the 5740 weeping enough to get your attention? No leaks per say but enough residue to catch my eye.......
which seals - axle? 3ph? pto? remotes?
/ Leaking seal on 5740 #3
Sorry to hear about any leaking seals on a tractor that new, my 03 L5030 has no leaks and the service records do not indicate any issues with it. Good luck.
/ Leaking seal on 5740 #4
Which seals? The site glass on my L4200 weeps. Sometimes it makes a drip on the ground, but usually not. When I got the tractor, there was 1/4" of goop covering the whole area. I cleaned it using degreaser and a pressure washer. Now, the whole PTO/3pt section of the rear axle first gets shiny, then starts to built up black spooge. Once or twice a year shot with a powerwasher keeps it clean enough not to notice.
Someday I'm gonna change that site glass seal...I really am...
JayC
Right rear axle seal has a band around the whole seal about 1 inch away on each side of the casing/split line. Just a light film but enough to catch your eye and dirt to make it obvious.
2015 International 4300 Elgin Broom Bear Sweeper Truck (A64556)
2015 International...
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
Warren Power Systems WCW84MH 8KW Portable Light Tower (A64194)
Warren Power...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
Approximately 100 Ratchet Tie Downs (A65579)
Approximately 100...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
