Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,070
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Backstory: My wifes cousin next door wanted a tree cut down then the root ball dug up.
The tree was probably under 12" diamater (forget). It was a LIVE tree so though I was concerned as always about falling branches, I presumed there would be fewer of them since it was a good tree (in way at road).
I backed my JCB loader/backhoe up to the side I wanted it to fall away from. I dug down on this side as well as the left/right sides, leaving the far side intact. My reasoning was, the far side intact will help hold the tree from falling backwards (my direction) and I would perhaps be able to loosen it up on the back side and then using the force of the hoe, help push it over.
It worked like a charm, exactly as I had hoped.
This in part, is what has me a little worried (I don't want to conclude that they ALL will be this easy!)
Forward to today.... he's got what I think he said, is a hickory tree in his back yard. The only things near it are some other trees, but they're probably 80/100' away. The canopy will hit them, I see no way around that.
We're looking at trying the same method. Dig on one side and push away, allowing the roots to come up on the side I dig on.
So far, I'm not any more uncomfortable with this idea as I would be using a chainsaw. Actually, I'm MORE comfortable with this idea than using a chain saw. Perhaps that's another error that I should guard against.
Regardless.... I've heard that Hickory's can have HUGE root balls and then I've heard it's all dirt.
I don't remember the diamater of this one, so for conversation let's say it's 12" diamater at chest height. Obviously, if it's larger then the root ball will be larger. It's certainly not 24". 18? possibly.
Do Hickory roots run deep, wide, both? Are they particularly tenacious to the ground, not wanting to come up? Do they have a tap root?
Trying to do my due-dilligence ahead of time to minimize surprises to the best I can.
