Welding on tractor
/ Welding on tractor #1
jake98
Dingmans Ferry PA
53 Cub, 70's JD 410, Kioti 25hst
Any truth to the rumor that it can fry the electronics?
/ Welding on tractor #3
Yes and No! It really depends on the location of the welders ground and electrode. If you can keep them close to the work area you should be all right. It is also safer to disconnect both battery cables from the battery. There are a couple of companies that make an anti zap device that protect the electronics from getting a surge when welding. I have one that MAC Tools sold and it is simple to use.
/ Welding on tractor #4
I spoke with mechanic at my Bobcat dealer. Asked him if he disconnects the battery before welding. (This guy welds a lot). He said never has, never had a known problem. I have welded many things attached to skid steers and tractors and not had an issue. My local welding guy also does a lot or welding on trucks putting in goose neck hitches and does not disconnect the battery. I have come to the conclusion, that my chance of screwing up the battery or terminals is probably greater than a electrical issue caused by welding.
/ Welding on tractor #5
Do disconnect the batt ground before welding on a tractor or veh.
Better to be safe than sorry.
electr do fry in situations.
/ Welding on tractor #6
I have worked for the D.O.T. for 21 years back when I was a truck driver I was the guy that did all the welding in our Crew when the Cert.Welder was off .We always disconnected the batteries when welding or at the least hit the disconnect switch.These trucks have such high tec computers in the cab to control the sanders that it was a precaution we always took.Was there really a good reason ? not sure in our case it was a matter of not voiding the warrenty on the electronics I think. None of us ever wanted to be the guy that fried $ 30,000.00 of electronics. Probaobly no need but someone some where had a reason for it I am sure.
/ Welding on tractor #7
Back in the 70s I worked for a local building supply company. During the Winter months we often had to use jumper cables to get the Mack diesels started. I witnessed what can happen when someone cross connects the batteries. The explosion almost knocked me off my feet and I was a good 20 yards away when they went.
This may not apply in any way to what the OP asked, and you can call me superstitious, but I always disconnect the battery and remove it a good distance from the vehicle if I can't remove the thing to be welded from the vehicle itself. Electricity & hydrogen gas never seem to play nice together.
-Jim
Well, just for the record, the tractor still works.
TSC had these box hitch reducers for under 10 bucks. I used 7018 rod and man, the stuff melts like butter. Had been using 6011 and I'm not sure if that's the whole difference, as I may have not had enough juice last time, but what a pleasure when it works right. :thumbsup:
/ Welding on tractor #10
The theory is, a welder is creating a controlled short, routing a flow of electricity through the steel your working on, which is why you want the ground clamp as close to the work area as possible. Its a fairly closed loop. Now if you go attaching it to your 3pt hitch and try to weld your bucket (gross example) you may very well fry some electronics unless the battery is disconected.
I'm trying to figure how the battery figures into it.
/ Welding on tractor #12
Jake, the negative battery terminal is connected to the tractors frame and so would be the ground clamp of the welder. Any stray current from the welder may pass through the battery and on to the electronics. It would be safest to disconnect both battery terminals and have the welding ground clamp as close to the weld as can be.
/ Welding on tractor #13
Thatsca good question i cant even for sure answer, i am assuming it hasxsomething to do with the fact the electronics acting as an arc themselves do to the fact they are grounded and energized by the battery, and with the welder you are introducing both alternate power and ground... The weakest link may go first... Aka sensitive electronics. I do know this much, everytime i would recieve an automotive exhuast kit for welding or aftermarket car computers it always said in bold print "dissconnect battery before welding". That being said i never really have and never had a problem but then again my ground clamp was at most 18 inches from my work space.
I guess if the key was on you could be introducing some strange spikes into the circuits. It's probably just a precaution to disconnect the battery.
/ Welding on tractor #15
I have personally witnessed a 3500HD computer get fried from the guy welding on it with the battery connected. The boss was pretty ticked when he learned he had to buy a new computer for the truck.
/ Welding on tractor #16
If it were me I would take the time to disconnect the terminals. Maybe even put in a disconnect.These Battery Disconnect Switch
Can be had at walmart for about 4 or 5 bucks..I simply wouldnt take a chance. And also I always like to be able to disconnect a battery in an emergency..(without bolt cutters lol)
/ Welding on tractor #17
i think anything that has fairly modern electronics/computers *could* be at risk for an issue when welding. i use an "anti-zap" that just clamps to the battery terminals like jumper cables. anything old; i just let her have it.......
/ Welding on tractor #18
i've done both with no problems.. though if I remember I do opt to disconnect the bat thus the rest of the electronics.
also to note. don't choose a ground that takes a path thru a bearing, bushing, or ratating pin.. etc..
soundguy
/ Welding on tractor #19
With our CUT's and simple analog electronics, you'll be fine. Just for safety sake, do as others have suggested, keep the ground clamp close to the work area.
With that being said,... IF you are welding on a more modern computer controlled engine, you should be disconnecting the ECM from the wiring harness.
I have seen COUNTLESS fried ECM's and scrambled software from welding... Sometimes the ECM is ok, just have to re-load all the software and set up the configuration again and do all the calibrations.. Other times, I cannot even communicate with the ECM..
Disconnecting the batteries does nothing but protect the batteries. Stray electrical current from a welding arc can get to an ECM just as easy thru a harness ground.... so unplug your ECM when welding....
/ Welding on tractor #20
100% correct. Although, I don't agree about the risk to the ECU, disconnecting the battery will do nothing to protect it, unless you happen to be welding on the battery.
20in Single Cylinder Grapple Bucket Skid Steer Attachment (A61572)
20in Single...
2025 SF60 60in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
2025 SF60 60in...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
John Deere 2155 (A62177)
John Deere 2155...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
