engine Block Heater
/ engine Block Heater #1
hoogy
Member
Chester, Vermont
MF GC2310 HST
I am going to purchase a engine block heater. Are there any tricks i should before i install it. I have a MF GC2300.
Thanks Scott
/ engine Block Heater #3
There it is-- MFRed's link (and my great pics :p) tells all. Any questions?
/ engine Block Heater #4
Hi. This is the inline heater that i have installed on my MF 1140...works like a charm...will melt snow on the hood.
It is installed in the bottom rad hose. You simply cut it and install the heater.
I happened to have a pick on my phone since i was changing the water pump today.
Ordered a new water pump from the Massey dealer...$300 plus shipping...OUCH. The lower rad hose is $50.
Ron
/ engine Block Heater #5
I have a inline lower rad hose heater on my tractor. They are very easy to do. The block heater type are deemed to be the best but can be a real pain to do .I have also installed block heater elements on industrial engines at 1500 watts on 250 HP cummins and VW diesels.
Craig Clayton
/ engine Block Heater #6
Craig Clayton
I know that the MF blockheater for the GC's are made for a real simple and easy install, :thumbsup:. KC :D :D :D
/ engine Block Heater #7
I am not sure if there is room for an inline hose heater on a GC. It is pretty tight in there.
There are lots of nice block heaters on E-Bay in the $35 range. If someone could specify the exact size of the freeze plug, the heater replaces in the GC, and the length of the heating element, perhaps one that will work is out there. If not, now that there are enough GC's out there, maybe they will offer an aftermarket one that is specified for the GC soon.
/ engine Block Heater #8
I wanted one put on my new GC2400. Dealer told me they always go with the magnetic stick on type. He said "no matter what you do, someday it's gonna leak". Made since to me.
/ engine Block Heater #9
I've had block heaters on every vehicle I've owned since 1984 and have never had one leak.
DEWFPO
/ engine Block Heater #10
I have a block heater on my MF 1529. It works great. I have it on a timer wher it heats for 2hrs every morning. Starts up with ease and no more smelly puff of black smoke.:thumbsup:
/ engine Block Heater #11
The M-F block heater I put on my 2310 was expensive but fit perfectly and was pretty easy to install. No leaks, works great to ease starting.
(Shown with a garden hose cap covering the electrical plug.)
  • block heater w: cap.JPG
/ engine Block Heater #12
My answer to that is: find yourself a MF dealer that will perform the work that you request to be done on your tractor, :confused2:. What a lame excuse for a MF dealer to not install a real good MF blockheater product, :eek:. KC :D :D :D
/ engine Block Heater #13
I was right, just tried using magnetic thing. Real POS. Gonna trade it for a real one.
/ engine Block Heater #14
Is that the MF version or another? Looks nice and clean, and I'm guessing would be similar on my 1531.
/ engine Block Heater #15
I have had dealer-installed engine bolock heaters on all of my small Masseys since 1991. I don't know exactly how many, but quite a few. They have all worked great and never had one leak yet. I use a timer to heat the tractor up for about 2 hours when I know I am going to use it. They start like a spring day, and I am sure that it is much easier on the engine.
When I order a new tractor that is part of the deal. The dealer has to install an engine block heater before I take delivery.
George
/ engine Block Heater #16
MF version it is. Dealer installed. Asked for the block heater and 1st 50hr service to seal the deal.
/ engine Block Heater #17
So my MF block heater has arrived. Any advice for installation on a GC? Is it going to make a mess pulling the freeze plug? Do I need to drain or lower a level. Anybody done this themselves?
/ engine Block Heater #18
I have not. But, in the interest of finding a less expensive solution for the other members, could you take accurate measurements, and post them? We will need the diameter, and the amount of projection the element has, (length).
/ engine Block Heater #19
Dang, walked right into that one didn't I.
/ engine Block Heater #20
Drain the cooling system, hit the core plug off center to loosen in and turn it at an angle and then pull it out with a set of pliers. Be careful not to knock it into the water jacket cause it's easy to do.(Don't ask how I know this!) If you do, have magnet handy to fish it out. It took me about 20 minutes to install mine on a Ford 4610 but it depends on the location of the core plug.
Clean the the bore of the core plug hole well and install the freeze plug tightening the bolt. Make sure tht you follow the instructions about the orientation of the element. Plug the cord into the heater and then refil the cooling system and start the tractor and let it warm up with the rad cap off til the thermostat opens and check the coolant level. Check for leaks around the newly installed block heater when you put the cap on and the system pressurizes.
When you're ready to use it, plug it in a couple of hours before you need the tractor or by a timer that will turn it on for you a couple hours before you need it. The instructions usually tell you not to have the heater plugged in with a running engine and you should follow this advice for element longevity. Some folks use remote control electrical switches to turn the heaters on from the house before they use the tractor. I feed our cows everyday ~4:00 pm and my timer goes on at 2:00 pm and the tractor starts on the first rev in the coldest weather we have.
2014 DODGE RAM HEAVY DUTY INSULATED BUCKET TRUCK (A63276)
2014 DODGE RAM...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59914)
2020 KENWORTH T680...
2022 EZ-GO ELITE...
2016 Ford Explorer SUV (A64557)
2016 Ford Explorer...
7" X 7" TOOLBAR W/ EXT. (A64278)
7" X 7" TOOLBAR W/...
2170 (A65055)
2170 (A65055)
