IH3444
Elite Member
- Joined
- Jan 10, 2004
- Messages
- 2,612
It is helping Eddie, but the stove draws air, along with the produced humidity. Some humidity is getting about the room, but a humidifier, inexpensive one from walmart, or such store will make a greater effect. Placing a humidifier also in the bedroom where you sleep will help keep your nose, and air passages from drying out while you sleep. This will inturn allow you to get a good nights rest, and not awake with a dry throat, or worst a symptomatic sore throat. You think you have a sore throat upon arising , but as the day progresses, the symptoms disapate, and go away. This was due to your air passages being dried out overnight. A bit alarming, because no one wants to be sick with a sore throat, or feel that they are comming down with a cold, or the flu. It's winter, so the air is usually drier that summer. Can you throttle your wood stove back? I've found that with mine once the chill is knocked off, that I can run it much lower, thereby reducing the amount of air being dried, and drawn from the outside, which is usually drier still. Sorry to be instructing you how to spend your money on a health related issue. I should leave that up to Obamacare.....
I also love the pictures of your piggy, and truly enjoy reading about him.
