770 just quit
/ 770 just quit #1
4Kings
NE Missouri
BX1800 & Deere 770
Hoping somone might point me in the right direction with my 770. Was plowing snow Wednesday when the the tractor just shutdown. I found that the negative battery cable had come loose. I reconnected the cable but now the tractor wont start. It will crank but it's acting like it's not getting fuel. Anyone have any tips or suggestions
/ 770 just quit #2
If you were at the Negative why not also check the Positive because you never know. Also did you bump any other wiring in that area. Do you have a bleed screw on the fuel system?
Craig Clayton
/ 770 just quit #3
Do you have a procedure to check if it is getting fuel? That would be a first step. Drain the water off the filter bowl and consider changing the fuel filter.
What is the status of the diesel fuel? Fresh? Stale?
Need some more info from your end. :)
/ 770 just quit
Fuel is fresh and treated.
I haven't had time to really look at it. I'm going to call my neighbor and see if he can come up with his 4400 and push me into my garage tonight so I can really look at it.
I did check both cables, the tractor will crank, just not fire
/ 770 just quit
What;s the procedure for bleeding the fuel line
/ 770 just quit #6
Based on your location do you or have you used the machine in these lower temperatures. The suggestions by ( been there ) are the next step because you fixed the loose connection problem.
Craig Clayton
/ 770 just quit #7
Try jumping it from another battery. Your starter may not be turning fast enough.
/ 770 just quit #8
My 770 seem susceptable to fuel gelling. If you have a questionable fuel filter and non-treated fuel, my bet is that. In fact it may have stalled due to fuel starvation. The loose ground might be just a lucky find.
Getting it into a nice warm garage is a good idea. Warm it up overnight, charge the battery, Drain any water accumulation and clean out the fuel filter housing, change the fuel filter, top it off with fuel and some additive (Howes, Power Service, Stanadyne, etc.) and I bet it'll be fine.
/ 770 just quit #9
Sorry to hear that.
Looks like some good advice right here. Let us know what you find.
I know on the 770 you can run them out of fuel and they are self bleeding, though there is a shut off valve to be used when checking the fuel filter. I am near certain that is what I read in the manual.
Haven't had to do this but I dread the day I do. Well, let's hope not.
/ 770 just quit #11
The filter should have a screw to loosen to check for air or fuel. The 770 has a mechanical lift pump to pump fuel from tank to inj pump so that rules out electrical problem to get fuel to inj pump if fuel filter isn't plugged. Does inj pump fuel solenoid "click" when key is turned to ignition? If IP solenoid clicks,loosen injector lines at injectors and crank engine over and see if fuel squirts out.
/ 770 just quit #12
2nd what Roy says. The state of the battery plus a loose connection, the age of the battery easily forgot. Try jumping it and test the battery..... If it will not fire just after being ran doubt its fuel, unless it ran out of fuel too....:eek:
/ 770 just quit #13
May I ask how long does it take for diesel fuel to get stale?
Jim
Good catch. Prolly not a good question from me. :)
I don't know how long, but hear that over time it could. Just something else for the OP to ponder and to rule out as a possible problem.
/ 770 just quit #14
Jim
I personally have never seen diesel get stale,contaminated with water & foreign matter, YES
/ 770 just quit #15
4Kings stated "It will crank but it's acting like it's not getting fuel".So how can it be battery or connection related????
/ 770 just quit #16
We're not there, of course, but "cranking" doesn't mean cranking fast enough. I've had this problem which is why I always suggest jumping the battery first (least intrusive option).
BTW, jumping the battery will help if it's a battery problem, not if the cables or connections are bad.
Still could be fuel related (the sudden shutdown during operation kind of indicates that) or a blockage in the lines (ice?). I don't know what the average winter temperatures are in NE Mssouri, but a lot of areas are getting lower temperatures then normal. As this appears to be an atypical winter, the fuel sold there may not be winterized. That's strictly a guess on my part.
/ 770 just quit #17
The best way to deal with this is for you to first check the fuel and make sure there is no water In it then you should check the fuel filter and make make sure it's not clogged then you should change it and see if fuel flows through it if it does not check in you gas tank for any clogs at the begging of the main line but if fuel is flowing through it choke the machine all the way and let her try to start for 2 mins if it still does not start check the or just replace the spark plugs and if that that does not work check the carborater and see if it might br gunk or if a screw broke on any of the hooks on it but if it's a diesel check or replace the glow plugs then check the injectors. If you don't under stand or require more help please send me a private message or email me.
/ 770 just quit #19
The 770 is a diesel and it has an intake air heater, not glow plugs. If the simple suggestions made on TBN don't work and 4Kings doesn't have the skills, it probably time to let a dealer mech work on it.
As a real quick example, my 790 was left out for a day or two and then wouldn't start. Headlamps were bright.
It would crank, but that drew the battery down pretty quick. I jumped it from a known good battery which got the starter turning fast enough. So, time for a new battery. Cranked fine, but didn't start.
Well, now it seemed like a fuel problem so I went through what most posters here suggested. This transpired over a week or so. No help...still didn't start.
Well, I figured it was one of two things...either jumped timing or an electrical problem. Since I'm an "OK" mechanic (at best) and definitely not good at electrical problems, it was time for the dealer to check it out.
Few days later, I got the diagnosis. It was a bad terminal on the wiring harness. Of course, Deere doesn't sell that terminal as a separate piece, so I'm looking at a $600 wiring harness plus labor. Fortunately, my dealer is a good guy with a good service dept. They found a similar terminal and installed that. Tractor worked fine since.
Some problems are easily found...the thermistor problem on the older 4xxx series Deeres is a good example. It's also an easy, cheap fix.
Other problems, like 4Kings is experiencing, aren't so easy and making a wrong diagnosis can result in more problems then it fixes.
/ 770 just quit #20
Check any safety switches, the fuses, and relays, And if it has a fuel solenoid ensure it is working.:)
2007 Freightliner Columbia 120 S/A Day Cab Truck Tractor (A61568)
2007 Freightliner...
FUEL CELL (A58214)
FUEL CELL (A58214)
New/Unused SD Lanch SDLD25 Mini Crawler Dump (A61166)
New/Unused SD...
2023 JOHN DEERE 317G SKID STEER (A62129)
2023 JOHN DEERE...
2014 Freightliner M2 106 T/A Terex Commander C6060 60ft Digger Derrick Truck (A60352)
2014 Freightliner...
2025 SDLanch SDLE20 Diesel Mini Excavator (A60352)
2025 SDLanch...
