Snow Equipment Owning/Operating Cutting / Groving / Siping R-4 for snow
   / Cutting / Groving / Siping R-4 for snow #51
Sweet thanks.
I'm planning on using the #5 on the rears and then take like a #3, or possibly #2 and groove the fronts the opposite way as the rears. The fronts are like "rudders" in snow, they only work to guide you as you go faster in deep powder. I usually don't even use the steering wheel in the snow, rather the rear brakes control my direction. The front R4's are pathetic when you actually try to "Work" them in snow.
Thanks for all the info.
Post some more pics if you do the fronts! :thumbsup:
Just did the fronts! Wanted to keep the look similar to the rear for a matching set. Plus, since the bars turn at nearly a 45 degree angle my grooves go in 3 different directions. I'll try it like this first. If it's still sliding sideways I may cut the bars into 2 or 3 individual blocks. My objective is both better forward and sideways traction.
My fronts are much more worn than I realized. they have only 1/4" of tread in spots. So I set the groover to just under 1/4". There is one lug that actually already had a small chunk out of it. I have 420 hrs now and probably wont make it much past 500 hrs before I'll want new tires.
Here are some pics! They kind of remind me of a modern snow blower tire now. Hopefully they work like one! ;)
   / Cutting / Groving / Siping R-4 for snow #53
Traction aside... I love the look of it :thumbsup:
I'm with ya teg! Makes me wish I could start over on the rears! :laughing: I'd match the fronts but with two grooves side by side since there is so much more rubber to work with out back. But I'll have to wait for the rears wear down 3/8" to be at my start over point.
Plowed a drive today with about 16" of wet settled snow that had been driven over and packed down in spots. Would sometimes push 100 feet before stacking. My traction is good enough now that when pushing into a pile with snow under the tires, it's a crap shoot as to if I'll spin out or stall the engine. This is while using a gear that gives 3mph at rated engine speed. That's decent traction in snow! :thumbsup:
I still cannot break through that heavy deep snow with the blade angled because it pushes the front of the tractor too much. I need to push strait to break a path and then widen it with the blade angled. I have my blade hanging off my bucket which puts it too far out making it easier for the blade to push the front tires sideways. I'm thinking about a different mounting arangement.
Just a quick update on how the grooved R-4s are working out...
I live in southeast PA. Our ice storm left about an inch of solid ice on the drive. It's about a 5% grade from the house down to the road. Unless your shoes had rubber that likes ice, you couldn't stand on it.
knowing from experience that my stock R-4's were worthless on ice, I did a test with 4 vehicles to compare tires and assess the grooved R-4's ice traction. The test was to drive down the grade towards the road at about 2-3 mph. Try to stop mid way (on the 5% grade) and then if successful try to back up the hill (total grade ~50 feet long).
Vehicles / tires / Drive system
Maxima / newish all season radials / front wheel drive
Minivan / new Hankook snow tires / front wheel drive
F250 / Cooper AT 50% tread / rear wheel drive and 4 wheel drive, limited slip rear
Tractor / Custom cut R-4's / rear wheel drive and 4 wheel drive
Results
Maxima - could not stop, slid to road
Minivan - stopped in ~2 feet, could not back up but did not slide down drive when trying
F250 in 2WD - stopped in ~5 feet, slid the rest of the way down drive when trying to back up.
F250 in 4WD - stopped in ~ 5 feet, backed up the drive with some wheel spin
Tractor in 2WD - stopped in ~10 feet (Brakes only on rears), could not back up but did not slide down drive when trying.
Tractor in 4WD - Stopped in ~2 feet (no wheel slide, could have hit brakes harder), backed up drive with almost no wheel spin.
I was surprised by several things. I didn't think the Cooper AT's would be much different than the all season on the car in ice. But that was not the case at all. They smoked the newer All terrains on the maxima.
I was surprised that in my best assessment, the grooved R-4's seem as good as the Hankook snow tires on ice. I thought the snow tires would smoke the groved R-4's. I'm wondering if the R-4's wont stay so good when the currently sharp edges of the grooves round a bit. time will tell (I can always recut)
I used the tooth bar to rip up the ice (gravel drive) and did not spin much at all even pushing hard enough to see my FEL flex. The tires were primarily on chipped ice and I made sure I was on flat ground or going down hill when ripping it up.
While I am sure that a set of V-bar chains in the rear would have been even better. I certainly didn't need any more traction. Considering what my V-bar chains do to my garage floor, I see no need for them in anything I've encountered this year (ranged from 16 inches of snow with several hour of rain in the middle of the storm [i.e. very heavy] to this ice storm). This winter has been a good test.
No new chunking on any of the lugs so far (did have one small piece chunked out on the front before I grooved the tires)
Very, very pleased with this mod :D
   / Cutting / Groving / Siping R-4 for snow #57
Please continue to give updates, later during the spring and summer, with Mud, etc.. I am very interested, in this project. You did such a beautiful job, but I am afraid I could not make it look that pretty. Now you did this freehand? No guides or anything?.. I wish I lived nearby to bring my tractor over:)
Thanks for taking the time to document and photograph.
James K0UA
   / Cutting / Groving / Siping R-4 for snow #58
I have loaded R4's with V-bar chains on the rear. No problem with traction.
Front slide/traction is my only problem.
I ordered and received my Ideal Heated Knife. I was ready to do my front R4's I have on the shelf and then looked at the new turfs I currently have on the tractor. The turfs that I have look like a very aggressive winter tread pattern.
Do you think grooving my R4's would give better traction than an aggressive turf?
   / Cutting / Groving / Siping R-4 for snow #59
So you have a set of chains for sale yet?? :laughing: Went to the farm show looking for a tire groover, came up empty handed!
What do the vehicles weigh? Might make a difference...
James K0UA
Yes free hand. It's not hard. You could probably do better than you think;)
2017 HITACHI ZX350LC EXCAVATOR (A54607)
2017 HITACHI...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2013 PETERBILT 367 (A55745)
2013 PETERBILT 367...
Advance SC750 28in Floor Scrubber (A53421)
Advance SC750 28in...
2025 GIYI SGB20 20in Single Cylinder Stump Grapple Bucket Skid Steer Attachment (A53421)
2025 GIYI SGB20...
2013 Jeep Grand Cherokee Laredo SUV (A55853)
2013 Jeep Grand...
