Polaris Ranger Five Cent Ebrake Fix
/ Polaris Ranger Five Cent Ebrake Fix #1
mars1952
Western North Carolina
1999 John Deere 4300 12/12 sync-reverse
Hi Folks:
My E-Brake was completely shot with no more room for adjustment. I figured out a way to add one fender washer to the brake lever assembly to get one more adjustment out of the worn out brake pads.
I posted a video on YouTube:
The Mars1952 Polaris Ranger Five Cent Ebrake Fix
Good Luck, Mars
/ Polaris Ranger Five Cent Ebrake Fix #2
Thanks Mars...good video. I have a 2010 800XP with just a few hours on it but I will now know where to go when the e-brake beyond adjustment...TMR
There must not be very many Polaris owners on TractorByNet.
Mars
/ Polaris Ranger Five Cent Ebrake Fix #4
Mars, great video. I had a Ranger but sold it and though super nice, it was already have e-brake issues. You must live close to me based on your demographics.
John M
/ Polaris Ranger Five Cent Ebrake Fix #5
Mars
I'm sure there are a lot of Polaris owners. Maybe not too many ranger owners. I have a Sportsman 550EFI but not a ranger.
/ Polaris Ranger Five Cent Ebrake Fix #6
I've watched several of your videos and think they are just great. Not a ranger owner but your ingenuity is great to see. Food for thought.
Thanks :thumbsup:
/ Polaris Ranger Five Cent Ebrake Fix #7
Have a couple of Polaris's here in sunny AZ. However not a ranger as yet... Who knows perhaps the next toy.
Great video
/ Polaris Ranger Five Cent Ebrake Fix #8
Sorry, my Polaris RZR S has no Ebrake, it is a park position on the shifter. The parking brake fixes are either a rod with a lock pushing on the brake pedal or a hydraulic line lock.
David Kb7uns
/ Polaris Ranger Five Cent Ebrake Fix #10
I don't have a Ranger but I did notice that is one of the best home videos I've ever seen. Very detailed and we didn't have to take a roller coaster ride while viewing.
Is there any chance the Ranger can be operated with the brake set unknowingly ( not set tight enough ) or is there an indicator light etc?
In the 1950s and earlier 2-1/2 etc. ton farm trucks had a hand brake with a band on a drive line drum. If it wasn't maintained well or set tight enough when parking, it would often be just hot enough to set a wheat field on fire about the time the county road was reached. Not a good thing.
Also while watching I couldn't help but wonder if one couldn't make his own pads from a better material and epoxy them to the plate. I use old automotive pads to make them for my lawn tractor but no epoxy involved there. And I have shimmed them with a thin piece of wood to get a few more miles.:D
Hi SandburRanch: Thanks for the compliment.
I read a post on another forum where the author had purchased a set of riveted automotive brake pads. He drilled out the rivets and re-riveted them to the Ranger plates after grinding them to the correct shape. He claimed they worked well but he had to use longer brake assembly parts since the pads were thicker than the OEM pads.
Mars
/ Polaris Ranger Five Cent Ebrake Fix #12
I watched the video and I realized that the parking brake mechanism looks very similar (perhaps identical) to the mechanism on my XUV. I recently had to replace the pads which wouldn't hold reliably - especially when in low range or with the rear differential locked. These pads have very thin brake pad material on them, even when new. The plastic shield over my parking brake rotor somehow melted and I think it contaminated the brake pads because even though the new pads were pretty close to the same thickness as the originals, they work while the originals did not. They were contaminated with black, perhaps plastic?
Anyway, since it is a parking brake, and there isn't any significant rotation involved (just binding while stopped) they really shouldn't require much pad thickness because they shouldn't wear. Unless you forget to take off the parking brake and drive with it engaged. I suspect the pad material selected is for best cold binding, rather than longevity like most brake pads for stopping the vehicle.
Hi 2fast2: Is that a Gator XUV?
Mars
/ Polaris Ranger Five Cent Ebrake Fix #14
Yes, 2008 Gator XUV 850D.
/ Polaris Ranger Five Cent Ebrake Fix #15
Mars
theres one more than before,
thanks for the posting, done the same on ours. pretty good video linked and a relatively easy procedure.
nice to not have the ATV take off down the lane when opening the gates now.
dunno if ours were original but they had a decent amount of meat on them.
the 2013 ranger crew beeps like crazy and the dash brake symbol flashes if the brake is on even a single click. which definitely encourages you to release it.
Unused 2023 Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
Unused 2023 Del...
2016 JOHN DEER 1600 TURBO SERIES II (A66091)
2016 JOHN DEER...
1995 CHEVROLET KODIAK C7500(INOPERABLE) (A67714)
1995 CHEVROLET...
2012 Ford F-450 4x4 Altec Bucket Truck (A66736)
2012 Ford F-450...
PORTA POTTY (A67714)
More info coming soon. (A64557)
More info coming...
