Front mount mower suggestions?
/ Front mount mower suggestions? #1
esmith
Central Iowa
Hi everyone, will try to be clear and concise here. Needing to decide on a mower before spring arrives, and soon enough to allow time to search for a good used/new example to buy.
I have about 5 acres to mow, with plenty of buildings and trees to get around. Want a smooth ride, and I want to spend as little time as possible in the driver's seat of a mower (within reason). I like the maneuverability of the mid-mount mowers, and the speed, but the design just looks like a rough ride compared to front mount mowers. Plus I think the front mounted deck is easier to see, sneak under trees/bushes, etc.
Here are some of the factors in my decision:
1. I have about $8000-9000 to put toward a mower that meets as many of my criteria as possible.
2. I have John Deere, Grasshopper, Kubota, Toro and Walker dealers within reasonable driving distance. (The only dealer relationship we have is John Deere, as that is our Ag equipment choice.)
3. I like Diesel power for several reasons, so will be limiting my search to Diesel engines.
4. I won't be transporting the mower anywhere, so size isn't a concern as long as it doesn't take away from the mower's productivity.
What recent year model should I be looking at? We as a family aren't the most prompt on mowing always, so definitely need something with the power to handle tall, wet grass on occasion, and still do it at some speed. Thanks for the suggestions. Not a mower expert, by any stretch!
/ Front mount mower suggestions? #2
I went from a mid mount unit (Cub cadet M60 Tank) to a Snapper pro S800X front mount mower. I always thought that I would like the front mount and have to admit the ride is far better and the mowing quality is great as well. Just one issue to be aware of is terrain. They work great on flat ground and objects are not an issue as they manuver well. My issue was some slight ditches. I really like the Snapper but am looking to go back to a mid-mount. If your looking for a low hour front mount I can fix you up!
/ Front mount mower suggestions? #3
(1), (3) Unfortunately, this puts you buying used in any of the top models w/ diesel as I'm pretty sure they are in the 20k + ballpark new - maybe not Grasshopper.
(2) I personally would not consider the Walker if I had 5 acres to mow. It's a great machine, just not what I would want for that much property - unless you really want a manicured look.
Compare the JD 1400 series, Kubota F series, and Toro Groundsmaster 328D - see which you prefer and which you can get the better deal on. In this class, I'd say all are good. I cannot comment on the Grasshopper, it may be the best - I'm just not familiar with them.
I see. Yes I fully expect to buy used due to the price limit, I forgot to mention that. Good to know on the Walkers. I had seen where most of them only do about 5 mph, where most others do upwards of 8-10 mph. The cut quality of most any mower is fine, this is a farm acreage, not somebody trying to win a lawn contest. :)
I'll get to comparing the 3 you mention. I hate talking with salesman, so nice to know I can look at those 3 models and know where I fall price-wise. Hard to find prices online, but then again I don't know where to look for good online market places for mowers.
Thanks for the info so far guys, keep it coming!
/ Front mount mower suggestions? #5
I bought a front mount Grasshopper w/28hp diesel [928d] on CL .the deck is 61".I paid $5,000.00 for it.The engine is Kubota.I have zero problems mowing my ditches with it and mow about 3acres.I used to mow with my Yanmar tractor w/finish mower and have cut the time in half with the Grasshopper.
I can get any part I need from my dealer and because they make them here in Kansas my dealer can have the part in the next day if he has to order it.Check C.L. ,I've seen others that are good buys.I also looked and test ran the mower before I bought it. russ
/ Front mount mower suggestions? #6
Check out the link below for used John Deere and other brands at John Deere dealers - just fill in the blanks to narrow the search. Also might try Tractorhouse.com.
Used Golf, Lawn & Turf Equipment - John Deere MachineFinder
