Smallest tractor with a cab
/ Smallest tractor with a cab #1
bowhunter3030
Collinsville, IL.
Kubota Grand L4060hstc & Kubota B2601
What is the smallest tractor with a cab with heat and ac on the market?
/ Smallest tractor with a cab #2
We have a Deere 2305 at work for plowing and salting sidewalks. Its an 18HP diesel 4x4 with factory hard cab and heat. Its pretty small. Don't think it has A/C though.
I have a Mahindra 2615 HST 4x4 that I just put a soft cab on. Aftermarket heat, no A/C.
I'm sure most companies can outfit a small (18-22HP) tractor with a cab and heat. A/C may be a tough call for a small tractor. You usually see that in large tractors.
/ Smallest tractor with a cab #5
to me they are talking bout a factory cab.
/ Smallest tractor with a cab #6
Kubota B3030 is the smallest tractor available from the factory with heat and air. There are some aftermarket units available but after you install them at a higher price you might find another shortage such as charging systems or cooling system problems.
/ Smallest tractor with a cab #8
I believe tha the Kubota B3030 HSTC has heat and ac.
DevilDog
That would be the HSDC. The cold weather version is the HSDCC, which includes rear wiper/defogger. Heater and air conditioner will both drive you out of the cab if you crank 'em.
Not sure about other brands but when I purchased it was the smallest Kubota with a factory cab.
I ditched an open station JD 790 for this tractor and never looked back.
I believe that Deere's smallest tractor with factory cab is the 3320. I checked into those also, but I seem to recall them being quite a bit more $$ than the Kubota. I don't recall the exact figures, but I'm thinking the JD was around $4,000 to $4500 more than what I paid for the Kubota.
/ Smallest tractor with a cab #9
ok....i have just been out there trying to find the same thing. i ended up with the kioti dh45 se hst....but it wasn't the smallest cab tractor, just the best equipped for the dollar that i could find. Kubota had the SMALLEST with FACTORY CAB HEAT AND AIR....but it was one of the most expensive. There are alot of makes out there that had smaller cab tractors, but had heat only. I wish that there were more makes in the 30-35 HP range with factory cab and air, but maybe there wouldn't be enough HP to do anything with after you take into account the HST, Power steering and a/c,,,,not sure. What really erked me was the fact that every brand needed EXTRAS....cept the Kioti. None of the other cabs included rear lights, rear wipers , rear hydraulic ports or a radio. they added A LOT (TYM did offer 1 rear port...my mistake). Kioti included ALL these in the price plus $450 for additional rear port. If it was only a few dollars difference i wouldn't of minded, but i saved over $10,000 over what John Deere bid me, and over $7,000 what Kubota offered me. I was kinda skeptical about the Kioti brand, but after doing about 1 months of online research, i really haven't found ANYTHING really bad about peoples experiences with the Kioti brand. Sure, some will say....how about service work, and parts. well my local sales company has been selling them for 5 years, and a second dealer has opened even closer. And besides, i can fix nearly anything in a pinch...been doing that out here for 16 years.
/ Smallest tractor with a cab #10
JD 2305 is a 24HP diesel 4X4, 18 PTO HP. There is NO factory cab available for it
/ Smallest tractor with a cab #11
I'll double check the one at work on Monday. It definitely came with a cab. That was a requirement when the higher ups ordered it. If Deere doesn't offer one then the dealer put an aftermarket one on before we got it. I'll look at the cab Monday to see who makes it and I'll take a picture of and post on Monday.
/ Smallest tractor with a cab #12
Deere makes a hard cab for the x700 series. Not sure what options you have for AC\Heat.
I love my 4720 Cab tractor!!
/ Smallest tractor with a cab #13
Certainly not as small as the Kubota B3030 but the Kioti DK35SE can be had with a factory cab with heat and a/c. It's also a LOT more tractor!
Kioti DK35SE
38 hp / 27 PTO
3 speed HST or 12-speed sync
4,133 lbs with cab
61.6" wide x 129.1" long x 95.3" tall (with cab)
loader capacity 1,412 lbs to 102.4"
backhoe capacity 3,748 lbs digging force to 94.4"
/ Smallest tractor with a cab #14
I have just searched the Deere web site, I have not found a cab available for the X700 series tractors. If there is one, they have it so hidden on their site that I could not find it. The smallest tractor available with a factory cab according to Deere is the 3320. There are no factory cabs for the 2000 series tractors. I have a 2305 and just put on a Curtis cab this year since I also put on a front mount 54" snow blower. If there had been a Deere cab, I would have gone that route instead although I am very pleased with the Curtis.
/ Smallest tractor with a cab #17
B3030HSDC........................................
/ Smallest tractor with a cab #19
Ducttape...you should have placed the dog a little closer to the camera...made the tractor look really tiny :)...also, how does the backhoe work with the enclosed cab....is it hard to move around???? i would think the cab would make it difficult to maneuver. i usually rent an excavator for the times i need trenching....so nice and fast
/ Smallest tractor with a cab #20
Check out the new Mahindra 3616 cab. It will blow the doors off the Kubota!
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
JOHN DEERE MX6 ROTARY MOWER, 3PT (A63291)
JOHN DEERE MX6...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2013 BMW X28I AWD SUV (A61574)
2013 BMW X28I AWD...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
2017 Ford Transit 250 Cargo Van (A61573)
2017 Ford Transit...
