hydraulic tee
/ hydraulic tee #1
mroldstyle
cataract wi
2003 New Holland tc 29d
I'm running line from my rear remote forward to fel/garpple, what I would like to do is take the QC off the rear remote and insert a tee, allowing me to replace QC on one leg and hoses going forward to grapple onto the side leg of tee. This way I would still have the QC available for use out the back. I realize I would need to disconect the grapple to get flow to the rear, but figure it would be easier to dc at the bucket than behind the tractor. Does this sound reasonable? Also would I need a hydraulic specific tee, or could I get away with using black pipe or galvanized. TSC doesn't have hydraulic tees, so I would need to get it online.
Thanks.
/ hydraulic tee #2
Only use fittings specified for hydraulics. Black pipe and Galvanized pipe is not acceptable.
/ hydraulic tee #4
I'll third the motion........... gangreen does NOT look good on you. Don't use pipe designed for 150 PSI in a 2500 PSI hydraulic system.
/ hydraulic tee
Please post the part numbers you ordered. Thanks
2 of : 1501-08-06 | 90ー Elbow, 1/2" NPTF Male x 3/8" NPSM Swivel (Steel)
$5.50 Processing
8 of : 5406-08-06 | Hex Bushing, 1/2" NPTF Male x 3/8" NPTF Female (Steel)
$7.12 Processing
2 of : 5602-08-08-08 | Street Tee, 1/2" NPTF Male x 1/2" NPTF Female x 1/2" NPTF Female (Steel)
$9.20 Processing
46192SFL (A64557)
46192SFL (A64557)
TAYLOR S/A LOOSE LEAF TRAILER (A64278)
TAYLOR S/A LOOSE...
2025 Rippa IREAS Ripper Mini Excavator Attachment (A64553)
2025 Rippa IREAS...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
2016 BOMAG BW145D-5 SMOOTH DRUM ROLLER (A65053)
2016 BOMAG...
1994 Trailmaster Aluminum T/A 407 Chemical Tanker Trailer (A64194)
1994 Trailmaster...
