Tire chains from Costco for less than $130
   / Tire chains from Costco for less than $130 #1
Brant
PA
TC 29D
I bought a set of tire chains from Costco online. See here. With shipping and tax they were less than $130. They fit my 11.2 x 24 rear tires quite well and are actually a little longer than required. They are made for heavy trucks like semis and such and I got the largest size. The cross chains are square 5.5-mm manganese alloy. Cam tensioners are included. Overall I'm pleased with the quality and you can't beat the price.
I tried them out in a recent snow and they work pretty well. There are some problems with the chains falling in the lugs but they definitely help with traction and stability. I run 2-link ladders on the front too. I run my chains pretty loose without tensioners and apply the rule of being able to get a fist between the side chains and tire. I think this is by far the best way to go with low-speed tractor chains on ag tires. All the banjo-string-tight tensioning that people do is pretty silly IMHO.
Anyway, I thought I'd share my tire chain solution for less than half the cost of most anything I've seen.
   / Tire chains from Costco for less than $130 #2
I run double rings and keep them as tight as possible. There's not a lot of clearance between the tire and the fender.
   / Tire chains from Costco for less than $130 #3
Yup I'm one of those chains snug as possible types also. Just don't like things loose and sloppy, not sure if the traction is any better or worse but it's not hard to do and some of these modern machines have sensitive components not far from the minimal clearance inside/near those fenders.
Anyway that's a good deal for the chains at Costco, just not sure about those rears with the link parallel to the rotation? I know any chain is gonna be a big help but that doesn't seem like the max traction. Maybe that makes for a smoother ride?
I have 2 links on the fronts and 4 links on the rear, 4's on the rear are way to bumpy, I've got to splice in more cross links to smooth it out, I think I have enough surplus chain around to do it.
JB
   / Tire chains from Costco for less than $130 #4
...They fit my 11.2 x 24 rear tires quite well...
So you bought the "DB2151" set for your tractor? Can anyone tell me if these would fit 15-19.5 (R4 tires for an L2800)
Or what would be close to the large truck tires on the CostCo chart (at the very bottom of the third page) here: http://www.costco.com/Images/Content/Misc/PDF/11177090_APP.pdf
edit: I see that I don't have enough information "indeterminate height" without the third number :mad: and I have no idea when I'll get to my tractor :( so I can measure (still not sure that would help figuring out what set would work).
So do I take a chance, and just plan to modify a set?
   / Tire chains from Costco for less than $130 #5
I had a tough time trying to figure what size I needed, I was lucky since I had a chance to pick through a bunch of surplus chain and just using hand measurements, found the closest one.
Still had to mod some anyway.
JB.
Yes, I did buy the DB2151 size. I suspect that most R4 tires, including yours, will be too wide for the chains. Truck and R1 tires have more similar profile. I took a bit of a chance too after doing some calculations with the size chart. I figured I could always return the chains to the local Costco for a refund. Best of luck.
   / Tire chains from Costco for less than $130 #7
...I figured I could always return the chains to the local Costco for a refund...
I didn't think about that... thanks. I'll look into it a little more...
   / Tire chains from Costco for less than $130 #9
Interesting...Never thought about getting tractor stuff at Costco...:rolleyes:
   / Tire chains from Costco for less than $130 #10
Probably made in China...cheap steel.
If anybody doesn't like the fact that I got them at Costco for a good price, they can also buy them from Amazon.com for $200. Would that feel better?
   / Tire chains from Costco for less than $130 #13
Hence the cheap price.
OTOH, if there is any place that cheap steel would do just as good a job as expensive steel, it's in tire chains.
JayC
   / Tire chains from Costco for less than $130 #14
Cheaper is better........ especially when they both seem to be Security Chain Company chains i.e. SCC.
   / Tire chains from Costco for less than $130 #15
JayC
Not for extended wear. Doubt you'd see years of service with chinese chains.
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
