roof ice/snow
/ roof ice/snow #1
Dutch445
Elite Member
Upstate NY
JD X585
here is a question I posted in another thread, and I'm wondering
what folks around here might think also.
I get ice dams on my 70s vintage ranch house, south side, above our "living room". I usually have
to chop the ice off once a year or so to prevent interior leaks.
the living room is 26' long, and it is the warmest room in the house because i have
a floor vent coming up from the basement with heat from the stove.
the attic has ridge vent, and vented eaves (2 inch strip along the eave the entire length in the soffit)
I still get a large build up of ice , and it's concentrated over the part of the room with an 8' sliding glass door.
As i research the fixes, vent - vent- vent. Eliminate heat loss, insulate-insulate-insulate. I came
up with another possible cause and wanted to see if anybody else thinks it could be a problem.
The masonry dual flu chimney runs up thru interior walls at the end of the living room (which has
a cathedral type cieling). The chimney then continues thru the attic, before it
goes up thru the roof. My thoughts are can this "warm" chimney in the attic space be contributing
to my snow melt/ice problem on the roof? I have no inside access to the attic, but I can probably remove
a gable vent to peek in there (never have). I would imagine the chimney is warm all the way up, at least
to above the roof line. (unlike when the boiler is running occasionally in spring and fall).
Am i chasing a ghost here? or would it make sense to maybe insulate around that chimney so the heat
doesn't end up in the attic melting the snow on the roof? or just more vents?
/ roof ice/snow #2
The problem is the inside of the roof is warmer than the outside of the roof. This causes the snow to melt.
The water runs downhill and freezes again when it gets to the cold part of the roof over the eaves.
Then ice backs up under your shingles and leaks in through the roof decking, usually right above the exterior wall.
Even though the eaves is vented underneath, it is not vented through the blocking between the rafters. There is no air circulation under the roof deck right in the corner where the rafters meet the joists. If there is insulation stuffed in there, it is even worse.
The solution is to make sure there are vents in the blocking between the rafters and then use a product called rafter vents to keep an open air path from the eaves to the peak of the roof, so that the underside of the roof deck stays the same as the outside air temperatures.
Do a google search for rafter baffle vents and start reading.
Here's a link to pictures of them.
rafter vent baffles - Google Search
/ roof ice/snow #3
I think your over thinking this, the best prevention is just remove the fresh snow from the edge of the roof before it has a chance to freeze. Very easy to do on a ranch house, just have to go back 2-3 feet.
You will always have some loss of heat and since you mentioned south side that means it has something to do with sun shine, both the damming and the melting above.
On masonry buildings the freeze thaw damage is often worse on the south side for that same reason.
Here in CT we have that problem less often, but every few years, like this one, conditions are ripe and my phone starts ringing (contractor) with people requesting snow removed from roof.
Did one yesterday, 3 foot drifts in the valleys.
Was LOL yesterday cause my wallet was getting so fat it was hard to close and sit on.
JB.
/ roof ice/snow #4
I would say you are both correct with what you say. Also come summer time, pull up the first 3-4' of shingles. Put down ice barrier (it's 3' wide) on the roof deck (right on the plywood) and up under the felt at the top of it. Re shingle it. The ice barrier seals around the nails and does a good job of keeping water out. If you have a problem up higher than the 3' put down 2 rows of the ice barrier. On low sloping roofs, I have done the whole roof deck with it and shingled over and have never had a problem since using it.
Good Luck
Clayton, General Contractor for 42 years
/ roof ice/snow
monday nite i did pull what snow i could reach with my
rake, i got up about 8-10', but it's snowing again today.
i'll have to try to check for the space above the soffit
vent and see if there is a restriction going up into the
attic space.
thanks
/ roof ice/snow #6
I found an extremely easy fix for this recurring problem, move to a warm climate. Why do you guys live in these places? If you like the beauty of snow buy a plane ticket for $69 bucks and visit.
/ roof ice/snow
don't tempt me!
:D
(2 years ago i went to cabo in Feb, for a week,
and it was cold there, 70. not too hard to take)
/ roof ice/snow #8
There are permanent installation Heat tape systems that are made for icing roof problems. More attic venting or better ceiling insulation will also help.:)
/ roof ice/snow #9
Good Luck
That's the best solution, the rubber membrane, buts it's so invassive I usually only recomend people do it at the time of reroof.
JB.
/ roof ice/snow #10
Look under (This Old House ) they have in the video sections very good information as how to help with the problem. When I watch the show and Tom Desilva takes the roof off and the first place he looks is the eves and he finds ice damming damage. When it is rotten then the sheathing must be changed. Do the research and you will know what you are doing this summer.
Craig Clayton
/ roof ice/snow #11
I am in Quebec and with cathedral ceilings this is a common problem.
For the venting to take place 3 conditions must be met.
-Sufficient space for the air to move out. 2" minimum, 4 suggested.
-Sufficient inlet air space. continous soffit venting best.
-Good outlet venting. the Maximum (brand) I consider the best.
Look at your roof ridge and I bet your little 2" high ridge vent is burried in snow and therefor the heat is trapped, snow melts, water runs down and freezes on the cold overhang and dams up, backs up and creeps under the shingles snd drips into the room.
I generally installed the Maximum vents and in fact to be shure that they'd operate I also add an extension as well as we often accumulate 3-4' of snow buildup.
That attic heat MUST be able to exhaust!
One solution that cures that is to build up a small aux roof along the ridge to create a ridge tunnel and then add a Maximum vent stack or 2 on that tunnel. Naturally you need to slit the ridge open about 2" to allow all the hot air from each rafter space to exit into that tunnel.
Now if the builder stuffed all the spaces between the rafters full up none of the above will work as the hot air just can't exhaust.
The only solution is to then lay 2 x 4's and a new deck to get that vent space.
Can tell U that around here many homes are chalets converted to all season dwellings and many were built with cathedral ceilings and rafter construction.
Today most of them now sport that second roof deck and air space technique.
You can spot them because the facia's are thicker than normal, or double facia.
/ roof ice/snow #12
While the rubber membrane will most likely stop the water infiltration, you will still get ice dams if you don't vent it properly.
The ice dam will still push your gutters, fascia board and soffits around and cause slow, but sure damage to your roof.
Until the spring, the best thing to do is use a roof rake and pull the snow off. You only have to go a little ways past the area over the exterior wall. No need to clear the entire roof, or even 6' back. If you have 18" eaves, 3' ought to do it. Especially on a south facing roof. The melt water will evaporate mostly before it gets to the edge and you shouldn't get to much buildup.
How do I know all this?
Because my roofer failed to install vents in the blocking between the rafters, I get ice dams each year, and I have to get up there, remove the soffits, vent the blocking, vent the rafters, re-insulate and fix it myself, but have not had the time. :laughing: So I roof rake after every significant snowfall. It takes about 20 minutes to do the whole house, except for two weeks ago when we had 3' of snow! :confused2: Then it took an hour and my arms were kinda sore! :confused3:
/ roof ice/snow #13
Look at your roof ridge and I bet your little 2" high ridge vent is burried in snow.
Excellent point. I have a power vent at the end of my gable that I can turn off and on manually from my kitchen if needed. It is set on a thermostat to vent when the attic gets above 85 in the summer. Saves on air conditioning.
/ roof ice/snow #15
There has been so much incorrect information published about ice dam solutions it's pathetic (including This Old House). VENT-VENT-VENT - well, let me tell those folks something. I'm not from Missouri but when you can show me cold air rises then I'll believe venting is a possible solution.
Another misconception - keep the attic the same temperature or colder than the outdoor ambient. IMPOSSIBLE. Insulation is a wonderful thing but it just won't work miracles. With no attic insulation ice dams may be a problem at 0 degrees F in a house but with excellent insulation the temperature at when it will possibly occur will be nearer 32 degrees outdoor ambient.
Ice Shield Membrane - will only be effective if the roof is completely covered and has a 100 percent seal. Ask your contractor if he will guarantee a 100 percent seal in writing. I really doubt it unless he is a complete idiot or plans to not be in business when you call.
The most workable and cost effective solution is to use heat tape at the eaves and at least one area above the building line. One heat tape straight up from the eaves edge up to the ridge will give the water a path to exit.
In post #3 the fireplace area on the roof needs to be address with heat trace tape. We can see ice in the photo and there more than likely will be water under it backing up past the building line.
This problem is sneaky and secretive unless you see water dripping from upper window areas.
The quickest way to have water enter is freezing rain followed by a few to several several inches of insulating snow. In this case you won't even see the thick ugly ice dam depicted in drawings because it doesn't need be there. The 1/8 inch of freezing rain is sufficient and the total roof will be under water except for the eaves.
/ roof ice/snow #16
I have a neighbor that had repeated trouble with this same problem....after membrane under shingles and adding ventilation/insulation the thing that did the trick for getting rid of the heat (winter and summer) was one od these....
Roof Turbine Vents
He mounted it on the back side of house on roof (ugly to see from street) and the thing draws air out year round from his attic....he loves it and the ice buildup vanished....no electricity needed and quiet......
/ roof ice/snow #17
I've had this conversation with friends with new houses with only ridge vents......They complain of the ice buildup and claim they HAVE enough ventilation.......
My reply to them "If you only have a roof ridge vent and no side eve vents then you have NO ventilation when covered up with snow"......
/ roof ice/snow #18
Insulation and ventilation works and I can prove it. Just come on over any time and I will show you some new houses I built that dont have a lick of ice on them and then I will show show you any number of older house that do have ice dams on them.
/ roof ice/snow #19
Read this part again.
"Another misconception - keep the attic the same temperature or colder than the outdoor ambient. IMPOSSIBLE. Insulation is a wonderful thing but it just won't work miracles. With no attic insulation ice dams may be a problem at 0 degrees F in a house but with excellent insulation the temperature at when it will possibly occur will be nearer 32 degrees outdoor ambient".
/ roof ice/snow #20
Attic temp doesn't have to be kept at or below ambient temps.
The roof deck sheathing is another insulation so as long as the minor amount heat is ventilated from underneath the roof deck melting will be eliminated.
Like I said it works and I can prove it.
Root Rake Loader Attachment (A59228)
Root Rake Loader...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
1979 Ford F-100 Ranger Pickup Truck (A59230)
1979 Ford F-100...
ENCLOSED DRIVING SIMULATOR TRAILER (A58214)
ENCLOSED DRIVING...
2010 Chevrolet Colorado LT Ext. Cab Pickup Truck (A59230)
2010 Chevrolet...
