3rd function addition to JD 4300
/ 3rd function addition to JD 4300 #1
57JD320S
Member
South Carolina
1957 John Deere 320 Standard & 1998 John Deere 4300 4WD
I have a JD 4300 with a 430 loader that I want to add a 3rd function to use for a grapple that I have. I have been looking at the W.R. Long electric over hydraulic kit aned it appears to meet my needs but not sure if this is the best option. I am not real sure on the specifics of my current set up (power beyond, etc.) and how to go about deciding what I need to install it. I definetly want bulk head fittings at the bucket end and the ability to ad TNT to the rear later. Suggestions?
/ 3rd function addition to JD 4300 #2
Will be interested in what you find out. Some links to the options you are looking at would be helpful to better understand what you are talking about. Thanks
I added the 3rd SCV to my JD 4300 and added the HTL (top link). One of the best things I did to my tractor. :)
/ 3rd function addition to JD 4300 #3
I would think you need the same 3rd scv kit as Beenthere.
I've got the 4310 which may be the exact thing, I installed 3rd scv on mine, it was inexpensive, not easy to install on mine with the power beyond already in place but not complicated, just a couple of hard lines and a lever.
If the 4300 is the same, the loader's valve already has a 3rd valve built in and you just need to tap off of it with the lines and the lever.
Well worth the effort, cost is minimal compared to what options you get out of it, I also have the HTL and love it, I use it with out exception, every time I operate the tractor.
JB
/ 3rd function addition to JD 4300 #4
The WR Long is a good kit-it will have everything you need to add independent control at the FEL.
TnT can be hard, but doable. As mentioned, you already have a 3rd valve-just no way to control it until you add the 3rd SCV option from JD that adds the handle on the right fender and all the hardware and hardlines for about $250. JD also has a kit that adds hardlines to the loader, and hoses that run under the tractor and connect to the 3rd SCV QD's (quick disconnects) at the rear. I posted the pictures of the two kits below.
/ 3rd function addition to JD 4300 #5
Hey Kenny do you know the cost of that set up to extend hard line to loader? Just thinking about a home made grapple down the road.
John
I am not real keen on the lever mounted on the fender but it would work in a pinch. Does that kit come as one unit including the lines to run to the front or is that separate? I am just curious how difficult it could be to put either in.
/ 3rd function addition to JD 4300 #7
Hope this does not scare you, the 3rd scv is a little pain in the butt, but well worth it.
This is on 4310
JB
/ 3rd function addition to JD 4300 #8
JB4310 What you have shown is a bit different from the 3rd SCV for the 4300. Likely due to the ehydro controls in the right fender whereas the 4300 kit mounts the lever for the 3rd SCV.
Difficulty just depends on the interest and mechanical skill of the doer. More for some, less for others. Does require removing the right rear wheel, seat, fender and some work on the control valve. Good directions came with mine. And I enjoyed the task.
I've not found the lever on the fender to be in the way.
/ 3rd function addition to JD 4300 #9
John
Sorry John, I don't. I seem to recall in the $300 range maybe...
/ 3rd function addition to JD 4300 #10
I guess I did not explain it well? The 3rd SVC kit does not include anything that runs to the front. That's the other kit I mentioned.
I understand your reservations about using that lever for a grapple since you'd have to take your hand off of the joystick to operate the grapple, but you will want/need this in the future anyway-it can be the first start of you TnT setup you mentioned.
Its not intimidating looking. I am am just looking for an all inclusive kit that does it it all at once. i guess I can boil it down like this, money not being an object which would you choose?
/ 3rd function addition to JD 4300 #12
There is no "all in one" kit. There is not even a "kit" to add more than one true rear remote-JD only offers one.
Call WR Long and get a price for the true 3rd function valve-it's probably in the $600 range and can be ordered through your dealer.
Whats you opinion on preference. I think I could justify either price wise but want to use what works best and easiest,
Thanks, that is what I was thinking. Seems to be set up for a more seamless operation.
/ 3rd function addition to JD 4300 #16
I understand your reservations about using that lever for a grapple since you'd have to take your hand off of the joystick to operate the grapple.
Unless you were really doing production work, I think the lever on the fender would be just fine for occasional grapple work. Drive into the pile and clamp down on the load.
For me I would just make a top jaw type grapple to use with a high capacity bucket.
JB
I have the grapple (pic attached). I just am trying to decide the best (not necessarily easiest) way to go about adding 3rd function to control grapple. I also want to add TNT and outlets to rear later so I am not sure if doing the prep and valve work all at once would be easiest or not. Please weigh in here. I like the idea of the W.R. Long kit with the ability to control the grapple without having to remove my hand from the joystick. I am dumb when it comes to the hydraulic set up that is currently in place so anyone who has already accomplished this and can help me learn from their successes/mistakes will be greatly appreciated.
Thanks
frc
/ 3rd function addition to JD 4300 #18
That looks VERY heavy...how much does it weigh?
Try searching these terms here in the hydraulices forum since I assume I have not answered your questions well enough:
grapple
4n1
remote
WR Long
diverter
remote
3rd function
Your information has been very helpful. I am just trying to piece it all together. Not too heavy but I haven't weighed it.
/ 3rd function addition to JD 4300 #20
That's why I suggested you search...this has all been covered before;)
As for the TnT, here are two threads that use a diverter to "split" the one rear remote (3rd SCV option I mentioned above) into two rear remotes to control the two cylinders for Tnt. It's a very cost-effective solution.
3320 diverter installed - TractorByNet.com
Electric Selector Valve Install - TractorByNet.com
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
KUBOTA LOADER BRACKETS (A62130)
KUBOTA LOADER...
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
Sterling AT (A63118)
