snapped chain.....twice
/ snapped chain.....twice #61
my experiance is if the shear bolt is loose the hole will wear,making it oval.Also about rocks getting into the chain,the augur is designed to pull snow from the sides of the machine and throw it into the impeller.If you think rocks are getting into the chain just get a guard for it.I think your shear bolts are to high a grade.Sometime they get labeled wrong.Use grade two on augur and grade five on impeller and change the chane to a higher grade chain.If its a 60c chain go to a 60hcrw
/ snapped chain.....twice #62
my experiance is if the shear bolt is loose the hole will wear,making it oval.I think your shear bolts are to high a grade.Sometime they get labeled wrong.Use grade two on augur and grade five on impeller and change the chane to a higher grade chain.If its a 60c chain go to a 60hcrw
Most all shear bolts only ride on the bolt and the holes do wear. However on a blower the parts are under power and should not move around too much when in use.
The Rad blowers are unique as they clamp 2 plates rather than going thru a shaft. Whatever the mechanism the bolt must be the drive or it cannot shear.
Also Rad who makes the blower in question clearly states grade 5 shear bolts.
Sometimes a softer bolt will stretch and not shear.
I will stick with what the manufacturer says to use.
/ snapped chain.....twice #63
I spoke to both of my dealers this morning and they said Kubota does not give a spec for shear bolt torque.
They both did say that they should be snugged and then backed off so the bolt could be rotated but the parts did not rattle around.
They both said too tight and they will not shear reliably.
Hope this helps someone.
I have a Kubota thrower and agree ... but Note that OPs shear arrangement is different than that used on Kubota throwers. His should be snug, but not tight
larry
/ snapped chain.....twice #64
larry
The OP's shear looks EXACTLY like mine except that the New Holland drive is on the opposite side.
Compare post 31 with 42
/ snapped chain.....twice #65
Thanks. Didnt see that. They are differemt than mine. ... In that case tho I do not agree with Kubotas advice. If the shear bolt is not snug in that arrangement the joint can open some by spreading. That corrupts the shear. A shaft in tube design does not need to be snug since the shear area is well controlled by the size of the parts.
larry
/ snapped chain.....twice #66
larry
Kubota's advice is JUST snug not loose, but so that the bolt can be rotated some. I assume by light wrench pressure.
Mine is 4 winters old and I have no wear yet by using this method.
/ snapped chain.....twice #67
Negative, the bolts will shear when something gets into the augers(or fan) bad enough to stop them, but I think you are getting rocks into your chain, which is before the augers. Thus snapping the chain.
A 2 to 6 inch rock getting in between the chain and the sprocket is probably going to cause a problem.
(Blower picks it up with the snow......snow packs it into the the sides...........gets lodged between sprocket and gear...........snow keeps piling in pushing rock into sprocket.............)
I think we've found the problem.
What lead me to this conclusion was the amount of paint wear (and the pattern) on the blower, in such a short period of time.
I'm with you on this one, sounds and looks like rocks/gravel are running
thru the blower fairly regularly, and the bigger ones may be in the auger,
but smaller ones may very well be in the chain/sprocket area.
Again I have not had rocks in the chain or sprockets. I have been in the auger. And once in the second stage.
/ snapped chain.....twice #69
How tight are you putting the shear bolts???? See my post above on dealer recommended torque.
They are tight, but i am going to loosen them a bit before I use it again. Had to put the blade on since it rain and turned the road to slush. We evn had to get the old TD-6 out to help clear the roads. I found something the tractor had a hard time doing and didn't want to tear it up.
/ snapped chain.....twice #71
I may have missed where you said what the shear bolt was.
A lot of times I'll see people using any old bolt or rod in place of the shear pin/bolt.
Such is a disaster waiting to happen.
Regular bolts are hardened metal. Shear pins are soft metal specifically to be cut through. I've made "shear pins/bolts" from scratch by cutting rod stock or from regular bolts and heating them red hot and letting them cool slowly without quenching in order to take the temper out of them, rendering them much softer than normal. Still not the best solution, but can work in a pinch.
/ snapped chain.....twice #72
Except that many manufacturers such as Martin Meteor use standard grade bolts as "shear" bolts direct from the factory.
/ snapped chain.....twice #73
It is my present feeling that the Ecnor blower is better built and wish I had bought one of them this time too.
My 6' Econor does seem to be built well, although (oddly) Econor blowers are relatively light in all size classes. Also, the well-respected Puma is the same blower rebranded.
JayC
/ snapped chain.....twice #74
Woah right there! Once you have blown the chain once, it will not hold the same again! All the links on the tension side of the original blow will always be weak in the future.
I chased the first chain I had on my blower with master links before I learned and bought a 10 ft roll. The new chain drasitically reduced my problems from a break every 5 hours to about a break a season. (I put about 100 hours a winter on blowing)
I also reduced my shear bolt size and grade but it still breaks chains before bolts.
Okay I am about to give up. Snapped the chain twice again. Once yesterday and again today. I have the 60H on already and the bolts just won't shear for some reason. It has the right bolts. I now have 5 master links in the chain. I did get a new chain so might change it out. Just don't understand this problem.
/ snapped chain.....twice #75
Shear bolts aren't always made from soft material. The neighbours MF baler uses Grade 8 bolts as shear bolts. It warns not to use soft bolts. I did once as a last resort, what a pain to get the smeared bolt out.
Shear protection is just designing a component to fail at a specific torque to save some other component.
/ snapped chain.....twice #76
Pulling the pins and checking for free movement should be part of everyone's annual PM.
It is sad that the owner manuals are so lacking in detail about the the shear pins and slip clutches.:confused2:
They seem to assume that everyone knows this stuff.
Actually, my equipment manuals all give explicit instructions on care and feeding of slip clutches or shear bolts. I did have to actually break down and open them up:laughing:. Maybe the less expensive stuff with 'Engrish' manuals don't have that section?
/ snapped chain.....twice #77
Kubota's english translations are sometimes less than acceptable.
They say something to the effect of making sure the shear bolts are properly tightened.
/ snapped chain.....twice #78
Woah right there! Once you have blown the chain once, it will not hold the same again! All the links on the tension side of the original blow will always be weak in the future.I chased the first chain I had on my blower with master links before I learned and bought a 10 ft roll. The new chain drasitically reduced my problems from a break every 5 hours to about a break a season. (I put about 100 hours a winter on blowing)
Exactly, and once a rock goes thru the sprcket, even though the chain didn't break at that exact time.........the chain is substantially weakened.
Best advice is to keep rocks out of the blower, especially one with an exposed chain.
/ snapped chain.....twice #79
Looking at your pics and noteing the hours of usage suggest that you blow lots of rocks.
(your blower housing is really battle scared for those low hours)
Every rock hit weakens the shear bolt a tad more each time and every bolt sheared puts a good shock load on the chain.
As stated in another post, once the chain snapped it snapped the weakest link but then all the other links became that much weaker.
I don't think the blower is much at fault but rather your drive is.
I'd suggest a new chain and adjust the skid shoes higher to avoid plucking stones.
I know that blower and it is real tough but there is just so much it can take.
/ snapped chain.....twice #80
I'm going to drop this thread, but IMO every snowblower is designed to have a few rocks go thru it. What this guy has, is not a rock/shear bolt/or chain problem. I don't know what it is......brand new blower...climb up(the azz)of the company that built the blower.
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63689)
PENDING SELLER...
For Sale - Brush Hog - Woods RCC42 rotary cutter
For Sale - Brush...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
DOBBS 48in Forks and Frame Skid Steer Attachment (A61572)
DOBBS 48in Forks...
2015 Ford Explorer SUV (A61574)
2015 Ford Explorer...
