snapped chain.....twice
/ snapped chain.....twice
I still need to get the pictures but I have been plowing with the blade all morning. We have had at least 1.5" rain and everything is melting. Couldn't even get out of the road. I know there have been a lot of question on what I have and the pictures will tell all.
Here is the infamous chain that is weaker than the bolts. :mad:
Here is the second stage shear bolt.
This is the back of the blower. If you look close you can see the black knob that you unscrew to access the auger shear bolt.
This is the auger shear bolt.
As you can see it is not a tube in a tube. It is two flanges bolted together. The do spin freely when the bolts are not in. Remember that I may have at most 25 hours on this blower. Only 70 hours on the tractor total. I also use the blade a lot like today. Rain sucks in winter.:mad:
/ snapped chain.....twice #43
That's how both my auger and impeller are set up and I tighten them down, they came tight from the factory. I figure I don't want them loose. If the plates are loose they'll move just a little during normal operation and will cause wear and the hole for the shear bolt to oblong. I've sheared one auger bolt but about 4 impeller bolts so far this season so I would say extra friction of the plates isn't a problem.
Next time I am at the dealer I will see if they have a service manual.
Mine were slightly loose so I put the new one in the same and I have only replaced 1 bolt in the past 4 years.
/ snapped chain.....twice #44
Contact your dealer and see if they have a torque spec. Crazyal tightens his more than I do but would tighten and then back off about 1/4 turn, be sure to use a lock nut.
That blower is identical to mine except the drive is on the right, Kubota is on the left.
/ snapped chain.....twice #45
Sumpter just got a quick question have you ever checked the oil in the gear housing? Also the internal chain which is in an oil bath on the back? As I said earlier I never had a problem with my unit it's one of my biggest regrets getting rid of the TC 40 I love that front snowblower really curious of what's going on.
You know I never have. Do you think if it is low that could be the issue? I will need to check it. I see you had the same blower.
/ snapped chain.....twice #47
You should check the oil in all gear cases, but your problem is after all the gear boxes.
I do make sure the oil and all that is at the right levels, and also grease regularly, but I have not thought about the gear case on the blower. I can not explain why. I have no excuse.:ashamed:
/ snapped chain.....twice #49
One other bit of friendly advice and I can see they still haven't fixed it, looking straight down you see how two bolts hold the entire black housing onto the snowblower those two bolts work loose or at least they did for me tried Loctite and everything else to no avail. The solution was to get a plate of steel and welding it to extend grabbing the other two bolts all four bolts would hold the chain drive assembly from shifting around it was the only thing that kept it from loosing ever again I'm not sure if I explained it right I drew some quick lines over a photo I think you get the idea you only need to do it on the top not the bottom that's if you have the problem mine would just not stay tight especially after heavy snow storms three in a row, that was the only problem I had can't believe you're snapping chains and sheer bolts?I beat the H### out of mine cutting down 3 foot hard packed snow walls weeks old and never having a problem.
/ snapped chain.....twice #50
one other quick photo my favorite one the 40+ inch snowstorm that front blower didn't even slow down look at that pass by the car almost 3 foot deep you shouldn't be breaking chains or shear bolts perhaps there's something wrong inside that internal chain transmission? take care
WOW!! If it wasn't raining here now we would have at least that much new snow, but no luck. (Did I tell you I love the snow?) Since I have the blower in the shop I will give it the twice over and make sure everything is correct and tight. I hope I find a simple solution and have an ah hah moment to cure the problem.
/ snapped chain.....twice #52
Check the teeth on the sprockets, especially the one in the back that we can't see in the photos.
If a rock entered there, and broke a tooth off...............that could cause the chain to snap repeatedly.
Or if you are picking up gravel while blowing, that could snap a chain also, if it gets wedged between the sprocket and chain.
My old Cub Cadet, with the belt drive rear tiller.................I could till acres of ground without a problem..............until I picked up a rock, about the size of a 50 cent piece and about 1/4 to 1/2 inch thick. It would get caught between the idler pulley and the belt, cutting that 125 dollar belt in half every time.
My neighbors garden is about 15 ft by 25 feet..............I went thru 2 belts tilling his garden as a favor.
Everything is clear and there are no broken teeth. This has been an issue since I got the tractor and blower. I think I will put the new chain on and see if I have better luck.
/ snapped chain.....twice #54
That shear arrangement puts the shear point well outward of the shaft axis. This increases the leverage of the bolt -- essentially decreasing the shear force, increasing torque necessary from the sprocket. With this arrangement in particular your bolt should not be backed off but snugged to a couple ft-lb. Are you sure the mfg does not call for shearbolts that are grooved at the shearpoint?
larry
/ snapped chain.....twice #55
Are you picking up gravel?
Yes I am picking up gravel or more accuratley rocks. I still feel that the bolts should shear before a chain break. I am in the mountains on old forest service roads and rocks 2-6" are common. I had hopeed that the snow had covered them all.
/ snapped chain.....twice #57
Negative, the bolts will shear when something gets into the augers(or fan) bad enough to stop them, but I think you are getting rocks into your chain, which is before the augers. Thus snapping the chain.
A 2 to 6 inch rock getting in between the chain and the sprocket is probably going to cause a problem.
(Blower picks it up with the snow......snow packs it into the the sides...........gets lodged between sprocket and gear...........snow keeps piling in pushing rock into sprocket.............)
I think we've found the problem.
What lead me to this conclusion was the amount of paint wear (and the pattern) on the blower, in such a short period of time.
The last rock was wedged between the ice chopper (?) and the housing. Not in the chain.
/ snapped chain.....twice #59
My farm road is 1500 foot gravel 2 inch flat gravel, I realize you're basically picking up stones why not hold the unit higher in the air or just adjust shoes to their maximum height might help a bit. I think you're going to have a real problem the beginning of each season until the stones are under a hard pack surfaces of ice and snow. I know that unit is quite expensive , but you might have to give up using it and just plow the roads rather than risk any more damage to the blower and possibly your tractor. Quite an expensive alternative trade it in for a unit with a shielded chain of course that would mean a three point rear snowblower which is a pain in the neck or modify the existing unit it could be done, or just keep extra chains and bolts laying around take care
/ snapped chain.....twice #60
I spoke to both of my dealers this morning and they said Kubota does not give a spec for shear bolt torque.
They both did say that they should be snugged and then backed off so the bolt could be rotated but the parts did not rattle around.
They both said too tight and they will not shear reliably.
Hope this helps someone.
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2018 INTERNATIONAL LT DAY CAB TRUCK TRACTOR (A59911)
2018 INTERNATIONAL...
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
