Kubota dozer blade
/ Kubota dozer blade #1
kuboman
Canada
B3200, L5740,
Does anyone know if Kubota makes a blade that will pin on the front of a loader in place of the bucket. I would like one for the loader on my B3200.:thumbsup:
/ Kubota dozer blade #2
W.R.Long makes such a blade, with the ability to angle.
/ Kubota dozer blade #4
Kubota made a frame mounted blade / snow plow. I believe it was for the B7xxx series. I have seen them for sale used and they look tougher than W.R. Long item.
Here is one for $500 I found searching Google
Kubota Front Blade FZB2019 > Capital Equipment > Used Equipment | Capital Equipment
/ Kubota dozer blade #5
If you have rear blade you could by an 3 point attachment plate for your Quick attachment. You could then use your rear blade on your loader. I would be careful how much pressure you put on the loader arms. I had considered a 3 pt attachement for my loader so i could use my boom pole to lift trusses and possibly a 3 point carryall as a man lift. Not that I would do that since you should not use a loader as a man lift......:eek:
/ Kubota dozer blade #6
looking for a unit like the one posted by Bruce Ward. if anyone knows of plow assy. I will pick up
thanks Nelson
2023 ANDERSON IFX720 CONTINUOUS BALE WRAPPER (A64277)
2023 ANDERSON...
New 4-Wheeler Tires (A65640)
New 4-Wheeler...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
2015 Bandit 200UC Chipper (A63689)
2015 Bandit 200UC...
2008 Harley Davidson Motorcycle (A64127)
2008 Harley...
2015 Polaris Slingshot Motorcycle, VIN # 57XAASFAXF5104933 (A65563)
2015 Polaris...
