my small dozer i build
/ my small dozer i build #1
coyoteugly543
wheelhouse
how do i upload a pic
/ my small dozer i build #4
I have done it many times but I can not really describe. As you are the original poster just use the quote and that should give you the attachment option. If others could help it would be great.
If you have some crashes at first do not worry as they are called growing pains.
Craig Clayton
/ my small dozer i build #5
You need a host for the pic first.
tinypic.com works well for me, some people use photobucket but you have to set up an account, free but annoying to me.
Then once you have a web link
look for this icon above the reply where you type the message
Click it and paste or type the web link in the box.
Hit ok and then submit the post.
/ my small dozer i build #6
I think that I put the pic on my desk top and and use the attachment to find it.
Browse then upload.
Craig Clayton
/ my small dozer i build #10
Here is an instruction for you!
When creating a new reply or in advanced edit mode click on the paper clip (on top row of icons).
Browse and select up to four pictures from you computer:
Click on 'upload' to have your images saved to TBN and then close the attachment manager.
Go back to the paper clip and select the image you want pasted. The image will appear in you post wherever your cursor was placed.
Good luck!
/ my small dozer i build #11
I've been thinking about turning my Cub Cadet 682 into a tracked vehicle - how did you steer it? (I can't decide between the easy route - putting brakes on each axle and brake them independently to steer, or the hard route of using wet clutches to engage/disengage power to each track.) Do you have any pictures of the building process/design?
I used used harley davidson motorcycle front brakes. no sorry I didn't take pic as i was building it. Rick
/ my small dozer i build #16
I like the dozer. Great work on it. Thanks for sharing the pics.
Chad
/ my small dozer i build #18
Looks nice. Can you take a close up of the tracks. It looks like you have some track guides other then the typical heavy chain. I also see what looks like a hydraulic track tensioner, can you take a close up. (in case we want to steal your ideas)
thanks
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
43023 (A59228)
43023 (A59228)
KMC 3386 (A64119)
KMC 3386 (A64119)
Colombo Twin Master (A64119)
Colombo Twin...
2023 John Deere 8R 340 Tractor (A63111)
2023 John Deere 8R...
Katolight SED60FJJ4 75kVA Towable Diesel Generator (A61572)
Katolight...
