Centering Steering Wheel
/ Centering Steering Wheel #1
Boeing
Botetourt, Va
kubota L3010
Would someone please tell me how to center the steering wheel on my Kubota L3010? It doesn't APPEAR to have a center hub cap hiding a bolt, there is no setscrew on the side??? It's way out of alignment, when it is straight forward the wheel is turned to the 5 o'clock position. Drives straight so maybe I should leave well enough alone.....:confused:
/ Centering Steering Wheel #2
It is a hydraulic steering system and the "center" as you describe it is constantly changing .......... meaning if you did line it up at say 12 o'clock ........ the next time you used the machine it would move to another position.
Someone with more knowledge will provide a better explanation of why.
/ Centering Steering Wheel #3
??? I've got power steering on my cars adn trucks and the wheel centers.:confused2:
/ Centering Steering Wheel #4
It is "hydrostatic" steering to be accurate. There is no mechanical connection between the tie rod and the steering wheel. Do to the very slight leakage (bypass) of the orbital valves used, the steering wheel is always off-center.
/ Centering Steering Wheel #5
It is technically "power assisted" steering...there is still a mechanical connection via a "steering box" or "rack"
/ Centering Steering Wheel #6
Would someone please tell me how to center the steering wheel on my Kubota L3010? It doesn't APPEAR to have a center hub cab hiding a bolt, there is no setscrew on the side??? It's way out of alignment, when it is straight forward the wheel is turned to the 5 o'clock position. Drives straight so maybe I should leave well enough alone.....:confused:
It's normal...and one of the main reasons I don't have a spinner on my wheel.
/ Centering Steering Wheel #7
Ah, now it makes sense. I got a spinner as a gift recently and noticed that it "keeps moving around the wheel". Not really, but it is no longer in the ideal location.
/ Centering Steering Wheel #8
Eventually, it will be back in the 'ideal' position again. ;)
/ Centering Steering Wheel #10
This is why I have two spinners installed opposite of each other.
/ Centering Steering Wheel #12
That is funny .......... if they're screwd down at 180 apart I bet they do stay that way ......... even with the wheel a spinnin.:laughing:
Thank you guys......I never cease to be amazed by the amount of KNOWLEDGE out there. I really appreciate all of your inputs to my ignorant and occasionally plain dumb questions:2cents:
/ Centering Steering Wheel #14
No question is dumb because only a few of us claim to know it all,:laughing::laughing::laughing::D
/ Centering Steering Wheel #15
Ah, but there is no such thing as a dumb question; agree on the knowledge as it sure has helped me.
/ Centering Steering Wheel #16
AND...... recognize that most of us asked the same questions at some point in time .........
/ Centering Steering Wheel #17
Good call SARG! Since they are both screwed down, they stay 180 degrees apart. They will vary in position but with having two, one should be in a fairly comfortable position.
As others have already mentioned, there is no dumb question. I asked this same question two years ago and this is why I have two spinners.
/ Centering Steering Wheel #18
Nothing to really do with centering the wheel, but it never hurts to adjust the toe in on the front wheels. Mine was out after 200 hours. Its been a while since I did it but got it within 1/8", meaning hey are sligthly toed in at the front. It was fairly easy using the remainlng rubber casting remains that are typically found running circumferentially in the center of each tire as a zero reference measuring point. Take that distance measured from the back of each tire, then check it on the front of the tire, measuring right side to left side 180 out. Wouldn't hurt to have a helper. Also make sure the front is unloaded, (bucket down).
/ Centering Steering Wheel #19
While probably not technically the best thing to do, you can adjust where the steering wheel is in relation to the wheels.
Put the wheels straight, and see which way you want the spinner to move. If the spinner is too far to the bottom right, you you need to turn the wheel clockwise.
Turn it all the way clockwise, and it will come to it's stop. But then just hold it there, and you will feel it creep further around very slowly.
Spin it back to centre, and see if your adjustment has worked.
I only bother to do this when I am going to be going in lots of straight lines and I want to be able to put my feet up a bit :cool:
It will tend to stay in the right position until you start swinging the wheel around wildly again (like during loader work) - mainly when you hit the stops, but there is an element of drift, which is worse on some tractors than others.
My experience is of mainly bigger ag tractors - but it works on the little Kubota lawnmower too :)
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2014 INTERNATIONAL PROSTAR+ (A65643)
2014 INTERNATIONAL...
Round Bale Livestock Feeder (A66408)
Round Bale...
Peruzzo Canguro 1600 Collection Flail Mower
Peruzzo Canguro...
New/Unused ATS 60 Gallon Two Stage Air Compressor (A65583)
New/Unused ATS 60...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A65643)
2015 VANTAGE...
