WHATS A GOOD IMPACT WRENCH?
/ WHATS A GOOD IMPACT WRENCH? #81
My first Snap-On 1/2" drive impact never saw under 125 psi. It lasted 18+ years before it just didn't have the power it used to. I can only hope the one I replaced it with will last as long. It probably will, now that I do 90% or more with my 18v cordless impact. My cordless will take off the lug nuts on my dually with no problem. I'll use my 3/4" gun for stuff like mower blades and stump jumpers.
Brian
/ WHATS A GOOD IMPACT WRENCH? #82
Holy cow, for years and years I have run my impact at 90 lbs. That is what the instructions said to do. Oh, a couple of times I have "cheated" on a tough nut and turned it up to 100 maybe 110 once or twice, to get a little more oomph. but who knew? 175 LBS?:eek:.. you got to be kidding me!:laughing: I always assumed that if you turned it up much it would become a hand grenade:laughing: Heck I am going to run that sucker wide open next time I need something broke loose:D Besides it is a junky old impact and I have got my money's worth out of it a long time ago.:thumbsup:
James K0UA
/ WHATS A GOOD IMPACT WRENCH? #83
Good discussion. I'll have to put in a vote for AirCat. That is what is in my garage. 1/2" is rated at 1000 lbs/ft and is quiet and comfortable to use. I think around $125 or $150 without looking it up.
Perhaps you all can help me with a question that has recently come up. My younger brother lives with me and he is claiming that the impact gun doesnt have as much power as it used to. He is claiming that it is because that I use it above the rated 90 psi sometimes. I do turn it up to 110 or 120 if I have a stubborn bolt once and a while and was assuming this was an acceptable thing to do. His argument is that when you do that it spins too fast and wears things out and the seals arent rated fo anything much above 90 PSI. In theory I would somewhat agree that it is feasible, but in all practicality I dont think Im doing any harm. What do you all think, especially you BIRD since you have a lot of experience with these types of tools.
No 1/2 gun is rated for 1000 ft-lb .. or even 900, altho Iv seen both statements on here. The mfgs are weasle wording it by saying that the gun will remove a bolt tightened to 1000. Thats not the same thing .. removal is easier. You cant apply 1000 thru a 1/2" square shaft.
larry
/ WHATS A GOOD IMPACT WRENCH? #84
James K0UA
Nah.. run it off the bottle at 175 and let her eat.. It WILL cause more wear.. but it gets the job done..
And to add to the increased wear of the ANVIL... Using "chrome" sockets on an impact wrench is an absolute no-no.. One reason that impact sockets are heavier is due to the socket material being slightly softer than the metal used for the anvil..
Chrome sockets are much harder material and wear away the anvil and destroy the retaining ring.
/ WHATS A GOOD IMPACT WRENCH? #85
This has been a great and very informative thread. Lots to learn still.:thumbsup:
/ WHATS A GOOD IMPACT WRENCH? #86
Brian
I run my Craftsman Pro gun at 125psi (at least) every time..Still works as good as it did when I bought it 15 years ago.
/ WHATS A GOOD IMPACT WRENCH? #87
And if that chrome socket breaks, it might become the hand grenade KOUA mentioned.
/ WHATS A GOOD IMPACT WRENCH? #88
try a Harbor Freight EARTHQUAKE 1/2" drive...for commercial use, there are much better impacts out there, BUT, for home use the Earthquake is a fairly stout impact. The Ingersol-Rand composite impacts are NOT worth the money, they are very frail and the air motor gives up quickly..
I bought earthquake. I'm impressed. 600+++ FT LB TQ. I have to be carefull. It will break bolts
/ WHATS A GOOD IMPACT WRENCH? #89
I managed a vehicle test garage for brakes from everything from a Civic to Class 8, using 3/8" to 1" impacts, AKA in our shop as "Rambo". There's a lot of good info here, and here are my thoughts.
We always used iron for our air plumbing. Part of our corporate safety policy not only for integrity, but not to add air in case of a building fire. Too small of hard air line or rubber extension kills the power every time. One thing that can be done in barns that have the compressor on one side and work area on the other is to plumb in a remote storage tank at the use location to keep the volume of air up. Similar to the "test" using a propane tank mentioned.
For 1/2" and under guns we always used Snap-On. We got a corporate discount so that made things easier. For the 3/4" and 1" guns, IR was our choice for both longevity and power. As mentioned, the good IR 3/4" could replace our 1" Rambo often.
We picked up several Blue-Point 14.4VDC 1/2" impacts during our latter years, and all the driver/mechanics really liked using these. As long as they had a good charge they would pull lug nuts off anything up to F-350's with their 150lb rating. Relatively light and no tripping over air lines. (Superduties are torqued to 165lbft, but they seemed to achieve that as long as no extension was added to the anvil).
We regulated at 80psi, unless we had a real problem. If you are using torque sticks for lug nuts you have to find the sweet spot in the pressure range for them. Our Snap-On torque sticks achieved rated torque at 90psi with our tools, but if we went over that pressure, the torque would too. Since we were a testing facility, torque was an issue we had to monitor with brake rotors. If your wondering about the 80psi, that was so we would be under torque with power, then manually come up to spec with a torque wrench.
/ WHATS A GOOD IMPACT WRENCH? #90
larry
No arguments here, the ratings gotta be inflated but I'm still going to buy a gun listed for 900 over one listed at 350. So, with all the knowledge listed here like higher pressure, shorter hose and no extensions for better power. What about the stubborn ones? Ok, to let it hammer for awhile? Some bolts are a bit loose and don't have a great fit, try to get a better fit as in the looseness is detrimental or is it irrelevant? This is a good thread, maybe all this stuff should be set up in bullets :)
/ WHATS A GOOD IMPACT WRENCH? #91
On the weekend car shows (off-road, extreme 4x4, hotrod tv, etc.. ) you always see those ya-hoos using a brand spanking new 1/2 impact with no dirt on it along with a shiny new chrome socket...
Good thing they aren't really using them... A chrome socket cracks and splits up the chrome plating it will fillet your hand!!!.
/ WHATS A GOOD IMPACT WRENCH? #92
Bird,
Thank You. Your info saved a couple of my old impacts. When they got week I replaced them and threw them in a box. After reading this thread I dug them out and looked for the lube points you pointed out. Sure enough there they were. A little lube and they were running like new again. I always thought when you added oil through the line you were lubing every thing. I guess it's a guy thing.I don't need to read the instructions I know how to run a impact.
Bill
/ WHATS A GOOD IMPACT WRENCH? #93
Besides the lubrication issue, I suspect that the 'pressure/volume drop' over your long run of air line/pipe, is adding to your grief! Lube them up and run them right at the compressor. I think you'll see a marked improvement. ~Scotty
P.S.-I didn't read all 90+ posts, just about 1/2 of them. Sorry if this is duplicate info. ~S
/ WHATS A GOOD IMPACT WRENCH? #94
Every shop I've worked at had unregulated air. The big compressors come on at 125 and run to 175. There is a difference in power when using the higher pressures. Most guys will let the gun hammer away for a while on the stubborn stuff in hopes of saving a trip back to the toolbox. I'll usually go 30 seconds or so just to see what happens, and sometimes will wait for the compressor to come on and build up to full pressure before a final attempt. If that fails, it's off to the toolbox for a manual setup or a bigger gun. Since I am working on mainly cars and pickup trucks my old IR doesn't fail me too often though. I think maybe 4 or 5 times this year I had to break out the 3/4" gun. My old CP 3/4 was only rated for 700 ft pounds but it sure does hit harder than any 1/2" gun in our shop. Oh, and the tighter the socket fits on the fastener the better for power purposes. A loose fitting socket absorbs some of the hammer blows
BUMP,
Ifinally got time off from work,and ive been to hd and bought some 1/2 pipe and fittings,and im gonna attempt a system.Id like to post photos along the way and get your input.
First question ,I noticed in KEVEN JS photos a short jumper hose between the compressor and first pipe.Im assuming that direct hookup of the iron isnt reccomended because of vibration? OR NOT?
Gonna try to draw a pic of my proposed system,scan it and show it stand by
ALAN
see if my scan pic works ,if so input please
ALAN
/ WHATS A GOOD IMPACT WRENCH? #97
Alan,
Pic came through, although it would have scanned better in black rather than blue, it is a bit tough to read. Yes, you want a flex between compressor and pipe due to vibration.
Did you ever try to hook up Impact Wrench directly to compressor rather than through all that tubing?
no i never tryed direct ,i think id need at least75 feet to have enough operating length.im trying to hard pipe everything ,having valves to close branches that im not using ,having drains,and a designated branch off the main just for the impact,with just a short operating hose.Ihad no tubing,it was all hose
/ WHATS A GOOD IMPACT WRENCH? #99
Another way to improve wrench performance at the end of a long run of pipe/hose is to have a storage tank, say 20 gallons right at the beginning of your "impact only hose". Any stored volume of air is a plus, and the closer to the gun the better.
Sean
/ WHATS A GOOD IMPACT WRENCH? #100
I've been out of the air tool repair business now for nine and a half years, but until then, the most popular half-inch impact wrenches for professional mechanics were the Chicago Pneumatic CP734 and the Ingersoll-Rand IR231. They were entirely different styles and designs, but both produced the same amount of torque; i.e. 425 ft. lb. MAC, Matco, and Cornwell all had versions with their own names on the tools, but they were just Chicago Pneumatic or Ingersoll-Rand so the parts were interchangeable.. Snap-On has very similar impacts, but just different enough that if you ever need parts, they have to come from Snap-On at much higher prices.
Incidentally, my own current half inch impact is an IR231 that I gave $40 for at a pawn shop.
Bird,
I've read a lot of your comments on various subjects and found them reasonable as per different subjects so when you mentioned that you were in the air tool repair business, I purchased an IR231C and you should see the grin on my face..... The best 1/2" impact wrench for the money-buy it once!
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
2011 Ram 2500 Longhorn Laramie 5.7 HEM (A62679)
2011 Ram 2500...
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
John Deere 700 H Dozer (A62679)
John Deere 700 H...
