255 Massey front end loader question?
/ 255 Massey front end loader question? #1
All About Mopars
255 Massey Ferguson
I have just invested in a 1979 Massey Ferguson 255. It has a front end loader on it that is functioning, but it is running off the rear remotes therefore you have to use the controls for the rear remotes to operate it which is not that efficient. I have bought a joy stick and was wandering if any of you have done a mod like this and might have input on this. Any input would be greatly appreciatted thanks Chris.
/ 255 Massey front end loader question? #2
U need to get a power beyond valve and had plumb it. They are pretty easy to install. If u need help locating one just let me know and ill b glad to help.
I do thank you jlsmith, I will research that and if I have any doubts I will get back with you.Thanks Chris
/ 255 Massey front end loader question? #4
We need some more info to help you better, and some pictures would be nice to...
What valve did you buy?
What is the GPM and PSI rating for your machine?
Are the rear remotes plumbed with hoses, hard lines, or is it mounted directly to the tranny?
I will get some pictures tomorrow,and more info on the valve as it is at the shop. I can tell you that the rear remotes are plumbed with rubber hoses. I knew better than to post without more specs, I had planned on getting all my "ducks" in a row today before hand but it slipped my mind.
/ 255 Massey front end loader question? #6
Ull b ok. I just did one a few months ago and u have plenty hydraulics. But did u get a open or closed center valve for the fel.
Okay so I got really busy today when I got back to the shop I finished fabricating a new bucket for the tractor we are talking about and I forgot to get pictures and info on the valve. I do happen to remember reading that there is a port on the valve that can be used for power beyond. I will try to get all the info needed tomorrow. Thanks Chris
Okay so I gatherd some info and a few pictures. I hope the pictures don't confuse more than help.
http://www.brand-hyd.com/install/LV_Installation_Sheet.pdf
In this link is the instalation info, it shows a power beyond port.
This is the feed and return from the pump.
This is the filter.
This is the feed and return lines to the valve for the rear remotes. Plus there is a small line going into the body of the tractor in the area of the three point.
/ 255 Massey front end loader question? #9
I have a 285 MF with loader and we use the 2 remotes at the back to power a joystick control valve. Ken Sweet
/ 255 Massey front end loader question? #10
I just purchased a '79 model 255 last night and it too has the loader controller running off the rear. The lift is very slow. Seems like this would be a volume issue more that a pressure issue because it has plenty of power. Would this new system help this? I would much rather have a joystick controller anyway.
/ 255 Massey front end loader question? #11
My 390 is tee'd off the rear remotes and works fine so was the ford 6610 and IH 674 . We were less successful with 30 series deeres plumbed this way though !
John Deere TX 4x2 Gator (A62177)
John Deere TX 4x2...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
New/Unused ATS-ECP40 Plasma Cutter (A61166)
New/Unused...
2015 Ford F-150 Ext. Cab Pickup Truck (A61568)
2015 Ford F-150...
2023 Deere 325G (A60462)
2023 Deere 325G...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
