box scraper, what size
/ box scraper, what size #1
alaskakubota
I know I have a lot of questions because of the new tractor, but I had a 4' box scraper on the bx 18. Now I have the 5740 and I am curious to what size people are using. 7 or 8'. Which one are people using? Tractor will have loader and rear tires filled. R-4's
/ box scraper, what size #2
7 ft if you don't want much overhang. 8 ft, if you don't have to worry about getting through tight places. Ken Sweet
/ box scraper, what size #3
id say you can pull a 6ft or 7ft box blade with ease.is the 5740 2wd or 4x4.
will the tractor have enough weight to pull a 8' blade? It is a 4x4.
/ box scraper, what size #5
youll have enough weight with the loader on an 4x4 engaged.
/ box scraper, what size #6
I use a 7 foot Land Pride on my L5030 and it works really well. Mine is a medium duty and I wish I had gotten a heavier one as I am adding weight to it. The 7 foot sticks out past the tires and I have nicked a coupe of trees, I would be hesitant to go with an 8 foot model myself. I am sure your tractor would pull one though.
/ box scraper, what size #7
Is there much advantage to getting an 8' over a 7'? I know my driveway is wider than 8' so you couldn't just go down the middle and if you want a crown on your road would the help or hurt?
/ box scraper, what size #8
I pull a 6' with a L3830. Works great. I like the implements the width of the tractor. Makes for easy road building, etc.
8' is a big blade! It may be too big for many projects. If you are grading tennis courts, etc... a big blade of course would be ideal.
/ box scraper, what size #9
The only advantage for me at least would be in moving more material. I use my 7' or 10' pull behind on roads.
I just bought a 7' box blade as he didnt have an 8'. I traded in my 4' bush hog brand blade. Man they are more expensive than I remember.
/ box scraper, what size #11
What brand did you get and how much does it weigh? If you are doing much grading, are you getting top and tilt hydraulics for your 3pt?
I got a bush hog brand. I believe it is an sbx 84. It weighs 650 lbs and has six shanks. They took my old four footer in on trade. Paid me 100 bucks less than I paid for it five years ago. I do have a top n tilt already.
/ box scraper, what size #13
Sounds like your all set then. :thumbsup:
/ box scraper, what size #14
Hmmm; don't remember seeing any pictures...you know what they say...
/ box scraper, what size #15
B 2320 size box scraper? Can it handle a 60" or stay with the 48" ? Don't expect heavy use just driveway and landscape work.
I need to post some pics of the new tractor. Havent gotten to that yet. Made some tire chains for the front and need to upgrade the rear set. I need to split some wood tonite so I will get some one of these days that I have time.
/ box scraper, what size #17
Here is why it is hard to answer you. I believe Kubota recommends a 54" as max. That size isn't too common, so a lot of guys just move up to 60".
But, since everyone's soil is different and most every job is different, it is so hard to say whether that 60" will end up working OK, or be a source of frustration. That is a tough one.
I had a tractor that same size originally and that is why I had the 48" box blade. I would not go bigger than that. I had the 48" blade and that would work the tractor pretty good. I was using that for smoothing the driveway and a little bit a dirt work. I wish I wouldnt have purchased it after I had it. Tractor did not have enough weight for what I wanted it to do, and I wasnt asking for much. 48" is a big as you want to go.
/ box scraper, what size #19
Hey Alaska, thanks. That's very good information and supports my inner "voice" that tells me the same thing. I've yet to buy a box blade for my B2320, but my instincts, based on using all my other implements, tells me you are right. I think I'd spend the extra $50 on quality, not quantity.
There are variable here though, again. Dirt? gravel? sand? clay?
Also, tires filled? R1 versus R4? A lot of variables.
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
(5) Round Grass Hay Bales (A66408)
(5) Round Grass...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
2018 Freightliner Cascadia 125 Truck T/A Sleeper Cab Truck Tractor (A64194)
2018 Freightliner...
(INOP) 2022 MACK MD6 WATER TRUCK (A65054)
(INOP) 2022 MACK...
Peacock (A64557)
Peacock (A64557)
