Question on GL40 3PH
/ Question on GL40 3PH #1
DiverDarrell
Member
I'm looking at purchasing a G l3540 or 3940 and this is the first tractor i have seen with the hydraulics for the 3PH on the exterior. Has there been any maintenance issues or problems with the cylinders exposed like this?
Darrell
/ Question on GL40 3PH #2
I have tractors with both. Exterior cylinders have a couple more zerks. Interior cylinders are more complicated to rebuild, but you should only have to do this every 50 years or so. Philip.
/ Question on GL40 3PH #3
Darrell
Darrell,
I have a new Grand "L" 3940HST - took delivery in January 2010. I have logged over 165 hours with absolutely zero issues. The 50hr initial service was very easy to do myself and I have gotten some really good use out of the 3PH using a 7' boxblade as well as a 6' finish mower and 6' gill rake. Again - zero issues.
I don't believe you will have any issues. These are well built tractors.
/ Question on GL40 3PH #4
Had/have both and prefer the outside cylinders.
150 GALLON FUEL TANKS (A65643)
150 GALLON FUEL...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
2016 Freightliner Columbia 120 Glider Truck, VIN # 3ALXA7CG9GDGZ6492 (A65563)
2016 Freightliner...
2005 Polaris Sportsman 700 EFI (A66408)
2005 Polaris...
2022 EZ-GO ELITE...
