Oil & Fuel Fuel Gauge not functional
/ Fuel Gauge not functional #1
Stormtruck2
Mechanicsville, Iowa
02 JD 4600 FEL, 72 MM Mower, Cab
4600. Fuel gauge indicates almost full finally dropping to about 3/4s just as I run out of fuel. I replaced the sending unit and it still indicates the same. Anything besides a bad gauge to check? I hope its not a gauge, I believe that takes a whole new cluster to fix. Lots O dollars to do that. :mad:
/ Fuel Gauge not functional #2
My dad's 3720 has the same problem. There is a sensor that indicates fuel level in the tank that is known to go out. It isnt cheap to fix, about $200 so my dad just looks in the tank periodically to see how much fuel it has. Yesterday I started up the tractor and the gauge read no fuel but when I started feeding with the tractor the gauge went up to full then back to half a tank. The sensor itself doesnt cost much, the $$ is when the mechanics have to replace it, an estimated 2 hour job.
/ Fuel Gauge not functional #3
Found the way to see if it is the tank sensor or fuel guage that is bad for the 3520. Probably the same for 3720 but probably won't apply to a 4600 unless the empty tank vs full tank voltages would help. Since the fuel guage is part of the panel cluster it would be big $$$$.
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63689)
Greenworks...
CRATE OF UNUSED KUBOTA PARTS & BRACKETS (A64280)
CRATE OF UNUSED...
(10) MISC BEDDER PARTS (A63291)
(10) MISC BEDDER...
KBH 750 GALLON NITROGEN APPLICATOR (A63291)
KBH 750 GALLON...
JOHN DEERE 5075E TRACTOR (A63291)
JOHN DEERE 5075E...
1993 WhiteGMC WG Tri-Axle Dump Truck (A61573)
1993 WhiteGMC WG...
