At Home In The Woods
/ At Home In The Woods #2,532
As a fellow father, I will forewarn you to count to 100 or more when you come into a room that your child has decided that it needs some nice crayola stripes on the walls....They do make washable crayons but it is still frustrating. I've given up long ago on perfectionism.;):confused2:
Boy did that hit home!!!!
This morning my grandson (3) got my grandaughters (7) markers (washable at least) and redecorated the wall. Cant leave them alone for a minuet! :laughing:
I never had problems with my kids writing on the walls. One of my friends had the 'whiteboard' material installed on the lower parts of their kids playroom area. They could write on the walls all they wanted with the non-toxic erasable markers. Still not sure if that is a good idea or not... kinda teaches them it is OK to write on the walls. I don't believe they had a problem with them doing it outside that room though.
Do you think a side mount garage door opener would solve your downstairs overhead door problem? I just saw them for the first time the other day and they are pretty slick!!
Jim
Jim,
Looks like that might work. However, our basement garage door opening is 7 1/2 feet high surrounded by brick. If the tractor with the ROPS up
won't fit in the 7 1/2' basement garage door, then maybe my wife will have to park her car in the basement! :cool: Like that would fly.
Obed
Obed I think I would forget the HVAC guy. Have the electrician fix the electrical,easy fix, and get the plumber to fix the gas line,they normally do gas anyway.
MarkV
MarkV,
This morning the H&A guy replaced the Romex cable in the conduit with the single conductor wires. He found a leak in the gas line, fixed it, and put the line back on 15 psi test. A few hours later the pressure had not budged. If the gas pressure holds, we should have our certificate of occupancy re-inspection tomorrow. A different inspector will be coming tomorrow. I hope he only looks at the 2 items the other inspector said we needed to fix.
Obed
Today I went over our electrical plan in detail and tested every outlet for power and GFCI protection where appropriate. I just plugged something in each outlet to verify we had power; I didn't measure voltage. I did find a handful of things that need looking at. Tomorrow the electrical workers should be here to replace the keyless lights in the closets with the globe lights and fix the other issues found by the inspector and me.
/ At Home In The Woods #2,536
Obed it might be a little late but an outlet tester is handy especially when you have a lot of receptacles to test. You could have a polarity issue or a bad grounding connection and a plug in device would still work. This would be a quick way to identify any issue before the electrician goes away. Here is a good descriptin at Wikipedia. RECEPTACLE TESTER
I have really enjoyed you build thread and you and your wife have done a great job. You are almost there.:thumbsup:
/ At Home In The Woods #2,537
+1.
...and good luck with the inspection.:thumbsup:
/ At Home In The Woods #2,538
+1.
+2 from me.
Your local hardware store will have receptacle testers. There are two kinds generally available. One just tests the circuit, the second type has a button which can be pushed to test the functioning of your GFIs.
I always try to get the second kind, which is about $1 more expensive on a $10 item.
Yay!
attachment.php
/ At Home In The Woods #2,540
Congrats Obed! That's a major step and it's behind you.
2018 Chevy Traverse 3rd Row Seating (A61307)
2018 Chevy...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
AUCTION STARTS HERE @ 9AM (A62129)
AUCTION STARTS...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
18' Field Cultivator (A60462)
18' Field...
2025 METALIUM INDUSTRIES 14 T/A GOOSENECK ROLLOFF TRAILER (A60736)
2025 METALIUM...
