Tachometer for BX2200
/ Tachometer for BX2200 #1
rjmatt
Kubota BX2200
Hello everyone. I'm new to the forum, and new to ownership of a tractor. I recently purchased a used BX2200 with a bucket, MM 54" mower, and real balast box. I'm learning so much from this forum, so thanks for that.
Here's my question, Has anyone ever installed a tachomenter on the BX? I feel like I'm operating blind when running my mower because I don't know at what RPM the motor is running. A friend of mine has a JD and it has a tach on the dash with a indicator for the 'best' rpm when running the mower.
Maybe I'm being rediculous about this, but I have to think there's an optimal RPM for the mower, and I'd like to find it and repeat it each time I cut my grass. Suggestions?
/ Tachometer for BX2200 #2
Welcome to TBN:D
One popular model is the Tiny-Tach. If you search you should find some good threads on them...
/ Tachometer for BX2200 #3
In thick grass when mowing I put the throttle wide open, back off a little when it is thinner or near rocks. It is made to run wide open though.
David kb7uns
/ Tachometer for BX2200 #4
Dave is correct. Just a little bit under full throttle will give you 540 rpm on the pto. I once consdered putting a tach on my BX23, but I never did do anything about it. In time I learned to listen to the tractor. If it sounds like I need a little more throttle I give it a little. But if I need 540 pto rpm, I run it just about full throttle.
Thanks guys. This is just what I needed!
/ Tachometer for BX2200 #6
Agree with the others; did this on my BX2200 and rarely even bother looking at the tach on my BX2660.
/ Tachometer for BX2200 #8
I have a TinyTach, NEVER look at it, listen to the engine, it will tell you when it needs more. I mow with the throttle wide open, and just about everything else too including the tiller, snowblower, chipper, etc etc. :D
2021 Ford Transit 350 HD Reefer Box Van (A64194)
2021 Ford Transit...
Caterpillar 572E Tracked Pipe Layer (A64553)
Caterpillar 572E...
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
JOHN DEERE HX14 ROTARY MOWER, 3PT (A64278)
JOHN DEERE HX14...
1995 FORD F-SERIES S/A GRAIN TRUCK (A64278)
1995 FORD F-SERIES...
SEARS ELECTRIC AIR COMPRESSOR (A64276)
SEARS ELECTRIC AIR...
