Foam filled tires
/ Foam filled tires #1
afoster
Whitehorse, Yukon Territory, Canada
Bobcat CT335 with cab
I noticed in the CT335 operators manual that it states that foam filled tires are not approved for use on this tractor and will void your warranty. It does allow calcium filling of the tires though. I'm curious to know what the issue with foam filling is. My dealer didn't know. Does anyone have an explanation for this.
/ Foam filled tires #2
I dont know why, but I do know that if you ever had to replace that tire, getting that foam filling off would be a mother, it is tough enough on fork lift tires
/ Foam filled tires #3
Maybe the extra weight that the wheels turn will where out faster. In short
not built heavy enough.
/ Foam filled tires #4
Foam filled tires don't have the cushioning effect that air filled tires do. Even calcium or water filled tires have a 20% air pocket in them that provides adequate cushioning. I personally have run foam filled front tires on many CUT's without any noticeable change in front end component wear. It depends on the dealer and how they handle foam filled tires and warranties, typically the only way the manufacturer would know in a warranty situation is if the dealer told them.
Brian
Adams Nurse Trailer Tank (A63688)
Adams Nurse...
300 GALLON HYD OIL TANK (A64280)
300 GALLON HYD OIL...
Kubota M4700 (A60462)
iDrive TDS-2010H...
2019 21ft Forest River Salem Cruise Lite T/A Trailer, (A61574)
2019 21ft Forest...
2020 JOHN DEERE 770G MOTORGRADER (A63276)
2020 JOHN DEERE...
