BX Alternator kit installation (project)
/ BX Alternator kit installation (project) #21
I must have been cheated, because I didn't get a new belt with my kit. I still haven't installed it. Like fine wine, I am letting it age a little..... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ BX Alternator kit installation (project) #22
I'd like to echo my thanks as the directions helped me a great deal. The directions supplied by Kubota are worse than useless....they are dangerous.
My alternator on my Bx 2200 works great and I have no fear running 4 spots, wiper, defroster as well as flashers.
/ BX Alternator kit installation (project) #23
Make certain you use a lockwasher on the lower mounting bolt. Yup, I learned the hard way....
/ BX Alternator kit installation (project) #24
</font><font color="blue" class="small">( I must have been cheated, because I didn't get a new belt with my kit.)</font>
You must not have gotten the "deluxe" kit! /forums/images/graemlins/grin.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/tongue.gif
Actually, I just checked my pictures and found that mine didn't come with a belt either. (That's what Kubota told me to tell you!) /forums/images/graemlins/wink.gif
/ BX Alternator kit installation (project) #25
This artical was a nice addition to the instructions (term used loosely) that came with the alternator kit - especially the steps about cracking a couple beers, but it apparently needs update depending on which kit you get. I just installed the BX7310A kit for my 2004 BX23. It comes with different parts which address the problem Charlie had about removing the bushing from the alternator mount on the engine. This kit had the parts to do any of the BX tractors, but specifically had a special collared spacer which slides into the bottom alternator mount hole, adapting it for the smaller diameter bolt. Although Charlie found a bushing in the motor mount hole, the new engines in the BX23 apparently do not have that - I really looked closely - it has the smaller mounting hole and no bushing. The parts included work well to mount the alternator with the smaller diameter bolt, saving what I thought would be a painful step removing that bushing. Also, I did it without removing the cowl totally, just moved it as far forward as the brush guard would allow and lifting the side up (held up with a string) to access the bottom bolt and to feed the wires through the firewall. My kit had a spade connector that was slightly too small to fit over the starter/battery post and I had to round-file it to fit. They also shorted me the boot that goes over the alternator post, but I had one that did the job. They also shorted the alternator post nut, but the unused shouldered one that comes off the old regulator is perfect (who has a big stock of metric hardware around the garage?). The alternator is a tight fit - trying to retrofit a car unit, as one post suggested, might be a little tricky and probably not worth the hassle. The little relay that replaces the old regulator is used to disconnect the field (regulator input) when the tractor is off - perhaps the ignition switch wouldn't handle the current, or they wanted to meter voltage properly at the battery, so they went that way. The project is surely worthwhile - you end up with a real alternator instead of the permanent magnet dynamo and it's inefficient series regulator that comes stock - it's basically a larger unit of what rode against the tire on a bicycle. I used to see the light brightness change when I came off idle speed, but not now, and the battery charging voltage (14.50) stays almost constant (within 0.04v) when the lights are turned on. I feel the battery will get a full charge now. All set for a cab and radio!
Dave
/ BX Alternator kit installation (project) #26
Hi guys, alternator shown in pic is a Denso, aka Nippondenso. These units are OEM on Toyota's vehicles as well as other makes. Old unit is an A/C only unit with no internal diodes used for changing A/C to DC. The retification is instead done in the combo regulator/rectifier unit. This is why the old unit had more wires (3 phase AC) going from it to the old combo unit mentioned above.
cheers,
/ BX Alternator kit installation (project) #27
Yes, I had the same issue where they did not include the nut for the alternator output, but I also found that the nut left from the old regulator fit. They must intend on us using that one.
Also my 2003 BX-22 did not have the bushing either. Like you, I used the small bolt and collared spacer. I noticed others mentioned that kit as BX7310, but I also got the BX7310A, so the "A" kit must be the difference with the bolt sizes and spacers.
/ BX Alternator kit installation (project) #28
I Know this is an old thread, but I wanted to give credit to the original author Charliebrn, and updates by Electron8 and RichT. It has been raining here all day, so decided today was the day to get this upgrade done. Great information and pictures (also gleemed the Amsoil filter # SDF20) I sure it would not have gone as well without this great advice. I don't post very often here, cause I'm usually looking for advice rather than offering. Thanks again for a great install article.
Bob
/ BX Alternator kit installation (project) #29
I just finished the BX7310 Alternator upgrade to my BX1500. After dealing with Ronnie at tractorsmart.com and my local dealer, Kubota told both of them that the kit was not available for installation on a BX1500. No reason was given for why this was so, but at the advice of Ronnie and my dealer and after reading this thread quite a few times, I proceeded with the upgrade anyway.
I purchased all of the parts separately staring with the Kubota IG-L 40amp 12V alternator I found on ebay (the seller has quite few of these - NEW) for $90. Quite a savings than if I purchase new from the dealer. I then purchased all of the other parts needed from tractorsmart.com. Ronnie helped me identify all the parts needed. Grand total for everything came to $173 (shipping included). If purchased at my dealer, K2561-98620 kit (BX7310) cost $289 plus shipping, so I saved over $100.
I follwed Charliebrn's instructions. The only mod that had to be made was the lower mounting bolt (one that goes through the cast bushing) had to be trimmed by 3/8" as the end of the bolt was about 1/8" from the belt. I assume the cast mount on the BX1500 is a little smaller in thickness than the BX18xx or BX22xx. Also, I did not have a bushing inside the cast mount, as Charliebrn said needed to be removed. Other than that, everything else matched to a 'T'!
To ease my mind, I did not connect the charging lead to the alternator, as I wanted to test the output first. I fired up the BX1500, put my meter on the alternator, and whalaa, 17.2VDC, which is within the spec of the Desno alternator.
One last thing, as was mentioned in this post, my wiring harness kit did not come with the red rubber insulating boot or nut for the output lug on the alternator, as was mentioned in a previous thread. tractorsmart.com is tracking this down for me. Thank you Charliebrn, and updates by Electron8 and RichT.
Now, onto adding the lights!!!
/ BX Alternator kit installation (project) #30
Dealer just ordered me the bx 7310 high amp altenator upgrade kit for my 2005 bx 23 total price 183.00 be here in 5 days.... Now I can install two 55 watts forward and two rearward on two switches and not have to worry about killing my battery .. Cant wait dealer called back said I should have by thursday now yippee
/ BX Alternator kit installation (project) #31
What dealer did you just buy from? I cannot find anyone in Detroit area that can get the kit. I think I need to buy and ship to me.
/ BX Alternator kit installation (project) #32
Bought mine at my dealer
Roork's Farm Supply
163 RT 77
Elmer, NJ 08318
Phone # 1-856-358-3100
Part # bx-7310A High Capacity Alt
186.00
Hope this helps for anyone looking..
And yes they do ship ...
Be installing mine as soon as I recover from surgery
/ BX Alternator kit installation (project) #34
Ordered mine today for 199.00 at the local. You need to specify "whole goods division" as it is like ....well... a different division. They should be able to find in the inventory there.
Well twinstick, how did the install go? Where allt he parts there? Kind of wondering if I should throw in a fuse block while I am at it, just in the event I add additional items down the line. I would really like a power inverter along with additional lighting. I put one on my motorcycle (fuse block)and it made a big difference when I put in the twin lighter plugs, air horn relay, and some additional electical items. I soldered all connections and used molex plugins on the harness. Blue sea has a small weather proof box although I used the Centek AP-1 on my bike. Itwas a plug and play, juststrip back the wire and push into the fuse box.
I am sure I could find room on the firewall.
ANyway, I was wondering how you made out, and was concerned if you got the adapter bracket for the alternator mount.
/ BX Alternator kit installation (project) #35
tollster
Well the install was pain I did not take off the push bar just pushed it forward and lifted the side to get to starter (should have tacken it off) in the begining of this post someone posted step by step instruction on how to do thats what I used... I now have 4 - HELLA 55 watt model is a 8001 hard rubber mount flood pattern.. 2 front 2 back very bright .. Oh yeah kit does not include red boot for back of altenator. Still looking for one.. And yes all the parts were there, I opened box at dealer to make sure before I got home. It really is a very easy install if you take engine cover off. I actually tok off my hood thinking that would make it easier it did a little , it allowed the wright side to lift out some..
.. Mounted two switches wright under my stock switches on my bx 23.
Purchased inline fuses, switches, wire loom, at tractor supply.. Switches are 20 amp did not want to use relays. I ran the wiring down on the left side of the tractor and came up on the left side near radiator near stearing lines just take off nut for the bracket that holds line and it will fit threw firewall.. I will try to take picks tommorow.. As in the first post put fan belt on first it will not fit after altenator is installed pulley is almost touching radiator tank. total time for both installs was about 3 hours but worth it.. Inow have no fear running my light and i can really use my machine at night... Next I am going to add some stobes for top of light bar.. After reading your comment I think I will add a cig lighter in dash off battery as well .
Maybe after I will add a weather proof box will see on if I need to add anything down the line
/ BX Alternator kit installation (project) #36
Nice, good to hear it all worked out well for you. Kind of makes ya wonder why they did not include that from the get go.
So your saying to pull the front brush guard, and pull the front clip for full access? Then I should get te belt on before Iinstall the alternator? Ya may find one of those right angle boots at the auto supply store. Any other pointers?
Oh, here is a look at that fuse block I was speaking of I put on my bike. I know you already have most of your items installed, but its worth a look perhaps.
Centech Auxiliary Fuse Panel
Weatherproof molex connectors and such:
http://www.atcindus.com/categories.php?cat=10
/ BX Alternator kit installation (project) #37
Yes remove cowl will make it easier I was stubburn . Use lock washers on alernator bolts and you will use some of the parts you remove from your dymo it tellsyou in directions from kubota. The belt is the biggest pain cannot beleive its that tight. Other red wire that goes on starter you have to push threw the boot on starter it hard but it fits.. other then that just read the first couple of post in this thread thats what I did to make sure I was doing it correct it .. It really is idiot proof, I will checkout that web site you listed... Will check auto parts store tommorow for boot.. And yes you will see when you drop the alternator in put belt around pulley then install bolts I also left top bracket very lose so I had more room to get alternater in but if you remove cowl dont woory about it..
/ BX Alternator kit installation (project) #38
I was able to get the kit. As mentioned, I had to specifically tell them that it was a whole goods part. I removed the cowl and it was a breeze to install. I had to use the original top bolt as it did not come in my kit. Otherwise everything was there (minus the red boot on alternator). Easy install and did not take long. Worth every penny spent. Everyone needs this kit. My Meyer snowplow now does not drain the battery and I can now also add a winch kit, aux lights, and power plugs for my sprayer pump. Thanks for all the posts and info on this.
/ BX Alternator kit installation (project) #39
I was able to get my alternator Kit on my BX23 today, followed Charlie's directions and no issues. His instructions where 10x better the the ones that came with the kit. My kit also did not have the red insulation booty for the hot lead on the alternator. My bota dealer found a black one laying around and I modified it to fit.
I also pulled the bash bar and cowling for easy access and raised the bucket. Just took my timeand made it better than a factory install, thank you all and especially you Charlie for taking the time and posting, the pics are worth a 1000 words!
Tol
/ BX Alternator kit installation (project) #40
do they make a kit that will work with a b2910?
Kubota MX5400 land mgmt package
Kubota MX5400 land...
2021 John Deere 6120M Tractor (A63109)
2021 John Deere...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
COUNTY LINE 300 GALLON WATER TROUGH (A62131)
COUNTY LINE 300...
2001 Challenger 35 ton Flatbed Lowboy Trailer, VIN 1W8B21D261S000473 (A61166)
2001 Challenger 35...
