On a Carbureated Engine
/ On a Carbureated Engine #1
SandburRanch
NHtd75
with a constant speed governor, what is the carburetor throttle plate position at cranking speed? Fully closed - fully open - part way open - depends where the throttle lever is set - I don't know - I don't care - I didn't even know it had a throttle plate. Vote now.:laughing:
/ On a Carbureated Engine #2
All I've ever seen have been wide open. The governer controls the max RPM, not the minimum. If it started out at an idle, would it ever rev up.
/ On a Carbureated Engine #3
They are spring loaded to full throttle and the governer brings it back to operating RPM.
/ On a Carbureated Engine #4
Where you set it with the throttle lever because the governor speed is zero so it can't react to engine speed.
/ On a Carbureated Engine #6
My Gravely had a hand throttle that set the throttle plate position.
Ralph
/ On a Carbureated Engine #7
Generally, there are two plates - one controlled by throttle, and one controlled by the governor. So, with the throttle cranked WFO, the throttle place is wide open, while the governor plate modulates with load.
At least that's the way little motors work.
JayC
/ On a Carbureated Engine #8
Most I've seen have the throttle lever controlling the tension on the governor spring. More tension = higher speed.
Sean
/ On a Carbureated Engine #9
The throttle plate is controlled by the governor directly. The throttle control the operator moves is connected to a linkage with a spring, (or springs), that then is connected to the governor linkage. There aren't two throttle plates, when you move the throttle control to speed up the engine, you're just applying more pull against the governor's operating force allowing the engine to run faster. The governor is always trying to push the throttle plate closed, and moving the throttle control to raise the rpm causes the governor force trying to close the throttle to have to work harder to do so....because the throttle linkage and springs(s) are trying to pull the throttle plate open with more force than when the engine is idling.
When you raise the rpm by moving the throttle, you're just causing the governor force, (trying to close the throttle plate), and spring-loaded throttle control forces, (trying to open the throttle plate), that are opposing each other to "balance" out at a higher rpm.
2017 BOBCAT MT55 STAND-ON SKID STEER (A64279)
2017 BOBCAT MT55...
Challenger 65C/70C/75C/85C Tractor Parts and Service Manuals (A63117)
Challenger...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2015 Chrysler 300 Sedan (A61574)
2015 Chrysler 300...
2006 GMC C5500 4X2 BUCKET TRUCK (A59912)
2006 GMC C5500 4X2...
2021 Case 200 Magnum (A64119)
2021 Case 200...
