Wheel spacer
/ Wheel spacer #1
buckeyepost
central Ohio
Went to put my new tire chains on last weekend and they slightly run the inside of the wheel well on my Kubota B8200. I figure a 1" wheel spaver will do the trick but can't find any for the size I need. It's a 6 lug, 5.91 bolt circle diameter. I attached a picture from the manual. Oh, Kubota does make a 3" kit for $416.... overpriced and overkill for me. Any suggestions???
Thanks
/ Wheel spacer #2
That's just about the same cost on my L2800 :( do you have local machine shop near by?
/ Wheel spacer #3
Thanks
that is acually a pritty good price for two rear weel spacers, the steel alone is about half that price.
/ Wheel spacer #4
buckeye
Am wondering if the bobcat skidsteer wheel spacers will work.
I'm looking into them for the 6 bolt pattern of my Deere 4300.
eBay about $300 for 4 of them 2" space.
Bobcat Skid Steer 2 Inch Wheel Spacers 6 Lug (x4) - eBay (item 110618473119 end time Dec-30-10 06:05:54 PST)
I'm interested in the spacers to give a wider stance.
As far as tire chains go, I made my own to fit higher on the tire and stay further away from the fender. i.e. longer side chains and shorter cross chains. They ride in the dip at the ends of the R-4 lugs, as seen here. Good clearance that way.
/ Wheel spacer #5
I did this last spring for my Jinma 35 hp wound up making them myself. Local machine shops want $500 - $1000 for front and rear, way over my budget. I did have a buddy turn the pilot bores for me and I had to buy new studs and wheel nuts probably had $200 in materials. My reason for the spacers was row cropping spacing. Now if I can just get the tractor lifted to clear the crops for cultivating. bjr
/ Wheel spacer
There is a local guy that might be able to make me something, I was just checking here first to see what my options are.
Beenthere, are you going to use all 4 spacers if you get them from ebay? I would be interested in splitting the cost with you because I only need the rears. I emailed the seller my specs to see if they'll fit.
Thanks for the help guys.
/ Wheel spacer #7
buckeypost
I would be interested in a split.
But first need to find out the spacing to see if they mate up. Hope to learn that tomorrow when I stop by my Deere/Bobcat dealer.
/ Wheel spacer #9
I wanted spacers for my 2400. Got a sheet of シ" steel plate, and a section of 8" schedule 40 pipe. Drew a pattern from tracing the wheel bolt/hole pattern off my rear wheels and had the local machine shop cut me 4 discs. Cut the pipe to the desired spacing and welded it up. Total cost under $200 and would be half that if I had the scrap parts lying around.
/ Wheel spacer #10
Thanks Texasmark,
I am not that handy with welding although I have a friend who can weld. If the aluminum does not work out I will go this route. Very good idea.
Thanks again.
Steve
/ Wheel spacer #12
Try this site. Made by BORA and a little salty at $300.00 including shipping.
Wheel Adapters, Wheel Spacers, Hub Rings, and much more! | Motorsport Tech
Steve
I wouldn't give Motorsport Tech the time of day. I had ordered a set of their steel spacers in March of 2018, got the run around for over 2 months before the spacers arrived in May only to have the wrong ones arrive because of an error on their website (they sent me front ones instead of rears). Throughout the whole time waiting I would call every week or two weeks and sometimes I would be told they were being made and almost done, other times I would be told they hadn't been started yet. Got the run-around on the replacements until August when I finally got fed up and had him refund my money.
Save yourself the headache. Email Bro-Tek. Richard at Bro-Tek is A++ for customer service. Just confirm the dimensions for bolt spacing and hub diameter with him when you order. Some of the Mahindra tractors are different than others. My spacers took a little longer because they had to locate the correct tractor model and get the measurements before they made my spacers.
/ Wheel spacer #13
Bro-tek.com has all of these spacers, bounce them an email. Richard@bro-tek.com
Even if Bro-Tek doesn't have them listed on their site they can likely still make them. He made me spacers for my Mahindra 2655 and I am very pleased with Richard's service.
/ Wheel spacer #14
Thanks Texasmark,
Thanks again.
Steve
I'm not either somehow I manage to get by. Grin
/ Wheel spacer #15
Thanks all,
I had never seen anybody mention Bro-Tek and found Motorsport. When I ordered from Motorsport they shipped them right away and actually delivered early. With their life time warranty, to me, it was a good bet.
Thanks for the info and Ill refer my tractor friends to check out Bro-Tek.
Steve
/ Wheel spacer #16
on many tractors, you can just install the wheels backwards and gain a few inches, this is only if the rims don't use tapered lug nuts..
/ Wheel spacer #17
Thanks for the info. I work on a hilly area and needed more than a few inches. I bought the Motor Sport 2.5" spacers and they work like a charm. No jitters when mowing on angles :cool2:
Steve
/ Wheel spacer #18
Steve
I thought the ones from Motorsport Tech would be great too but when they can't deliver as promised and give a different story every time you call it makes it kinda hard to judge how well their spacers work. At least you got your spacers and are happy with them. After my experience with them it was a breath of fresh air to deal with Richard at Bro-Tek. His customer service is top notch and the product is well made and fit perfect.
Skid Steer Mount 3pt Adapter  (A62679)
Skid Steer Mount...
Good-Year Tire / Farm Tractor Parts (A62613)
Good-Year Tire /...
CATERPILLAR D8T CRAWLER DOZER (A64279)
CATERPILLAR D8T...
John Deere 4960 (A64126)
John Deere 4960...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
2020 KENWORTH T60 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 KENWORTH T60...
