Dirt Pile vs. 4120
/ Dirt Pile vs. 4120 #1
om21braz
Lexington, NC
Was going to do a little filling in some low spots in the yard today. It was a little warmer than it had been and sunny. Placed the tractor in 4WD, lowered/leveled bucket and proceeded into the pile. The tractor comes to a dead stop, then front end raises a little. Tried again, Oops! Frozen dirt pile! The dirt won today, but there's always tomorrow LOL.
/ Dirt Pile vs. 4120 #2
hose frozen dirt piles are sure hard to dig into. Where did you attempt to scoop? At ground level? half way up? Having a slight tilt to the bucket and going in about at ground level will pry your bucket in and you can loosen up the soil. Its worth a good try. :)
/ Dirt Pile vs. 4120 #3
Yep its that time of year :( weather station saying warming up for you folks down there,but mother nature decides to thaw or not to thaw. ;)
I attempted about as you note ground level/slight tilt on bucket. It just wanted to push bucket up the side of the pile. A toothbar would probably make a big difference. If I attempt again soon, swapping out to the pallet forks to loosen things up a bit might help to start?
case 370 glass door never installed (A61307)
case 370 glass...
2014 Tennant ATLV 4300 All-Terrain Litter Vacuum (A61572)
2014 Tennant ATLV...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - Tier 2 - Irrigation Takeout (A63689)
Kubota V3600-T-E2...
Bobcat Skidsteer (A60352)
Bobcat Skidsteer...
NEW WATER PROOF/FIREPROOF FIRST ALERT SAFE (A64281)
NEW WATER...
2016 Kawasaki 62Z7 Articulated Wheel Loader (A61572)
2016 Kawasaki 62Z7...
