Drive loader up the side of a pile
   / Drive loader up the side of a pile #11
Depends on how much brush is in that brush/dirt. If it's mostly dirt and it's solid dirt, maybe its ok. If it's mostly brush then it would seem pretty sketchy.
I pile brush with the loader. I keep the loader low until I'm at the pile, and lift it just to dump the load (from a grapple, and I don't mix dirt and brush). The approach to the pile needs to be level or nearly level so there's not a risk from lifting the loader high.
Even if it does not collapse and dump you and the tractor, or get the tractor stuck, there's the risk of a limb or stick damaging the tractor. On the underside of most tractors there's a lot of exposed linkages, hoses and wires with zero protection.
No one's not going to tell you to do all kinds of stuff that's dangerous. You have to think out what the risks are beforehand. Keep in mind that the tractor's side to side stability comes from the rear axle (the front being on a pivot). Don't raise the loader up high unless the rear tires are on level ground. Go slow and stop to think if it feels sketchy.
This, exactly.
   / Drive loader up the side of a pile #13
I do this to a slighter degree, driving maybe 2' or 3' up the pile while raising and dumping. Since it violates the idea that you shouldn't drive on uneven ground with the FEL high, it feels sketchy, so I only do it to this smaller degree.
My strategic vision is to gradually do this further and further until I tip the machine over backwards and destroy it, undo the seat belt, crawl out, replace the machine, and from there on out do it somewhat less far.
   / Drive loader up the side of a pile #14
I’ve been doing it for many years with no problems.
Ever work in a processor gravel pit?
As long as what you are climbing will support the weight, it is perfectly safe.
Spent years in a gravel yard, of course gravel is different. It was a daily part of the job, in between loading trucks, dressing up/compacting the stockpiles.
   / Drive loader up the side of a pile #15
:ROFLMAO::ROFLMAO::ROFLMAO:
Thank you for this.
I do something like this fairly often, well i guess often while im building big piles, which isn't all that often. I typically use my box blade as loader counterweight so the limit of what i will drive up is my 'departure angle', or the angle where i can't keep my box blade from digging in even thought it's lifted all the way AND tilted all the way forward with the top link. I feel like that's over 30 degrees but i can't find a pic showing it right this second.
One thing i will point out about a box blade, is you can actually shape up a pile pretty easily with one while pushing backwards, because the 3pt does not prevent the box blade from pushing upward, so when you push dirt into/onto a big pile while reversing with the box blade, it tends to naturally ride up as the resistance of the pushed dirt rises. That will give a nice taper and let you push stuff up the side of a pile without having to manually mess with your 3pt height. Just back up until you're at the top of the pile, then drive off and do it again, and it will naturally push the bottom of the pile to the top in a nicely increasing slope. Assuming the pile isn't already super steep when you start. So it's more for gathering a mess into a nice pile, than doing something with an already existing pile.
If you have a really hard pile and a small tractor that can't break into it well, you can also back up the pile and drive down it with your rippers down and then turn around and load it with the loader. I've done that with an old pile of hardened asphalt millings before.
1999 Dodge Ram1500 ST Ext. Cab Pickup Truck (A56858)
1999 Dodge Ram1500...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
24017 (A56859)
24017 (A56859)
Mini Margaritaville Truck (A55853)
Mini...
1986 VIM TACK TANKER TRAILER (A58214)
1986 VIM TACK...
2015 Chevrolet Express Box Truck, VIN # 1GB3G3CG3F1110762 (A57453)
2015 Chevrolet...
