Comparison buying new, Deer vs New Holland?
/ buying new, Deer vs New Holland? #1
donlo
Canfield OH
ford 3000 JD5095M, 1500kabota, ford 600
Ok guys I know this maybe the wrong forum for this, we have ALWAYS been Ford people, trucks and tractors,,
But now we need a little bigger tractor ,, and after months I have it narrowed down between a NH Td 5050, and a JD 5095M
same horse, both with cabs, JD has 32 frwd 16 reverse,, NH 12by12,
NH has bigger tires front and rear,,
JD has beefier looking lift for the 3 point lift arms,
JD priced about $4000 HIGHER,,
JD built in GA,,well assembled in GA,,,,NH in Italy,,,
can anyone give an unbiased opinion?
when we buy a tractor,, we usually have them for life,,hopefully thats a LONG TIME YET!!!!!!!!!!!!!!!!!!!!!!!!!!!!
/ buying new, Deer vs New Holland? #2
I wish I could be unbiased but can't. I went blue. Mainly because Green didn't have a front mount blower and also price. Don't think you can go wrong with either one.
/ buying new, Deer vs New Holland? #3
What are you going to use it for? Do you need the bigger tires of the NH? The more forward gears of the JD?
/ buying new, Deer vs New Holland? #4
What are your opinions of the JD and NH dealers?
I know this isn't true for everyone, but my comfort level (or lack thereof) with a dealer often helps me make a choice.
Steve
/ buying new, Deer vs New Holland? #5
I own a TD5030 open station that I bought this year. I am very happy with it. I have no doubt that John Deere has an equally good model that I might be happy with as well. What led me to New Holland was the dealer. I am confident that my dealer will do what it takes to resolve any problem that I may have with my purchase. He also has very knowledgeable sales/service staff.
I guess my suggestion is to start with researching dealers.
/ buying new, Deer vs New Holland? #6
It depends where you are.
Around here (Southern Oregon) as I drive around and look, there are a few older Fords, but almost no New Hollands. A lot of Deeres, and a few Kubotas. If you want to be able to get reasonable resale value here, go for the Deere.
Other places may be different, but buying what is most popular locally is always a good plan.
Every time you drive through the countryside you get a chance to do your own survey.
/ buying new, Deer vs New Holland? #8
Ok guys I know this maybe the wrong forum for this, we have ALWAYS been Ford people, trucks and tractors,,E
if you want to i can give you more info and comparison of the two tractors, and actually the Deere 5093E is close in comparison than the M series
/ buying new, Deer vs New Holland? #9
I wish I could be unbiased but can't. I went blue. ..... and also price. Don't think you can go wrong with either one.
yep.. that ground up ca$h they must use for the paint pigment has always kept me away from them.
I agree.. both would be capable machines.
good luck
soudnguy
/ buying new, Deer vs New Holland? #10
Cannot answer without bias. Have had relatively few issues with M series tractors. Love the wet clutches. Much improved over dry clutch system. Good tractor.
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
John Deere 5525 (A60462)
John Deere 5525...
Miscellaneous Item Pallet (A59317)
Miscellaneous Item...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
SANY SY50U EXCAVATOR (A59823)
SANY SY50U...
