Log splitter, Warming up????
/ Log splitter, Warming up???? #1
Big Wave D
Kubota L35, Kubota B6200E
Not sure what area to post this under, so I'm going with this one. It is an 'operating' question, just not about a tractor per se.
I have a TSC/Speeco self contained log splitter. It doesn't have a heated home.
Until now, when I've used it, the temps have been rather mild, 45+ degrees. Now, the weather has turned to truly winter temps and the highs are only in the low to mid 20's.
So, how is the best way to warm the hydraulics of it up? Or, do I even need to?
If I do: Then do I want to start it and just let the engine idle with the pump just bypassing? Do I want to run the engine at operating RPM and still just let the pump bypass? Do I want to idle the motor, but run the ram back and forth with no load? Same as before, but with increased RPM? Do I just start it and go right to splitting?
How all do you handle 'warming' your log splitters? Love to hear your methods and reasons for doing so.
Thanks
/ Log splitter, Warming up???? #2
I have a 22 ton from TSC and I start it and get right to splitting. Just might want to take into consideration what type of fluid you are using as some are not good for winter operation.
Happy Splittin !
When I bought the splitter, it was on sale. Part of the sale was that they prepped it for use, supposedly a $40 value. I figure they used what ever they sell out of the store.
Sadly, I don't know what they used for certain concerning the hydraulic fluid. When I check the fluid level, it is a very light, honey color. It doesn't seem overly thick on the viscosity scale.
/ Log splitter, Warming up???? #4
I am a big fan of warming up my splitter first it has a 12 Hp Honda on it. After the engine has run a few minutes I will cycle the ram. Seems to work fine for me. Although we don't get that many long cold spells here in the rainforest of Seattle.
And I give it a few minutes cool down period after splitting for a bit. Just the same as when I am out using my chainsaws.
/ Log splitter, Warming up???? #5
I just start mine and give the engine about a minute at high idle to get the oil flowing. Then it's full throttle and start splitting. Done it this way for years at very low and very high temps. No problemo. I say start her up and have at it. :thumbsup:
/ Log splitter, Warming up???? #6
I do the same, idle for a minute or two and then start splitting. :thumbsup:
Alrighty then.
I won't go overboard on the warm up period when it comes to splitting wood in the colder months of the year. Seems like most people are saying that they want the engine warmed but aren't to concerned to much about the hydraulics. They'll come up to speed with use just fine.
Thanks to all for your 2 cents on the subject.
Mousefield,
Do you paint the bucket on your back hoe to keep it looking so nice?
Mine still has some paint left, but it only starts to look nice again with an extended period of digging, otherwise it sports a nice rust patina. :laughing:
/ Log splitter, Warming up???? #9
When it's cold and you've had to pull that dang cord 20-30 times to get the motor to fire up, you won't give a *$%#! about the hydraulics! By the time you get your wind back, the engine will be running smooth and ready to go. :laughing:
/ Log splitter, Warming up???? #10
That's why I like the Honda engine. I've not had to pull more than twice on that thing yet to get it started...:thumbsup:
/ Log splitter, Warming up???? #11
Mousefield,
Still the original paint. :) Have used it to dig up some stumps and dig a couple of trenches, one was at the neighbor's, about 300 ft, 2 ft deep and very gravely. I'm sure gravely is a proper word. :D
/ Log splitter, Warming up???? #12
Ever try it at 30 F BELOW zero? Post back and really brag after you do that ;)
/ Log splitter, Warming up???? #13
I don't know about -30 but Honda engines start very easily. Big thing for me.
I bought a TSC/Speeco splitter this summer, 22 ton. It came with the Briggs motor on it. I could have ordered a Honda fitted splitter, but I think the price was around an extra $100+.
I don't usually try to make a habit of splitting wood in the dead of winter. So, I wasn't real concerned about cold weather starting. Well, I am trying to get a massive oak tree parceled up and split, just because I'm sick of looking at in my my barn yard. It had fallen onto a friend's business rental due to a tornado passing overhead.
Anyway, I'm sure Briggs isn't really much more than a shadow of its former self, but so far it has ticked along quite nicely and even starts without struggle when the temps are in the Teens and Twenties.
That little primer bulb has been a nice addition to the modern small power plant.
/ Log splitter, Warming up???? #15
If it gets to 30 below here in Seattle H--L will have frozen over..And my hairy little Hiney is smarter than worrying about splitting wood then anyhow. :D
/ Log splitter, Warming up???? #16
I purchased a splitter made by Swisher because it has a belt driven pump that you can disengage until the engine is started and warm. It makes tugging on the rope a lot easier when cold.
I would not recommend using my neighbors method. He puts a pan of carcoal under his to warm it up. True story. He can't start it under the load of the pump with cold fluid.
I would not recommend using my neighbors method. He puts a pan of charcoal under his to warm it up. True story. He can't start it under the load of the pump with cold fluid.
Okay, the disengaging pump thing is a nice touch. I can see that on a higher end splitter.
About your neighbor, I'd say he is running something way to heavy for hydraulic fluid if he's having to go to that kind of extent to just even start the thing.
Mine pulls somewhat what harder, no doubt, with the cold, but he's off the charts. :confused2:
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
2007 Mack CV713 Granite T/A Pole Truck (A62679)
2007 Mack CV713...
2013 Mack CXU613 T/A Day Cab Truck Tractor (A61573)
2013 Mack CXU613...
1996 Vermeer V-3550 Ride-On Trencher (A61572)
1996 Vermeer...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A62679)
2011 Autocar ACX64...
