Snow Rear wheel traction in snow
   / Rear wheel traction in snow #11
Just got my 2010 3520 about a month ago and I love it. My question is if I push snow is my 450 lb. scrape blade enough weight to get decent traction to the rear wheels. I don't want to fill the tires because I got this tractor for overseedeing, aerating and other work in and around lawns and I don't want to leave any tracks. The terrain around my neck of the woods doesn't have the slope issues I've read about in other posts. Thanks for any input.
Although 450 lbs is relatively light, the only way you know what works is to actually try it.
I suspect you'll want more traction, which might be a ballast box or might be chains.
Try moving snow without either...you might do quite well....or you might need a bit more.
Good luck!
Yes, I'll probably just have to try it and see what happens. Thanks for the info.
   / Rear wheel traction in snow #13
I assume you have Turf Tires? If so, you will be fine in the snow, but adding another 500lbs will make it push ALOT more.
If you can keep the ground bare where your tires run, you'll be amazed how much snow it will push. The weight is just ridiculous, as to how much more it will push with added weight.
I have R4's on my 2520 and they are the worst tire ever in Snow. The Turf's I had on my old 2210 did much better in the snow.
   / Rear wheel traction in snow #15
With R4's, you will want all the weight you can find. They do fine, but if there is any ice at all, or packed down snow, they slip and spin alot. The worst is that they have NO side-traction at all, so if you are on an incline to one side, you will immediately end up at the bottom! :laughing:
Mine really made me mad at first, but I know what they will and won't do now, so I don't try to do alot with them in the snow. :laughing:
They work awesome in all other conditions, but they are slippery in the snow. :mad:
   / Rear wheel traction in snow #16
It would be expensive, but if you're really considering driving a mile to move snow, it might be worth it to get a set of turfs....
I keep the backhoe on my SCUT for rear weight, and the turfs have never let me down yet. I have chains, but have never felt the need to put them on.
I am blowing from the front, however, rather than plowing/pushing; Im sure that makes a difference, too.
   / Rear wheel traction in snow #17
Thanks for the info. I didn't think about chains doing damage to driveways but you're right in that I should ask. What type/style chains should I get? I've looked into a little bit. I know one thing I sure don't want any part of the chains flopping around doing damage to the fiber fenders. I could see them getting beat to death with a wayward chain. How much weight will a ballast box hold?
Chains are your answer.
These don't flop around, and they work very well.
   / Rear wheel traction in snow #18
Here are the chains I have. They have DOUBLE the cross bars, because the cross bars want to fall in between the lugs on the R4 tires. Mine have V-bars on them, and EAT the driveway! lol
They are insane in the woods, I use them for skidding logs out! :thumbsup:
The tensioners keep them from flopping at all, and they have NEVER touched my fenders yet.
Do you have any trouble with the chains falling inside the treads thus making them ineffective?
   / Rear wheel traction in snow #20
you could do a search for screw in studs.I think you get 500 for around 200.00....no damage to fenders
Be sure to use Google's SafeSearch feature when searching for "screw in studs". :thumbsup:
It is in the Search Settings before you click the "Google Search" or the <:eek:> "I'm Feeling Lucky"<:eek:> buttons.
John Deere 644G Wheel Loader (A55272)
John Deere 644G...
2011 John Deere 5085 70HP Utility Tractor (A55973)
2011 John Deere...
Case skid steer wheels and tires (A56435)
Case skid steer...
2013 Ford F-150 Pickup Truck (A56858)
2013 Ford F-150...
2009 INTERNATIONAL 9200I TANDEM AXLE WRECKER (A58018)
2009 INTERNATIONAL...
2018 KUBOTA SVL75-3 SKID STEER (A52709)
2018 KUBOTA...
