Snow Rear wheel traction in snow
   / Rear wheel traction in snow #1
LHS Inc
Gold Member
Eastern Shore, Maryland
JD 3520 eHydro w/300CX FEL
Just got my 2010 3520 about a month ago and I love it. My question is if I push snow is my 450 lb. scrape blade enough weight to get decent traction to the rear wheels. I don't want to fill the tires because I got this tractor for overseedeing, aerating and other work in and around lawns and I don't want to leave any tracks. The terrain around my neck of the woods doesn't have the slope issues I've read about in other posts. Thanks for any input.
   / Rear wheel traction in snow #2
My Gravely with only 2 wheels driving it wasn't worth a darn in the snow, to push its 4' wide snow plow. Had to use either chains on the 2 wheels or put on the dual wheels.
My 4010 is great in the snow with turf tires and 4wd. It has loaded tires. I've FEL in front and back blade in the rear.
My driveway does not have much slope. There's a small rise about 1/2 way along it.
Ralph
I failed to mention I have the 300CX FEL on my 3520 MFWD. I did think about chains for the tires but the filled tires aren't going to happen. We don't have that much snow in a normal winter here in Maryland altho we got hit hard last year by three big storms. I did tell one of my lawn care customers about my tractor and they asked for a quote for snow removal. Its about a mile from where I live so I could drive there with out any problem. I just need some insight on what I might be getting into.
   / Rear wheel traction in snow #4
You should be OK. Four wheel drive will help a lot. If you still have problems chains make a great big difference. Be aware that there are different types of chains.:D
   / Rear wheel traction in snow #5
chains and a balast box on the back would help.I hate loaded tires also.I do a bunch of driveways and they don't want chains in them.to much damage.might want to ask before you give out quotes
Thanks for the info. I didn't think about chains doing damage to driveways but you're right in that I should ask. What type/style chains should I get? I've looked into a little bit. I know one thing I sure don't want any part of the chains flopping around doing damage to the fiber fenders. I could see them getting beat to death with a wayward chain. How much weight will a ballast box hold?
   / Rear wheel traction in snow #7
I was working on a DIY ballast box this weekend. It is an old salt tank and I put 8 60lb bags of sakrete in it. If my calculations are correct I should have about 480 lbs. back there. I also dropped in an old rotor from a 1/2 ton pickup and plan to put a few weights on top of the sakrete if necessary. I have about 12" of room left.
   / Rear wheel traction in snow #8
I would think the heavy blade on the back would give you good enough traction if conditions are not too slippery or uneven.
In order to snow blow or plow my driveway and trails I needed not only the 500lb snowblower and loaded rear tires but chains on the back tires and the front tires.
Weight along is not enough for traction where I live. I would think non-aggressive two link chains would be OK on pavement and client driveways.
I have very aggressive v-bar chains on the front and back tires and they make a mess on hard services. Check out what's available at tractor tire chains for farm tractors
   / Rear wheel traction in snow #9
you could do a search for screw in studs.I think you get 500 for around 200.00....no damage to fenders
   / Rear wheel traction in snow #10
I've got 500 lbs in rear tires and like another 500 for ballast. I would buy a backhoe, best ballast I ever found for mine. I have tire chains but I don't run them, actually I hate running them, with wide flat tires they make it ride like old Iron wheels, no fun, especially a mile on hot top.
TANK SEEDER (A58216)
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
Magnum 4000 Series Hot Water Pressure Washer (A55272)
Magnum 4000 Series...
SHOPBUILT T/A BUMPER PULL TRAILER (A52708)
SHOPBUILT T/A...
ARGO 6X6 FRONTIER ALL TERRAIN BUGGY (A52708)
ARGO 6X6 FRONTIER...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
