Snowblower need help setting snowblower
/ need help setting snowblower #1
ihuntbear
Gold Member
new brunswick, canada
2015 tym T554 and 1999 Kobota m4700
I have a new normand snowblower.we had our first snow this past weekend.When I was snowblowing I noticed it was pushing snow with very little coming out the shoot.I checked all shear pins ,Nothing broke.everything turns but leaves a pile of snow when I stop.Is there something wrong with the way I installed it.Do i need to angle it more to the back or more to the front.This thing is p##sing me off
/ need help setting snowblower #2
A pic or two would help come up with a solution, or a question or two. :)
Sounds like the auger isn't working, but suspect might be something else (or just not enough snow in front).
Keep us posted.
looking into the blower the auger turns, impeller turns ,snow just seems to be pushed ahead instead of going into the box or augers.I talked to the dealer again,he wants to see it,He thinks it might be the clutch and want to put a dyno on the pto.This tractor just had its first lub change,hard to beleave the clutch is going bad.Not the trans clutch but the hyd pto clutch
/ need help setting snowblower #4
check your shear pins? both the auger and the fan. make sure the heads and nuts are actually attached to the bolt. its possible for the augers to turn even if sheered they'll just slip under load. if snows going into the fan area and not being thrown thats where id look first.
I assume this is a new blower? a warn blower can sometimes have extra clearance between the fan and shroud causing throwing problems.
did you run any other pto attachments like a Bush hog? how did it work? first oil change is pretty early for the pto clutch to be gone...
/ need help setting snowblower #5
I candidly hate to even suggest what I am about to tell you UGH!!!!, But as the open auger is pushing the material out and you have no snow being spanked and thrown over the cliff and left for dead so to speak :laughing:
The little brat is running backwards; Its entirely possible you may have been saddled with a front mount REVERSE drive P.T.O., snow blower.
The quick way to check is paint a large dot on the last portion of ribbon near the center of the cross auger and if the dot travels inward when you start the rear P.T.O., at a low engine speed-low idle speed when its empty, its running backwards.
Whoopsie!!!
This is worse than lefty, loosy, righty, tighty, on army six by sixes UGH!!!
One sure way to tell is to do the following,
lower blower on the ground or the shop floor;
clear all the snow out of the blower and chute when the tractor is shut down
and the PTO IS OFF!!!!!, Then disconnect the P.T.O shaft from the gear box and the tractor and set it aside out of the way to avoid tripping over it.
Now after this is all done-
you will able to do the following rotate the cross auger by pulling it towards you with a pipe wrench or chain wrench on the cross auger shaft.
depending upon the position of the exit point from the impeller drum being left or right-
right side exit from drum- would require the load side of the impeller to rotate counterclock wise to discharge snow out of the auger housing when the cross auger is turned inward
left side impeller exit point would require the load side of the impeller paddle impeller to operate clockwise when the auger is turned inward
IF the rear mount PTO is used; the gear box is is set up to rotate to the left which would require a reverse gearbox for a front mount; left, right, dizzy, HA,HA.
If the auger is rotating inward and the impeller does not lead to the chute opening with the load side of the impeller paddle-not good for the home team
Whoopsie
:mad::confused:;):eek:
ME thinks you may have a front mounted snow blower hiding as a rear mount snow blower. WHOOPSIE!!!!!
Option 2 which is also entirely plausible in that-
you have a sheared key in the gear box, or one or both of the sprockets for the chain drive rotating the cross auger.
The impeller paddle shaft has sheared its key but the cross auger is still functioning, as the spur gear is still rotating the chain until it encounters a load of snow where the cross auger is filling the housing and the snow is simply being pushed in and out of the auger housing.
option 3 is the PTO is not fully engaged on the tractor which is also possible.
/ need help setting snowblower #6
Did this snowblower work ok last winter when you posted that you bought it?
Or did it just start this winter blowing poorly?
2-01-2010
http://www.tractorbynet.com/forums/buying-pricing-comparisons/162559-montana-vs-mccormick-2.html
/ need help setting snowblower #7
If the snow is that heavy 'snow man' wet snow, that can happen.
I have had wet snow bunch up for as much as 10 feet in front of my blower without any getting blown out the shute and then it suddenly gets shoved into the fan and generally then clog up.
That is the nature of wet snow blowing.
Often a 3 hr wait or 3-4 degree drop in temp and all is fine.
Is that your situation?
wasn't able to use it last year .Recovering from shoulder and arm surgery.I droped it off at the dealer tonight hopefully they can find the problem
/ need help setting snowblower #9
ihuntbear
That was a bummer...not only didn't get to give the new equipment a run, but laid up with surgery too.
Hope that didn't interfere with the bear hunting (too much).
/ need help setting snowblower #10
I was going to say that it sounds like it is running backwards but, leonz was all over it.
Sounds like it's running backwards, for whatever reason.??
Could be that the shear pin is broke and won't run under a load, too.
Let us know, for sure.
/ need help setting snowblower #11
I agree with others, it certainly sounds like it's going backwards. Since the impeller is essentially an axial fan, I find it easiest to tell if it's correct by observing the rotation of it: it should rotate toward the exit hole.
See my fine artwork below.... (no, those aren't smiley faces!:laughing:)
Hope yopu get it fixed soon- won't be long now!
no bear hunting only starts in april.I was good to go but the snow was a gone by then
just got off the phone with the dealer.He thinks the pto wasn't engaging all the way.
He's going to put it threw its paces today.What ever that means:confused:.not enough snow to do that:confused:
good news it was in the switch .something about not enough amps going threw to engage all the way. all fixed:thumbsup::thumbsup:I talked to one of my neighbours today which owns a new kbot,same issue.so I quess it doesn't matter what color we own everything has its defects
/ need help setting snowblower #15
Hey, glad you got it fixed!
But I'm confused... I always thought a PTO was either "in" or "out," no in-between... how's that work on your set-up? (Just curious, perhaps another chance to learn something!)
they told me the switch was defective and wasn't putting enough power to the relay.I thought the switch controled the hyd valve which engaged the hyd pto
/ need help setting snowblower #17
My Yellow MF has a soft start feature on the PTO.
Wet snow doesn't like to blow, so I just let it freeze over night. But then again there are all kind of different scenarios for snow.
Gehl RS6-34 (A64119)
2019 Caterpillar D6N LGP Crawler Tractor Dozer (A66734)
2019 Caterpillar...
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
2011 CATERPILLAR CB434D DOUBLE DRUM ROLLER (A65056)
2011 CATERPILLAR...
2020 FORD F-150 XL CREW CAB TRUCK (A65054)
2020 FORD F-150 XL...
PORTA POTTY (A68842)
