Home made Grapple
/ Home made Grapple #21
The guys that have grapples, how long are the tines and how thick are they. I'm wanting to order the material next week so I can have a winter project.
3/8 inch is fairly standard for a typical light duty CUT grapple. Length will vary with design but close to 32-36 inches is a rough guess. I'm figuring the measurement from the back of the grapple to the tip and part of that would be the rear frame.
You can figure measurements from the photos below if you calculate based on the standard skid steer plate dimensions. If you need accurate figures let me know.
/ Home made Grapple #22
Measured bottom grapple tine from tip to surface of quick attach plate: 32inches. 3/8 mild steel. Upper grapple arm is about 24 inches from mount to edge. Frame is 3x3.
/ Home made Grapple #26
millwrightdude said:
I was thinking about making the tine 1/2 x 3
1/2 may be overkill but 3 might be a bit small. I will need to measure but I think mine is 3/8 x 4. Some guys like half inch on the sides but I would put extra steel into an extra bottom tine or gussets for support .
My grapple has curved bottom tines which would be easy with CAD and CNC. I don't understand why more grapples don't use them as I see no advantage to straight except ease of building. That should not be such an issue with computers doing the cutting.
/ Home made Grapple #28
What does it usually cost to have then CNC cut?
I've never priced it. I would suggest posting that question separately in the Projects area as the guys who fabricate from steel frquently would know details.
I would guess it is not a huge expense so long as you can provide compatable CAD drawings. These systems are standard in medium size custom steel shops now. Cost should be reasonable if they have some down time and you are not in a rush.
/ Home made Grapple #29
I was just wondering about the cost. I was planning on using 3x3x1/4 square tubing for the main frame and 3x1/2 flat for all of the tines. I thought I would make the tines 30in long. The over all wide of the grapple would be around 63in.
/ Home made Grapple #31
Hi millwrightdude. I also made a grapple based on this thread. Here is the link to my version. http://www.tractorbynet.com/forums/...-my-tractorbynet-inspired-grapple-bucket.html
After using my grapple for a couple years I would make a few changes.
My tines are 2 1/2 by 3/8 and have held up great. I would use 4" spacing for all the tines (I have some 8" in middle of the bucket). The back is 8" which is fine. I think the length is 24" which is great although I could handle 30", would not want longer then that.
I would also make my top tines curved and serrated.
I would change the leverage on the cylinder as I would like a little more squeeze sometimes.
I have used the bucket a lot. Logs, Brush, Rocks, leveling/raking, snowmobile bridge work. I love it!
Dean
/ Home made Grapple #32
My loader is 57in wide and I allowed for 3in on either side. I want to make a frame similar to the pallet forks I built a few years ago.
/ Home made Grapple #33
So 3/8 tines have been good for you, or would you go to 1/2. I have been thinking about 6in spacing. I could go to 4 but I think 6 is ok.
/ Home made Grapple #34
The 3/8 have been fine. I recommend 4" after seeing what stuff falls thru the 8" spaces.
/ Home made Grapple #35
I look at that when I start the build. My quick attach brackets should be here today
/ Home made Grapple #36
I'd go with a narrower grapple myself. My standard bucket is 72 inches. My grapple is 48 inches and perfect.
Regarding tine size and spacing, 3/8 is fine in the design I have. Note carefully the different shape of my grapple tines. They are thick at the root and tip but narrower in the middle. Custom CAD/CNC would be necessary but engineeringwise I think it is better than just a straight piece.
My tines are about 8 inches apart as I recall, maybe 9. There are times I wished they were closer but not for brush. Brush is sticky and really doesn't fall out much. Rocks are what I would like to hold onto better. I think 6 inches would be nice but remember that more tines equals more weight.
/ Home made Grapple #37
Has anyone seen a grapple with an 'overbite'? If you're picking up a bundle of small logs, at best you may be able to pinch one using the typical grapple design. I often wonder if allowing the grapple to close beyond where the tips meet the tines would help clamp smaller loads.
Another grapple design question, is there any tool to help lay out the pin locations for the cylinder and hinge? It obviously plays a key role in the travel, speed and force of the grapple, and i'm fairly certain it would be a fairly trivial trig function, but i've never really seen one.
/ Home made Grapple #38
I'm glad others are building grapples as this is going to be a spring project for the new plasma cutter. I haven't decided as to how wide yet but most likely will be 3/8" tines 32" long somewhere between 4" to 5" tall. I'm not sure about spacing yet, somewhere between 6" and 8". But I like reading what others have done or like about what they have.
/ Home made Grapple #39
I see most grapples have two upper claws, does anyone think three would be useful?
/ Home made Grapple #40
The limiting factor on load is more the depth of the grapple and how wide it opens. An overbite would help with bulky long loads like logs but would hurt the ability to secure smaller items. The overbite might also interfere with getting close to a wall for example. Still, a slight overbite is better than underbite.
Regarding geometry of the upper jaw cylinder pin location, I imagine it is trial and error or mock up based unless you have an animated CAD program.
Upper jaw clamping force in a standard style grapple is not critical as gravity holds the load down and the upper jaw just keeps the load from falling out forwards. For a claw style grapple the clamping force is key as it is the only thing keeping the load in place.
UNUSED IRANCH MINI HYD THUMB (A62131)
UNUSED IRANCH MINI...
Tandem Axle Rear Truck Frame (A61568)
Tandem Axle Rear...
2014 Timpte Hopper Bottom (A63118)
2014 Timpte Hopper...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A62130)
2020 CHEVROLET Z71...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
1985 Ford Ltl9000 Tender Truck (A63118)
1985 Ford Ltl9000...
