Fuel Filter on 273
/ Fuel Filter on 273 #1
Stumpshot
Member
Time to change the fuel filter. The owner's manual is useless and I need to know if there are 2 valves on the filter. I'm not sure about the purging of the system on a fuel injected unit. What's the sequence and which way do you turn the valve on top of the fuel filter for off? My valve can set 3 ways, upstream, downstream and 90 degrees to the line. I'd assume any position 90 degrees would shut it off but this thing ain't a U.S. tractor.
Thanks.
/ Fuel Filter on 273 #2
Thanks.
Never had a problem with air when I changed the filter. Just shut off the tractor, unscrewed the plastic bowl, changed the filter. Turned the key on and the electric pump filled up the bowl. Tractor started right back up.
Thanks Bud.
Exactly what I had planned to do.
Roy
2005 COMPTANK ACID TRANSPORT TRAILER (A67714)
2005 COMPTANK ACID...
Unused 2023 Maybridge M79 3 Point Hitch Carrier Chain Harrow Lift Tractor Attachment (A66734)
Unused 2023...
1994 MACK CH613 FUEL AND LUBE TRUCK (A67714)
1994 MACK CH613...
CRATE OF MISC ELECTRICAL WIRING (A68842)
CRATE OF MISC...
2016 FREIGHTLINER 125 DAYCAB ROAD TRACTOR (A65054)
2016 FREIGHTLINER...
2014 Ford Explorer AWD SUV (A66738)
2014 Ford Explorer...
