Dodge Diesel Question...
/ Dodge Diesel Question... #41
Took a look at my '04 this morning. I have no such thing on my truck. Could it have something to do with 4 wheel ABS maybe? I've got the service manual on a CD that I could look at but my mouse roller is shot and that makes it pretty hard to navigate it. Maybe I'll get a new mouse this week yet. Sorry I'm no help, yet anyway.
Kim
/ Dodge Diesel Question... #42
Do you have cruise control? If you have an 04 diesel with cruise control then you have a vacuum pump. It wasn't until the switch to throttle-by-wire in 06 or 07 (I think) that they changed it.
/ Dodge Diesel Question... #43
Truck does have cruise control.
Kim
/ Dodge Diesel Question... #44
OK, I went back to the beginning of this thread and now see the pump is on the passenger side firewall.
The coolant recovery bottle on my 3/4 ton is on the drivers side right next to radiator and windshield washer bottle so I was looking on the bottle. Looking back on the passenger side firewall I see the air conditioner accumulator that is in his picture but there is no pump like that anywhere under the hood that I can see. My truck build date is 7/03. HO Cummins 6 speed manual quad cab short box. I guess the one tons are different under the hood?
Kim
/ Dodge Diesel Question... #46
Kim
Vacuum pump for the cruise control is for Automatic transmissions only.
Throttle-by-wire was introduced in 98.5 when they went to the VP44 IP.
Completely different system but technically still "throttle-by-wire". The newer system is completely ECU controlled.
/ Dodge Diesel Question... #48
Thats right. I looked in the service manual and discovered that. Couldn't find much mention of the pump except in the speed control section, but I did find in the electrical section that it is located where the OP's picture shows the pump in question. It is powered on with the ignition switch and is on the same fuse (#1, 7.5 amp) as the AC pump relay. Didn't see any external switching of the pump so it must be internal by demand. Looked around in the automatic transmission section but I didn't see any mention of vacuum in its operation. I have no idea where the vacuum lines would go other than the cruise servo, and possibly the transmission.
Kim
/ Dodge Diesel Question... #51
Why leave just the cruise control a vacuum controlled item ?, did they ever get away from that and go all electric cruise ?
/ Dodge Diesel Question... #53
mj007 I was reading all the suggestions and I could'nt believe someone didn't steer him in that direction sooner. If the others don't know about that site they should check it out when they have time. I have been a member there for about 5 yrs and fixed many problems on my two diesel trucks.:thumbsup:
2019 CATERPILLAR 259D SKID STEER (A64279)
2019 CATERPILLAR...
2019 HINO 268 4X2 26FT NON CDL BOX TRUCK (A59911)
2019 HINO 268 4X2...
2010 Dodge Charger Sedan (A61574)
2010 Dodge Charger...
Vegetable Sprayer (A60462)
Vegetable Sprayer...
JOHN DEERE 4760 TRACTOR (A64280)
JOHN DEERE 4760...
2018 John Deere R4030 Sprayer (A63111)
2018 John Deere...
