not2old
- Joined
- Oct 16, 2010
- Messages
- 1,643
- Location
- Scotch Creek, British Columbia
- Tractor
- 2010 Massey GC2610TLB
When I have a stubborn pile i go to the top of the pile with my bucket as far in the "dump" position as possible. I then put the bucket down (with force) at the top edge of the pile and drag backward. This creates a pile of loose dirt that is easily scooped up.
A couple of hits with this procedure and you will soon start to use it all the time on anything stubborn. I find I can completely fill the bucket easier using this method.
My 2 cents.
I'm still a beginner, but this is the method I've been using for the best results. I've also used the curl lever back and forth, while putting down pressure on the bucket. I then back up in order to take a full scoop,filling the bucket to the point where I have to spill some so that it won't get scattered along the ground where I'm travelling across the yard.
