If I could chime in here for just a second, KennyD I read the specs for the electric diverter valve, and Think I understand it well, but my question is more of an operational question than technical. Lets say I connected this valve in the following manner. on my
L3400 take the 2 work ports out of the front end loader control valve that normally control curl/dump into the p1 and p2 input to this electric diverter valve then plumb back the other 2 ports that have the flow path in the non-energized state back to the curl/dump hoses going to the loader cyl. so then the loader curl/dump circuit is made back just like it was. then plumb the other 2 ports out to a
grapple thumb cylinder and maybe put a needle valve in this circuit or use 1/4 inch hoses to slow it down some. then hook a momentary foot switch on the left floorboard of the tractor to energize the coil to send fluid to the
grapple to close when I move the main loader control towards the curl side . and when I want the
grapple to open I would press the foot switch and push the main control to the dump side. What I am asking is this the way it would work, and is this a good plan from an ergonomic operational standpoint? I have never operated a
grapple before, I do have over a 1000 hours behind a front end loader control, lever but 0 hours using a
grapple. I am thinking as you approach the brush pile, you move the loader controls as normal to line up the "grab area" by using the lift and curl/dump to get it where you would "bite" then stomp the button to energize the coil and then move the control lever to dump to open the
grapple, then move the tractor forward into the pile, move the control the other direction to close the
grapple, release the foot button and then curl the bucket as needed. Does this sound right. ? Sorry for the extra long post, but I am really trying to think this through, and on this subject, I am a total newbie.
James K0UA
