Toolbox Installed
/ Toolbox Installed #1
JDGreenGrass
Maine
John Deere 770
Couple of notes....Though it looks like it may be in contact with the back of the seat...it isn't. Not even when I sit in it. And, it had to be off center in order for the latch to have room from the top-link. I put it to left side or, what I call, operators side.
A good place for pins, shear bolts, plyers, adjustable wrench, small hammer and the like.
I need to mount a rear work light and it looks to me like it could go right on the steel fixture to the right of tool box. The light would be high enough to angle down and over my snowblower. What do you folks think.?
Here's the pictures....
/ Toolbox Installed #2
Looks great.:thumbsup: Did you weld that up or buy it?
/ Toolbox Installed #3
Looks good you will be surprised how much stuff you can actually get in there its amazing how you can fit so much needed stuff in one hahaha!
/ Toolbox Installed
I bought the toolbox and the length of steel that is bolted to the tractor from TSC. Drilled some holes, painted the inside of the toolbox and the steel length and then mounted it.
Thanks for the comment.
/ Toolbox Installed #5
That looks good, I wonder if one of those Northern Tool Led lights would fit on that bar?. A couple of folks here say they have them and they are ok. I have been thinking about one.
James K0UA
/ Toolbox Installed #6
I like :) wish I could have done the same but I was inform tra. sign needed to been seen in full when on public road.
/ Toolbox Installed #7
Nice job, JDGreenGrass!!
That will be very handy for a few tools, pins and such.
/ Toolbox Installed #8
Slick, but it just looks like all the stuff inside it would rattle like crazy when riding on some rough terrain.
/ Toolbox Installed
Thanks for the comments. Happy to get everyone's approval except that I wondered about the "caution sign" being blocked. In fact I put the project off because of it. 2nd time I thought about the toolbox I got focused and never even gave the sign a thought.!! Hey, I'm getting old.:laughing:
Anyways, I've been into this tractor thing for about 1 year, now. I am finding that my greatest joy is painting parts and I have a small desire to weld. I'm useing Valspar out of a can. Seems to cover quite well.
What do you guys use to paint parts and such.?? I have a 15 gallon air compressor and am wondering if I should be shopping for a paint gun. Or, just stick with the can.??
How about welding....Seems technical and somewhat like electricity to me.?? Like, you gotta know what you're doing or you get hurt.
Is welding a difficult trade to take up.?? Trust me, I know I ain't there yet.:D
/ Toolbox Installed
No problem with that. I'll put the thickest rag I can find in there to keep things damp.:thumbsup:....I just hope it works.!!
/ Toolbox Installed #11
Arc welding can be easy or extremely difficult. It all depends on the materials you are trying to weld and the equipment you have. For most projects around a farm you will be welding hot rolled steel such as angle, flat stock or channel. You may also use cold rolled steel such as dimensioned rod. These are easy to weld, especially if horizontal. There are also cast iron parts on agricultural equipment. They require a different technique to avoid crystallization of the metal. When you get into stainless steel or aluminum you are looking at very specialized equipment.
You can teach yourself to weld if you do some reading and practice on some scrap steel. You may be able to rent a small AC stick arc welder at a tool equipment outlet. Take it home and give it a try. Some Vo-Ed or trade schools offer night classes to the public. That way you are actually getting some good instruction, too.
You can get started with a simple 225 amp AC welder for around $250. An AC/DC welder will cost more. DC is nice for welding overhead and thinner materials. You can then go to wire feed with different gases for specialized metals.
For general repair around the home or farm an AC or AC/DC will work fine.
As far as safety with the electricity. If properly wired your primary danger will be from hot slag or spatter, not electrocution.
/ Toolbox Installed #12
You have lots of room there for a light, it's the same place I mounted mine.
Sean
/ Toolbox Installed #13
I had a tool box mounted between the uprights on my 790. It blocked the SMV sign....so I bought a bracket (commonly available) at my farm store and mounted the "receiver half" on the tool box and the other half on the SMV sign from the seat. Low cost / worked slick. :thumbsup:
/ Toolbox Installed #14
You can just see the bracket I'm talking about (above) from this pic. It makes the SMV sign detachable. To me....the tool box was indispensable....and always jammed to the gills. :laughing:
My box somehow got dented from the top link when I hooked up to my landscape rake. None of my other implements had any issues.
I don't want to be a naysayer....(believe me I know how hard it is to fit a tool box to your tractor)....but I think you may have some durability issues with that mount....unless you figure a way to re-enforce it. You may want to take up that welding habit. :thumbsup:
/ Toolbox Installed #15
They are kinda' tight on space! :( I looked at that spot, but went a different route. Water bottle holder on one side of ROPS, fire extinguisher on the other.
For tools, I have a small ammo box clamped to the loader frame on my 790. Hammer & big screwdriver fit into tubes on the left side of the seat & chain & clevis into a box under the grille. ~~ grnspot110
/ Toolbox Installed #16
JDGreenGrass.
By just showing interest almost half the battle..welding one could hang out at shop or sign up for classes
Puttering on tractor always been great therapy. :)
/ Toolbox Installed #17
Welding is easy to start, learning to weld like a pro could take a lifetime. I recommend DC stick welding, It is smoother, less spatter. You will be able to glue parts together the first day, but sometimes the results might not be that pretty. Also highly recommend a good auto darkening helmet, the one thing that will really make your welding better. Especially for a beginner. Every beginner thinks it is so cool to "nod" down a helmet like a pro, but let me tell you, keeping your start position and scratching around in the dark to get the arc started is for the birds (and the pros). With the auto darkening helmet, you can see (especially if the work area is well lit) from the get go, just position your rod, and scratch or tap away to "get her lit". But all that said, I would recommend everyone that likes to make metal things, get a welder, I have sure enjoyed my welders.
James K0UA
/ Toolbox Installed #18
I welded for years before AD lenses were invented. The only way to keep that rod in the bevel is to hold it like a billiard que stick between your fingers then flip the hood down and strike the arc. You burn up a lot of gloves that way, but if you dont and arc outside the bevel then you could loose your job at least when welding pressure pipe. AD lenses didnt come along till much later and first one I used was when I was teaching welding at Long Beach City College in 1990 and it sure kept the flash burn down as I could walk around with my hood down and walk up behind the student without getting flashed. I gave away all my American Optical gold lenses after that (wish I had kept a few as they go for over $100 now)
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
2017 Ford F-250 4x4 Crew Cab Medical Service Truck (A61573)
2017 Ford F-250...
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
2019 Isuzu NPR 14' Box Truck (A62613)
2019 Isuzu NPR 14'...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
