How Do You Get To 8F/4R.??
/ How Do You Get To 8F/4R.??
Hmmm.??.... I went back and read all the posts. Seems this tranny still has problems with reverse speeds.
My JD770 has 8F/2R. I have a new 3pt. blower this year and I am anxious to see how well the gears will handle speed. I like the L2800 because it has more "options" in reverse but may be a tad fast still.??
Anyone out there running a rear blower with the 8F/4R set up.??
/ How Do You Get To 8F/4R.?? #22
I drove my neighbors JD tractor and it had R,1,2,3,4 plus A, B, C so that would be 3 choices for each gear wich would make 12 forward and 3 reverse I would mostly back in RA but it was fairly slow but once in a while I would back in RB and if I wasn't careful on the clutch I would be thrown forward in the seat cause of the different speed. It was like night and day.
/ How Do You Get To 8F/4R.?? #23
I doubt you'll have any problems with reverse speed, 1 and 2 are fairly slow even in reverse. Power may be an issue depending on how wide the blower is. The 2800 gives you about 26 hp at the PTO. The 3400 or 3700 are the same size as the 2800, although the 3700 is only available in HST, or so I'm told.
There may be a new Kubota offering in this HP/size range this year if rumours are true.
Sean
Sean
It sounds like the L2800 is going to be replaced by an L3200.
2010 48 ROLL OFF TRAILER (A65643)
2010 48 ROLL OFF...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
1995 NAVISTAR INTERNATIONAL 4700 S/A FUEL TRUCK (A65054)
1995 NAVISTAR...
PALLET OF AXLE TAKE OFF'S & CYL (A64278)
PALLET OF AXLE...
