How Do You Get To 8F/4R.??
/ How Do You Get To 8F/4R.?? #1
JDGreenGrass
Veteran Member
Maine
John Deere 770
Gear transmission...How do you get 4 reverse gears with 2 or 3 ranges.??
Such as on the L2800.
/ How Do You Get To 8F/4R.?? #2
At a GUESS it is a 4 speed box, with a "2 range box" on forward.
/ How Do You Get To 8F/4R.?? #3
I can't say on a L2800, but on our 2550 JD you have 4 synchronized gears on the right shifter and the left shifter has High range, Low range and Reverse. Low and reverse ranges are in line for shuttling back and forth. I would imagine the Kubota is similar.
So what you are saying is your 2550 has 12 reverse gears, correct.??
The L2800 has 8F/4R.?? The first reply may well be right.?? I still don't fully understand.?? No hi/low range in reverse.?
/ How Do You Get To 8F/4R.?? #5
Nope, 8 gears forward, 4 reverse.
/ How Do You Get To 8F/4R.?? #7
Just exactly that... the range lever has Low, High and Reverse positions, and there are four ratios available on the separate H pattern gear lever. The ratios are well thought out, 4 low is a bit slower than 1 high, etc.
The Kubota isn't synchronized (no shift on the fly without double clutching).
Sean
/ How Do You Get To 8F/4R.?? #8
SOME tractors are set up to block out the high range(s) in reverse, SOME are not.
It is simple enough with a 4 x 3 for example to allow only the lowest of the 3 ranges to engage when in reverse - that would give a 12F 4R, which is not uncommon.
12F 8R are also around.
I happen to have 12F 12R on one of my tractors, though I don't think I have ever used any of the highest 4 (high range of High, Medium, Low).
16F 16R shuttle shifts are common too.
It doesn't make a lot of sense to have "road" gears in reverse anyway - and in the US they may well be blocking them for liability reasons (-:
Was your question why or how ?
/ How Do You Get To 8F/4R.?? #9
This is the correct answer. At least in the case of the L2800 and L3400's.
The shuttle shifter has high low and reverse. The gearshift on the transmission hump itself is 1-2-3-4.
So you can have R1, R2, R3, and R4 for reverse
For forward you have L1, L2, L3, L4, H1, H2, H3, H4. A total of 8 forward speeds.
My only complaint on the L2800 and L3400 tranny and speeds is that Low forward and Reverse aren't the same gear ratios. Meaning that R4 is FASTER than L4, R3 is faster than L3, etc. So when mowing or doing bucket work, where shifting the shuttle shifter from Low to Reverse quite frequently, it is a PITA going faster in reverse at times.
/ How Do You Get To 8F/4R.?? #10
My 30 year old JD2240 has the same setup. 8F & 4R and you're right about the reverse speed being different. It's not the same as either High or Low, but rather somewhere in between. I usually operate somewhere between L1 and L3 depending on what I'm doing and reverse is quite a bit faster.
/ How Do You Get To 8F/4R.?? #11
Yep. Your 2240 is probabally the same as the 2040. Both shifters are the center "hump" right beside eachother. The H-L-R lever actually as 4 positions like the 1-4 shifter. The 4th (left and up) is a park.
But the same concept none the less. 8F and 4R. But most of the newer tractors have the H-L-R selector in a more "convenient" location to the left of the seat at your side.
/ How Do You Get To 8F/4R.?? #12
My 870 has 9F 3R and same issue reverse is always faster that forward. Perhaps they are assuming you're backing over your own tracks so there won't be any obstacle issues and you can set back up quickly to go forward for what ever you're doing??
/ How Do You Get To 8F/4R.?? #13
That's the way most tractors are set up. In their mind the primary function when shuttling from L to R is for loader work, so having a slightly higher reverse speed is ok (makes for a quicker cycle). Where it is not ok is like on the JD I previously mentioned. I'll be round baling along in L4 and need to reverse to dump the bale, and at PTO speed R4 is ridiculously high for this. So then you have to shift the other stick into a lower gear also.
/ How Do You Get To 8F/4R.?? #14
I have the same complaint. I find the worst is when mowing. I usually mow in either 4 low or 1 high. Reverse is either too fast or painfully slow in either 4 or 1.
Sean
/ How Do You Get To 8F/4R.?? #15
Sean
Exacally my problem as well.
I usually mow in 4L because my yard is smaller, and I usually wait too long before finally mowing:D. 4R is jsut too much faster than 4L to give a good cut.
The few times I get on the ball and can mow in 1H or 2H, given the smaller yard and a lot of reverse, I fine it too much of a pain going from 1H to 4R, and I usually just mow in 4L anyway.
/ How Do You Get To 8F/4R.?? #16
FWIW, my L2850 has 8 F and 7 reverse. It has 4 gears with high/low selector. The 4h reverse is block out. DT8 tranny I believe.
/ How Do You Get To 8F/4R.?? #18
I have been lurking, just gathering, Oh boy Jackpot! .. my tranny has infinite forward and reverse!:laughing::laughing::laughing::laughing:
James K0UA
/ How Do You Get To 8F/4R.?? #19
Our 2550 has that, but a little slop that has developed in the linkage lets it go into H4R. :thumbsup:
larry
